Show me what's in your camper shell!
Discussion in 'Tonneau Covers, Caps and Shells' started by whitetaco02, Apr 20, 2014.
  1. Feb 3, 2015 at 3:46 PM
    #141
    skygear
    skygear                    
    Shower components and then the platform/ drawer system if you don't mind.
  2. Feb 3, 2015 at 3:56 PM
    #142
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Holy shit , surgical room clean
    You guys ever haul anything in your trucks ?
    KeystoneGoodie likes this.
  3. Feb 4, 2015 at 8:21 AM
    #143
    bicyclist
    bicyclist Well-Known Member
    Just a heads up: when hanging the flag against a wall, it should be displayed with the field of stars to the left.
    I'm sure it's just an oversight. You obviously take pride in the way you do things. Clean truck.
    GeoTachnical likes this.
  4. Feb 4, 2015 at 6:33 PM
    #144
    tomwilson74
    tomwilson74 Well-Known Member
    Tom
    West Virginia
    2020 TRD double cab OR
    OME 3” lift Mickey Thompson Classic III Wheels
    It's called "flag etiquette". This is an old picture anyway, he probably has already fixed it. I am a disabled veteran and there plenty more vet's on this forum. I still have great respect for our flag.
  5. Feb 5, 2015 at 7:27 AM
    #145
    FixedGearMike
    FixedGearMike Well-Known Member
    Hotlanta
    13 TRD Taco OME 3 inch lift
    Leer camper
    Here is my super awesome sleeping/ storage platform. I was telling a guy at work about building one, so he offers to sell me his setup for 60 bucks!! I couldn't buy the materials for that much.
    So it's about 3 inches of foam, under the carpet which just happened to be a perfect color match for the shell. There are 6 storage compartments, with another really big space in the middle.
    The whole thing weighs about 50 pounds and can be removed in 5 minutes. I'm 6 2 and can comfortably sleep with my lady in the 6 ft bed.
  6. Feb 5, 2015 at 7:46 AM
    #146
    Guspuppy
    Guspuppy Well-Known Member
    Corinne
    western PA
    2010 RC base 4x4 stick
    This is sweet!!
  7. Feb 5, 2015 at 8:22 AM
    #147
    huntark03
    huntark03 I'd rather be hunting!
    Maumelle, AR
    2005 Limited Tundra DC 4X4
    Spidertrax Wheel Spacers aFe Pro Dry Drop in Air Filter Weathertech Liners Bilstein 5100s w/ OME 885 coils and ToyTec 1.5" AALs Light Racing UCAs
  8. Feb 6, 2015 at 8:28 PM
    #148
    badtoytrd
    badtoytrd Well-Known Member
    Brock
    Northern VA
    The easiest thing would to check out my post here: http://www.expeditionportal.com/forum/threads/127132-Tacoma-Sleep-Platform-and-Drawers-slow-build
    The basic list for the shower is:
    7 gallon tank with custom fittings from Pasticmart http://www.plastic-mart.com/product/...er-tank-rvb272
    1 gpm Shurflo pump http://www.shurflo.com/marine-produc...s/default.html
    Shower Port http://www.dyersonline.com/dandw-spr...pray-port.html
    Deck fittings http://www.go2marine.com/product/637...cap-nylon.html
    Misc hose and clamps
    The sleep platform is: 2 Adventure Trailers birch drawers with a lot of customization.
  9. Feb 6, 2015 at 11:19 PM
    #149
    plurpimpin
    plurpimpin Well-Known Member
    PDX
    2010 TRD Off Road 4x4
    +1
  10. Feb 7, 2015 at 5:46 AM
    #150
    teneighty
    teneighty I'd rather be skiing...
    Right behind you. NY
    18’ F150 SCREW LB 3.5 EcoBoost
    Bilstein 5100’s (x4), 275/65/20 Cooper XLT AT3’s
    Wow. Awesome!! Great deal
  11. Feb 7, 2015 at 8:50 AM
    #151
    skygear
    skygear                    
    you should put the link in your sig ;)
  12. Feb 11, 2015 at 12:21 AM
    #152
    Hilborn
    Hilborn Adventure First. Safety Second.
