Show me what's in your camper shell!
Discussion in 'Tonneau Covers, Caps and Shells' started by whitetaco02, Apr 20, 2014.
  1. Feb 26, 2016 at 6:11 PM
    #241
    CenCal805
    CenCal805 Well-Known Member
    California
    2016 Tacoma TRD OR AC
  2. Feb 27, 2016 at 3:11 PM
    #242
    MTNHABITOVERLAND
    MTNHABITOVERLAND Well-Known Member
    2016 Tacoma Camper Build Instagram: @mountainhabit
    Vagabond Outdoors Camper
    Where are you located?
    Want to do this again?! Lol!
  3. Feb 27, 2016 at 3:59 PM
    #243
    CenCal805
    California
    I'm in Cayucos, CA. While I'll admit building it was fun, I think I'll spend my weekends enjoying it. ;)
    Find someone who is a woodworker, and see if they will help/teach you with the build. I spent about 70 hours with my retired neighbor/woodworking ninja and built this. I learned a ton, and now have this rad friendship with my neighbor and his wife. I wanna adopt them as my parents! Haha You'll be stoked when it's finished, I promise.
  4. Mar 1, 2016 at 2:45 PM
    #244
    jbv1030
    jbv1030 Well-Known Member
    La Verne CA
    2004 White Tacoma 4x4 Icon stage 2
    for those of you that installed nets on the inside of their shell or other attachment points, did you drill from the outside of the shell in? or from the inside to the outside? didnt go through the shell?
    thanks!
  5. Mar 1, 2016 at 2:50 PM
    #245
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    Do you have Thule or Yakima tracks?
  6. Mar 1, 2016 at 2:56 PM
    #246
    jbv1030
    La Verne CA
    i do not...though that is also on the short list...
  7. Mar 1, 2016 at 3:05 PM
    #247
    geekhouse23
    I would do that first then install the netting. Love mine.
    jbv1030[QUOTED] and Sdtrueblue like this.
  8. Mar 1, 2016 at 3:10 PM
    #248
    MTNHABITOVERLAND
    I did one similar for my old Kia Sorento. Just really didn't want to do it again - so many mistakes cost me more $$ than I budgeted for.
    Thanks for the info!
  9. Mar 1, 2016 at 3:53 PM
    #249
    Sdtrueblue
    Sdtrueblue Well-Known Member
    Markie B
    San Diego, CA
    2015 DCLB Sport
    6112’s/5160’s Snugtop Rebel NTG’s 265/70/17
    I copied a version of geekhouse23's setup, but instead of installing the net, I hung carabiners from several of the bolts that hold the track down.
    Then, I use the carabiners to hang various items from the roof on the inside of my cap.
  10. Mar 1, 2016 at 3:55 PM
    #250
    geekhouse23
    I have small drings that hang down from 6 track nuts and bolts and then the betting is clipped to those drings
  11. Mar 1, 2016 at 4:31 PM
    #251
    jbv1030
    La Verne CA
    okay, solid advice.
    just trying to figure out how to do this...without a roof rack...damn
  12. Mar 1, 2016 at 11:56 PM
    #252
    HalfWayThere
    HalfWayThere Well-Known Member
    SLO, CA
    2016 DCSB TRDOR 4x4
    Without through-bolting, I can't think of a good way to make an attachment. I suppose you could cut back the carpet and then glass a mounting point to the fiberglass, but what a PITA. My shell came from the factory with fishing rod holders attached to the ceiling. They used sheet metal screws and they some of them just fell out once they were a little loose. In the honeycomb area of the SnugTop, there's just not much meat and everyplace else is too thin for screws (unless you drill all the way through, but ugh!). So really, you want rack tracks to make it all work clean.
