Should traction control button be illuminated?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by unclemat, Jan 16, 2018.
  1. Jan 16, 2018 at 9:44 PM
    unclemat
    unclemat [OP] Well-Known Member
    2012 TX Baja
    2013 TRD (Baja). Noticed mine is dark while Mine is dark, when fog lights, DAC, Diff lock, RSCA are lit.
    I am guessing it should be lit, seeing the picture linked below.
    Need new button or the lamp can be easily replaced?
    Thanks!
  2. Jan 16, 2018 at 9:51 PM
    unclemat
    2012 TX Baja
  3. Jan 16, 2018 at 10:05 PM
    unclemat
    2012 TX Baja
    So the amber bulb part # is 90011-01058.
    I need green, and I have hard time finding the correct part #... anyone?
  4. Jan 16, 2018 at 10:22 PM
    baboltin
    baboltin New to the 3rd gen world!
    Brad
    Tehachapi,Ca
    2019 Toyota Tacoma
    Stock with a camper shell for now.
    I need to do this as well
    I have a couple burned out I guess as well that I always thought never lit up
  5. Jan 16, 2018 at 10:27 PM
    bobsuruncle
    bobsuruncle PhD in voiding warranties
    Bob
    Fall City, WA
    06 TRD OR DCSB
    ARB bull bumper Warn XD9000 Icon 2.5 EXT Road Armor rear bumper Archive Garage shackle flip FJ/T4R tcase 4.30 gears Dirty5’s T4R rear axle swap w/disc brakes New frame from Toyota under EWP
    Priced out a used one? I thought those where LED, not a bulb?
  6. Jan 16, 2018 at 10:36 PM
    unclemat
    2012 TX Baja
    Looking up Toyota part numbers is so fucked up. So much easier finding stuff for Subarus. Software can be downloaded easily and there are good online catalogs with diagrams. :(
  7. Jan 16, 2018 at 10:43 PM
    unclemat
    2012 TX Baja
    Part code is
    84988J BULB, DOWNHILL ASSIST CONTROL SWITCH
    But still cannot narrow down the actual part number. :annoyed:
  8. Jan 16, 2018 at 10:44 PM
    bobsuruncle
    Bob
    Fall City, WA
    06 TRD OR DCSB
  9. Jan 16, 2018 at 10:46 PM
    unclemat
    2012 TX Baja
  10. Jan 16, 2018 at 10:46 PM
    bobsuruncle
    Bob
    Fall City, WA
    06 TRD OR DCSB
  11. Jan 16, 2018 at 10:54 PM
    unclemat
    2012 TX Baja
    Yeah these part catalogs are total garbage.
  12. Jan 16, 2018 at 10:54 PM
    tn_popo
    tn_popo OINK
    Billy
    East Tennessee
    '18 Tacoma DCSB TRD Sport V6 Inferno
    Are the steering wheel controls in a '14 supposed to light up?
  13. Jan 16, 2018 at 11:04 PM
    unclemat
    2012 TX Baja
    I think the best bet is 90011-01018. It is shown for clutch cancel switch (the only button apparently with replaceable bulbs). At least it should be green.
  14. Jan 16, 2018 at 11:27 PM
    REDdawn6
    REDdawn6 Well-Known Member
    Redlands CA.
    2011 Tacoma TRD 4x4
    Ask our resident parts dealers w/TW discounts... Gunny1005
  15. Jan 19, 2018 at 4:03 PM
    baboltin
    Brad
    Tehachapi,Ca
    2019 Toyota Tacoma
    Does anyone know what or if this bulb can be replaced with a led bulb and what size led bulb it would be ?
  16. Jan 19, 2018 at 4:07 PM
    Alloutdrs1
    Alloutdrs1 Well-Known Member
    Andrew
    Virginia Beach, VA
    12' Mag gray Doublecab 4x4
    Distinct Offroad light bar, Rigid E-series and amber duallys, Leer 100xq, Oem roof rack, Oem bed mat, Bullculla trailer plug relocate bracket, Rear diff vent mod, front mud flap chop, Color matched Grille w/Andres devil horns, Wet okoles and weathertechs
    Subd for outcome as I noticed my trac switch is out this week as well.
  17. Jan 21, 2018 at 2:40 PM
    Alloutdrs1
    Andrew
    Virginia Beach, VA
    I pulled my Trac switch out today along with the downhill assist and rsca off and the bulb is the same between those three.
    MolonLabeTaco likes this.
  18. Jan 21, 2018 at 4:34 PM
    JdevTac
    JdevTac Well-Known Member
    Josh
    MD/GA
    2nd gen
    It is a t3 neowedge if you want an LED replacement. Beware though it needs to be about the same height as the OEM bulb otherwise the switch won’t actuate.
  19. Jan 21, 2018 at 9:19 PM
    baboltin
    Brad
    Tehachapi,Ca
    2019 Toyota Tacoma
    Very good to know that you maybe I will leave well enough alone
  20. Jan 21, 2018 at 9:32 PM
    baboltin
    Brad
    Tehachapi,Ca
    2019 Toyota Tacoma
    Is the 4x4 switch suppose to light up as well ? Maybe my bulb is burned out of it as well ?