    Michael
    Utah
    2009 Tacoma DCLB TRD Sport 4x4
    ADD W1 Oil Catch Can. AFE Magnum FORCE Stage-2 Si Cold Air Intake System. AlphaRex Black Pro-Series Headlights w/ LASFit Bulbs. Anderson Engineering Solutions Manifold Spacer. ARK Splash Guards. AVS Door Sill Protectors. BAMF Bolt-On Rock Sliders. BAMF CMC Plates. BedRug. Brute Force HC Rear Bumper. C4 Engine Skid. C4 Transmission Skid. C4 Transfer Case Skid. C4 Fuel Tank Skid. C4 Rear Diff Skid. Cooper Discoverer ST Maxx LT285/70R-17. Dirt King Ball Joint Upper Control Arms. Dirt King Lower Control Arms. Dirt King Spindle Gussets. Doug Thorley Y-Pipe. DRT Fabrication Shackle Hanger Kit. Eaton Detroit Trutrac Rear Differential. ECGS Bushing. Expedition Essentials Bedside ARB Air Compressor Mount. Garmin Overlander GPS. Genesis Gen 3 Dual Battery System w/ G Screen. HCF Delete. Husky Floor Liners. Hypertech In-Line Speedometer Calibrator (@1.038). IGGY Switch Panel. Ironman4x4 Foam Cell Pro Struts and Shocks. KPOffroad Alignment Cam Upgrade Kit. Leer 100XQ. Magnaflow Overland Series Cat-Back Exhaust w/ 10416 Muffler. Method Vex Titanium 17x8.5. Yukon 4.56 Gears. Odyssey Performance Group 34 Batteries (2). OME 886x Coil Springs. OME Carrier Bearing Spacers. OME CS047R Dakar Leaf Springs w/ D29XL. Overland Torque Tune. Pakrax Tailgate Panel. Pinch Weld Mod. Pop n' Lock. Power Stop Z36 Truck and Tow Brake Pads. rcbs204 Illumited 4x4 Switch. Rear Differential Breather Relocation. Rexing V1 Dash Cam. Scanguage 2 w/ TFT. Stahlbus Oil Drain Plug. Stoptech Cryo-Treated Rotors. Sway Bar Delete. Total Chaos Bed Stiffeners. Toyota 70mm Throttle Body. ToyTec Axle Degree Shims. URD 170° Thermostat.* URD 65 to 70mm Throttle Body Adapter. URD Exhaust Cam Gears. USA Spec IPod Interface. Voltage Booster Pro. Wheeler's Brake Lines. Wheeler's Front SuperBumps with 3/8" Spacers. Wheeler's U-Bolt Flip Kit w/ SuperBumps.
  13. Feb 11, 2015 at 4:00 AM
    #153
    SpeedWagon
    SpeedWagon Member
    Where do you get the rubber mounts you're using to hold the shovel with?
  14. Feb 11, 2015 at 8:06 PM
    #154
    Scott B.
    Scott B. Well-Known Member
    Scott
    Georgia
    2015 ACLB SR5 4x4 Expo
    They are called "Quickfists". Do a search - they are available at many places, even Amazon.
  15. Feb 11, 2015 at 8:35 PM
    #155
    Shaggs
    Shaggs Well-Known Member
    NorCal
    2012 DoubleCab Long Bed 4x4 TRD Magnetic Gray
    I want that setup... it would give me a good excuse to get a shell. Almost exactly what I want in mine
  16. Feb 11, 2015 at 9:25 PM
    #156
    TravelinLight
    TravelinLight Well-Known Member
    Hayes
    Pensacola, FL
    Bilsteins on front and rear, OME 885 coils, Wheeler's AAL with overload left in, LR UCA's, Stock TRD 17" wheels, 255/75-17 BFG KM tires, VIPMOTOZ headlights, Lifetime LED headlight bulbs, 6000K LED Fog bulbs, Jumper's Interior and license plate LED's, Husky Classic floor mats, OEM bed mat, Leer100R truck shell with carpeted platform, de-badged, white derped grill emblem.
    By far my favorite thread on TW so far. I got in a rush and did the standard 2x8 slats with carpeted 3/8" plywood. I have a feeling I'll upgrade. I'm about to take on the challenge of carpeting the interior of my fiberglass cap. I'm going to use the thin carpet used for subwoofer boxes and I'm still deciding on the glue/adhesive to use if you have suggestions?
  17. Mar 8, 2015 at 7:37 PM
    #157
    NCTacoma
    NCTacoma Rather be in the mtns
    Caleb
    CLT, NC
    Sold- Searching for 1st gen
    Tons of ideas here. Glad I haven't started on my sleeping platform/bike rack/dog ramp/sliding tool drawer yet.:D:D
    badmotorfinger likes this.
  18. Mar 9, 2015 at 2:43 PM
    #158
    S13chris
    S13chris Well-Known Member
    Jacksonville nc
    07 dbl cab 4x4
    Tail gate mod, debadged, and weather techs, satoshi grill, diff breather mod, Duratracs 265/70/17, snugtop shell w/ rack, sleeping platform for bed, LED's for interior lights/Reverse lights/license plate, BHLM & DTRL Mod.
    When I was changing tail lights to led's. I had the back packed with all my work gear
    Crom and ready6delta like this.
  19. Jun 4, 2015 at 3:58 AM
    #159
    DrFunker
    DrFunker Well-Known Member
    @Goosedog - any write up on your drawer build? Thanks.
  20. Jun 4, 2015 at 11:55 AM
    #160
    Wandering
    Wandering Member
    Randy
    West Jordan, UT
    2015 Tacoma TRD Off-road
