Should your truck sit level??
Discussion in 'Suspension' started by wolfspirit, Jul 14, 2008.
  1. Jul 14, 2008 at 2:38 PM
    wolfspirit
    wolfspirit [OP] Member
    I just don't get it. Maybe I"m being to critical here. I have a 2" leveling kit on the front and 265/75R16 Federal M/T tires on stock rims. When I measure from the ground to the bottom of the fender ( through the centerline of the rim) here are the measurements.
    Drivers Side Passenger Side
    Front 37.25" Front 37"
    Rear 37.5" Rear 37"
    Is this no big deal or should I be worried and look further into it. The truck is on a level surface and there is no load in the bed.
    If it was because of the gas tank, it would be heavier on the drivers side, not lighter. I can't figure this one out.
    Thanks in advance.
  2. Jul 14, 2008 at 2:40 PM
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2011 DC TRD SPORT Prerunner
    3” spacer lift, 285/75/17 KO2, Spidertrax 1.25” spacers
    The driver side usually sits lower, thats quite odd.
  3. Jul 14, 2008 at 2:45 PM
    tacoskim
    tacoskim Tuned By Gadget
    Los Angeles, CA
    09 TRD 4x4 Pyrite Mica
    Stock
    i think the driver side sits lower cuz of your gas tank, your battery, and all the controls, and you are located on the left(Drivers side). i remember reading bout this a while ago
  4. Jul 14, 2008 at 3:00 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    Well I changed all that after I installed my lift. I never noticed the lean however after the lift I went and tested out my suspension and now I have a slight lean, lower on the passengers side.
  5. Jul 14, 2008 at 3:19 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    I wouldn't worry about it.... you'll spend tons of money & time trying to chase it. Besides.... take measurements when the gas tank is full versus measurements when the gas tank is empty and see what you come up with.
    The previous generation trucks (95-04) were known for having a lean due to everything being on the drivers side (including gas tank). The front coils were different also - the drivers side coil had one extra winding in it to make up for the weight. But...if you put new coils in - they didn't have that extra winding and the truck would lean badly.
    I remember chasing a lean on my 96.... Roncho (Rancho) setup was horrible. The OME 881 coils & the custom leafs, but I ended up with a 1/4 thick spacer to help level things out and it still wasn't *perfect*. After chasing it for too long - I said TO HELL WITH IT!!
    I don't know how these new trucks are in terms of *The Toyota Lean*. I'm keeping mine stock for as long as I can!
  6. Sep 28, 2009 at 12:37 PM
    machman
    machman Well-Known Member
    NE Alabama
    03 DC PreRunner TRD V6
    The ground not being perfectly level could also through off your reading. Even concrete that looks level can be way off.
  7. Sep 28, 2009 at 12:39 PM
    tacoskim
    Los Angeles, CA
    Stock
    holy year and 2 months
