Should I take "EZ Lube" seriously?
Discussion in 'Performance and Tuning' started by Styx586, Aug 26, 2011.
  1. Aug 26, 2011 at 4:56 PM
    G scott04
    G scott04 ...
    Garrett
    Mesa
    04 PreRunner
    That sounds like a good plan!
  2. Aug 26, 2011 at 4:59 PM
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    :smack: for even taking your truck to one of those places
  3. Aug 26, 2011 at 5:13 PM
    drewskie
    drewskie Well-Known Member
    Drew
    Burbank, CA.
    08 Prerunner 4 banger
    x2. Of all the quick lube joints, EZ lube is by far the worst. i can't believe they haven't gone out of business yet. The "techs" are on commission for everything they sell, and they make up things that don't even exist. I'm willing to bet anything they didn't even look at your diff or the tranny. Also, the best part is, they wouldn't do they work even after you payed them. They are notorious for that, they've tried it on me, and there are numerous complaints about it online.
  4. Feb 17, 2012 at 9:57 PM
    LGE RAW
    LGE RAW Well-Known Member
    Rob
    Dothan
    2020 TRD Off Road DCSB 6AT Magnetic Gray Metallic
    New Mods in the works.
    Even for a quick oil change, i can usually be in and out of my Toyota dealer in under 20 minutes. They use Mobile 1 oil and the notoriously good Toyota filters. If you go to the Toyota web site, you can print your own coupon for $28 for a V6 and $30 for a V8. Plus, they document a multipoint inspection and include it with your receipt.
  5. Feb 19, 2012 at 2:12 PM
    shampoop
    shampoop Well-Known Member
    southwest WA
    08 tacoma extracab v6 auto trd offroad 4x4
    yes, they are trying to get your money.
    When using conventional fluids transmission should be flushed at least every 60k, same with diffs/tranfer case. Toyota uses the red long life coolant that lasts basically forever, so due to the fact that a timing beltand water pump is recommended every 90K, I would just do it then cause you're going to be draining it anyway, unless it takes you an absurd amount of time to reach 90k miles.
  6. Feb 19, 2012 at 2:28 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Obviously, you better take EZ Lube (and the other quick change oil places) very seriously...
    http://www.consumeraffairs.com/automotive/ez_lube.html
    http://www.consumeraffairs.com/autom...valvoline.html
    http://www.jiffylubeproblems.com/
    http://www.consumeraffairs.com/automotive/walmart.htm
    http://www.complaintsboard.com/bycom...ube-a3272.html
    http://www.jiffylubeproblems.com/Experiences676-700.htm
    http://www.mohea.com/mike/words/000158.html