    I have Yakima tracks on mine from the factory, but they only through-bolted the three center mounting holes on each rail. The outer ends are riveted and the mounting hole in between is not used. That's different than my previous shell, which was the exact same model but was returned because it was not built with the reinforced roof like I ordered. That one had all the bolts on each side. So, I'm not sure what gives. I also don't see how I would slide on a mounting point if the end caps are riveted on. There are 4 sliding nuts on each side, so I guess I would be forced to use those. I've never had this type of roof rack and I haven't researched it, so maybe there's an obvious answer once I get to that point and start investigating.
    jbv1030[QUOTED] likes this.
  13. Mar 2, 2016 at 5:23 AM
    #253
    kpe
    kpe New Member
    Jax Beach, FL
    2014 Mag Grey TRD Sport DCSB 4x4
    ARE Z-Series Shell; Weathertech; Panavise/Ram GPS Mount
    Where did you get the netting for your topper? Was it already built to fit or did you have to Macgyver it yourself?
    Thanks!
  14. Mar 2, 2016 at 5:35 AM
    #254
    kpe
    kpe New Member
    Jax Beach, FL
    At present, groundwater sampling equipment. Looking forward to taking advantage of this cooler weather and try camping with the new shell! :oldglory:
  15. Mar 2, 2016 at 6:24 AM
    #255
    huntark03
    huntark03 I'd rather be hunting!
    Maumelle, AR
    2005 Limited Tundra DC 4X4
    Spidertrax Wheel Spacers aFe Pro Dry Drop in Air Filter Weathertech Liners Bilstein 5100s w/ OME 885 coils and ToyTec 1.5" AALs Light Racing UCAs
    Who do you work for? I'm a hydrotech with the USGS in arkansas.
    Crom likes this.
  16. Mar 3, 2016 at 5:36 AM
    #256
    kpe
    kpe New Member
    Jax Beach, FL
    Very cool! I work for a small environmental consulting firm in Jacksonville, FL.
    huntark03[QUOTED] and Crom like this.
  17. Mar 3, 2016 at 6:48 PM
    #257
    Jfunkysax
    Jfunkysax Well-Known Member
    Jay
    08 DCSBPR RED AS HELL
    Bilstein 5100's all around, Old man emu leaf springs, Volant cold air, body armor rear bumper with swing arm, Goodyear Wrangler Duratrack 255/70R18, Rockstar rims, EBC slotted rotors and green stuff brake pads, roll top bed cover.
  18. Mar 4, 2016 at 10:39 AM
    #258
    bluewaters182
    bluewaters182 Well-Known Member
    Greg
    Ohio
    2019 4runner TRD premium
    Weathertech Mats, Leer 180 Cap, Icon 2.5 coilovers w/700lb springs, Icon UCA, fox 2.0 remote resi 10" travel rear shocks, nitro 4.56 gears, carrier bearing drop, Level 8 guardian rims 16 x 8.5, 315/75/16 Cooper ST Maxx, satoshi grill, shorty antenna, BHLM, color matched eyelids, rear diff breather relocated, exhaust chop, mudflap delete, debadged, All Pro front bumper powder coated white, smittybilt x2o 8 comp winch, SOS sliders, illumination supply 30" single row led bar, uniden 880 CB w/2' firestick on relentless fab hood mount, full AllPro skids, AllPro expo leaf springs, AllPro U bolt flip, Ultraguage, interior LEDs , trimmed fenders and flares 2", AP ext brake lines, CMC, fire wall massage, pelfreybilt battery box, diehard group 31 battery, Kragen 7" HID, homemade HiLift mount, Yaesu ft-8900, Ellis precision AT shifter, EBC yellowstuff & sport rotors, PIAA 510 fogs, Safari snorkel
  19. Mar 4, 2016 at 10:45 AM
    #259
    omaguz
    omaguz Well-Known Member
    Omar
    Puerto Rico
    2016 4Runner Trail Edition, NON KDSS, Pirelli Scorpion's ATR 265/70/17 E Load, Canvas Back, BROG Built Roof Attic, Thule Roof Rack and a few other stuff!!!
  20. Mar 4, 2016 at 10:46 AM
    #260
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    Thanks for your post. Can you tell me how you attached that aluminum bracket in the corner of your shell? Thanks!
    faw3 likes this.
