Show me what's in your camper shell!
Discussion in 'Tonneau Covers, Caps and Shells' started by whitetaco02, Apr 20, 2014.
  1. Apr 21, 2014 at 6:17 PM
    whitetaco02
    whitetaco02 [OP] Well-Known Member
    Frank
    GA
    09 Tacoma 4x4
    Tinted windows, stainless steel drop hitch, rear TSB, Marathon seat covers in Realtree AP camo, low profile chrome toolbox, husky liners front and back, debadged
    Keep them coming guys and gals. I am pumped about getting my cover!
  2. Apr 21, 2014 at 7:26 PM
    snorola
    snorola Well-Known Member
    Brett
    Canmore Alberta
    06 4x4 Dbl Cab
    SAW 2.0 Coilovers Eibach 14" 650lb springs Camburg UCA's All pro expo springs OME rear shocks All pro front bumper All pro IFS skid All pro sliders SCS f5 matt black rims Lightforce blitz 240's
    the bolts that hold my shell on go through the shelf to hold it in place.
  3. Apr 21, 2014 at 7:29 PM
    Blueitrgsr
    Blueitrgsr Well-Known Member
    Brad
    Gainesville, Fl
    2006 Reg Cab 4wd
    Some bilsteins, OME 885's, and an AAL.
    Damn what led lights are you using back there. Those things look bright as shit.
  4. Apr 24, 2014 at 3:20 PM
    whitetaco02
    Frank
    GA
    09 Tacoma 4x4
    Your sleeping platform is what I plan on doing as well. Looks great!
  5. Apr 28, 2014 at 6:59 PM
    smokefan86
    smokefan86 Member
    Josh
    FL
    '13 TRD Sport Long Bed
    Here is a platform I did for my 2013 DCLB this last weekend. My goal was a camping set up that could sleep my wife and I (she hates tents). At 57"x73", it will accommodate a double size air mattress. I opted for two of Cabelas foam mattresses (30x72x3) cause I'm not a fan of air mattresses. They are a bit big, but crunch up to pad the sides of the bed which is actually nice, and are the perfect length. They stow in a full ceiling gear net, and a 2 person canvas sleeping bag and a couple pillows fit perfectly in the drivers front compartment. The passenger front compartment is for a future marine deep cell battery/inverter install. The drivers rear is for camping gear, and the passenger rear is for tools and recovery gear.
    I don't have it re-enforced in the back (there is a cut out you can see to accommodate a 1"x6" cross board, we come in at less than 160Lbs each, but if you weigh much more than that you will need to install one). I used one 1/2" sheet of ply wood (high quality A/B Grade for hardness), and two 2"x10"x8' untreated timbers for the frame (11 1/2' total used, so you could use one 2"x10"x12', but it is actually more $ than 2 8 footers for the oversize lumber. $13 compared to 2x $6, plus you have 4' extra in case you mess something up). All the wood was cut, sanded, primed and painted satin black, the deck sheets were covered on the top with a plastic sheet of adhesive painters floor guard (after painting) to keep any water damage minimal, then topped with outdoor rated grey carpeting.
    Prices rounded up to nearest $ (April 2014):
    1x A/B Grade 1/2" sheet plywood: $40 Lowes
    6'x8' Roll grey outdoor carpet: $20 Lowes
    1x roll 21"x30' platic sheet: $10 Lowes
    2x 2"x10"x8' untreated lumber: $12 Lowes
    4x cans grey primer: $8 Ace
    4x cans fast dry black Rustoleum: $20 Ace
    4pc corner brace set 1"x1/2": $ 6 Ace
    4pc corner brace set 3"x1/2": $ 6 Ace
    4pc corner brace set 2"x5/8": $ 7 Ace
    TOTAL $129
    You can see by the pics the gist of the set up, I'd give measurements but they get real precise. You need to measure as you go piece by piece. For example; get your frame laid out, cut, check fit, sand/primer/paint, check fit, install with hardware, then measure for your panels one at a time. Take into account 1/16" per side for carpet thickness! And yes, this set up can be done with ONE 4'x8' piece of ply wood!
    Keep in mind, if you have a short bed (60") you will not be able to sleep 2 people, or fit much in the way of air mattresses or full length sleeping bags without rolling up some excess. One guy diagonally and a dog is about all you can hope for, but even then it does keep the bed organized well ;)
  6. Apr 28, 2014 at 7:05 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Nice job
  7. Apr 29, 2014 at 1:41 PM
    Echodawg
    Echodawg Well-Known Member
    Fremont, CA
    2014 TRD OR DCSB
    Stuff and Things!
