Show me frame welds for your sliders!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Oysterhead, Jan 24, 2012.
  1. Mar 1, 2012 at 7:59 AM
    Oysterhead
    Oysterhead [OP] Well-Known Member
    Nashville
    '10 TRD OR
    Kings are king
    They're on! The rear leg was a beyotch. Didn't use a gusset, but with the angle I agree with Adam that it's unnecessary.
    I used a 17 degree angle, which is about max to avoid interferencew with the rear door.
    The distance between the pinch weld is about 1", except for the rear leg which is about 1/2" (since it angles up).
    Watch the brake lines on the driver side!
  2. Mar 1, 2012 at 8:11 AM
    tacoma89
    tacoma89 Money Pit
    Chase
    Richmond, Va
    08 sport dc lb
    Check build in sig.
    looks good... i still need to do mine
  3. Mar 1, 2012 at 8:14 AM
    Brunes
    Brunes abides.
    Rotorhead
    Nice work...I gotta get my wife's CBI sliders on her 4R someday soon....
  4. Mar 1, 2012 at 8:16 AM
    JLee
    JLee The Man! Vendor
    Jerry
    Bay Area NorCal
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    I would weld the top of the plate and plug weld those holes so you can keep the moisture from getting behind the plate. other then that :thumbsup:
  5. Mar 1, 2012 at 1:24 PM
    Oysterhead
    Nashville
    '10 TRD OR
    Kings are king
    I'm planning to spray the holes with undercarriage rubberized paint.
  6. Mar 1, 2012 at 1:33 PM
    JLee
    Jerry
    Bay Area NorCal
    As long as it seals it up so water can't get behind your frame plates you should be fine.
  7. Mar 1, 2012 at 1:41 PM
    korslite
    korslite Well-Known Member
    Justin
    Bellingham, WA
    DCLB Sport
    FOX 2.5 RR's, TC UCAs, TC Spindle Gussets, Allpro Expedition leaf pack, Fox 2.O RR w/ Comp adjusters, 17" ATX Artillery, BFG AT 285's, de-scooped, custom sliders, custom bedrack, Brute Force Fab bumpers, Smittybilt XRC8 winch, ARB locked Rear diff
    Still a real good idea to weld that top seem as well. That is a great place for water to get in and your frame will rot out long before that mounting plate does. I nipped the top corners off of my mounting plates so the horizontal portion at the top is shorter and easier to weld. That top side can be tough to see or get a wire gun in there.
  8. Mar 2, 2012 at 10:08 AM
    G scott04
    G scott04 ...
    Garrett
    Mesa
    04 PreRunner
    Haha rust
  9. Mar 2, 2012 at 10:42 AM
    Mitch
    Mitch Somebody call for a Wambulance?
    Mitch
    Spokane, WA
    2007 Access Cab SR5 4x4
    Lights, Siren, Drugs, Needles, Electricity
    I just looked at mine and found some surface rust on the back leg. Wipped it off and repainted
  10. Mar 5, 2012 at 7:57 AM
    Oysterhead
    Nashville
    '10 TRD OR
    Kings are king
    I had all the open seams welded including the tops. (the trip to Essentially Off Road in Murfreesboro was worth the time/$$ alone, serious buggies).
    All legs and plates were primed and painted with rubberized undercarriage paint. The holes were not welded. That stuff can clog some serious holes. I was wondering about a "bondo" or similar product that I could use to fill-in the holes...
    For now, the slider project is complete and I'm very happy with the outcome. I'm confident they can easily hold the weight of the Taco and the new look is pretty darn sweet too.
  11. Apr 8, 2013 at 9:37 AM
    double dee
    double dee Well-Known Member
    Phoenix
    2016 Tacoma 4x4
    I know this is an old thread but I noticed you did not have frame plates. Have you ever come down on them hard for any bending to occur? The shop I took my sliders to have welded on did them they same way yours are even though I provided them with the frame plates and gussets. I told them they needed to fix it but they refused so I am in the process of disputing the charge :(