    Here's what I keep in the back of mine, minus camping equipment.
  8. Apr 29, 2014 at 1:59 PM
    vicali
    vicali Touch my camera through the fence
    mike
    Kam,BC
    2017 TRD Sport 1D6
    Shovel, JackAll, Recovery/Ammo/Toolbox;
    Hamer95USA and ready6delta like this.
  9. Apr 29, 2014 at 2:05 PM
    TacoDeLaPlaya
    TacoDeLaPlaya Total Automotive Performance Sleeper Cell
    Bobby
    Del Mar, CA
    06 Silver Access cab
    Custom sotoshi deep dish grill 6112 front 5100 rear Leer 100xl
    What are the black boards on the driver side? Are those for putting under the tires when stuck?
  10. Apr 29, 2014 at 2:06 PM
    tomwilson74
    tomwilson74 Well-Known Member
    Tom
    West Virginia
    2020 TRD double cab OR
    OME 3” lift Mickey Thompson Classic III Wheels
    EchoDawg, what is strapped on the left side of the bed? By the way, your flag is backwards.
  11. Apr 29, 2014 at 2:20 PM
    Echodawg
    Fremont, CA
    2014 TRD OR DCSB
    Stuff and Things!
    They are TREDS for vehicle recovery. http://www.tred4x4.com/index.php/products
    Thanks for the info on the flag, never knew that about vertical displays, fixed. :)
  12. Apr 29, 2014 at 2:45 PM
    bluedegeon
    bluedegeon Well-Known Member
    Colorado Springs, CO
    2017 TRD OR ACLB 4WD
    Where did you get the gas and water can and mounts? I been looking into doing something similar.
  13. Apr 29, 2014 at 2:54 PM
    Tacoma VT
    Tacoma VT Well-Known Member
    R. Kessler
    Vermont
    10 DCLB TRD sport
    OME 884s, Bilstein 5100 Shocks, Icon 3 leaf progressive AAL (with overload in), Rear leaf TSB, ImMrYo mirror relocater, ARE Z series cap, Hi Lift jack W/ DIY mount, trimmed Mud Flaps, Devil Horns by Andres, EGR In-Channel rain guards, LED bed lights, Weather Techs
  14. Apr 29, 2014 at 3:10 PM
    OZ-T
    Peter North
    British Columbia
    They are Rotopax
  15. Apr 29, 2014 at 3:59 PM
    #35
    bluedegeon
    Awesome thanks
  16. Apr 29, 2014 at 4:26 PM
    #36
    sportnobadges
    sportnobadges Well-Known Member
    the great midwest
    '09 TRD SPORT SR5 4.0L V-6 TOW PKG DEBAGED
    de-badged / weather tech digital floor mats front and rear / weather tech in-channel vent visors / A.R.E. MX cap / bed mat / blacked out 4s
    Looking through the pics here I did not notice any "toppers/caps/shells" with lockable side opening windows. I have them on my 09 and they are handy as hell. Beats climbing up to the front of the box to get something small that is needed at anytime or whatever. Would highly recommend considering side windows that open when buying a 'topper/cap/shell'.
    TRZA and RobP62 like this.
  17. Apr 29, 2014 at 7:26 PM
    #37
    el taco loco
    el taco loco Well-Known Member
    USA
    '13 DCSB Sport 4X4 in 1E7
    It's a work in progress, but this is it as of a few days ago. Replaced the bungees with ratchets and added tie-downs to the large Action Packer in the back for lashing soft gear to the top.
    The final result:
  18. Apr 29, 2014 at 9:18 PM
    #38
    Gaunt596
    Gaunt596 Well-Known Member
    Matthew
    Central Maryland
    that slider is awesome, did you make it yourself?
    RobP62 likes this.
  19. Apr 30, 2014 at 2:56 AM
    #39
    Capita
    Capita Well-Known Member
    Corner Brook, Newfoundland, Canada
    09 TRD Sport Double Cab
    Got them on my cap. Being installed Friday :)
  20. Apr 30, 2014 at 11:09 AM
    #40
    el taco loco
    USA
    That is an ATC Original. www.atctruckcovers.com
