Show me your driving lights !
Discussion in 'Lighting' started by Janster, Jul 3, 2008.
  1. Jul 3, 2008 at 8:15 AM
    Janster
    Janster [OP] Old & Forgetful
    Jandy
    Lancaster, PA
    Show me what you got in terms of driving lights!
    I've got the Aries pushbar and it needs some lights. I'm torn... I have a set of PIAA 520's on the Jeep that are pretty old but still look good and work very well. They've been cleaned up and painted many times. I've been talking about putting those on the truck - but my husband (the electrical guru) doesn't wanna mess with removing the wiring and installing them on the truck. Hell, they've been on & off about 3 different vehicles already.
    So.... the husband has been talking about getting me some new lights. Don't need anything special or as expensive as the 520's. Round.... no cheapies either.
    In terms of *lighting* - the Tacoma high beams are pretty damn good - bright and light up pretty far. I don't use them a whole lot. It'd be nice to have more ground cover where the taco lights aren't focused. I assume having driving lights on a bullbar (lower than headlights) - they can be directed more towards the ground? Thoughts? Or am I thinking in the wrong context?
  2. Jul 3, 2008 at 8:17 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    can't....post....fast....enough.... :D
  3. Jul 3, 2008 at 8:18 AM
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2011 DC TRD SPORT Prerunner
    3” spacer lift, 285/75/17 KO2, Spidertrax 1.25” spacers
    Here ya go Janster. IPF driving lights from Costco. I have heard good things about this same set of lights from the FJ guys. And if you have a problem with 'em, all you gotta do is return 'em to Costco.
  4. Jul 3, 2008 at 8:23 AM
    Ridgerunner
    Ridgerunner Well-Known Member
    Frank
    Rocklin, Ca.
    2001 prerunner doublecab limited
    2001 with; cat-back side-swept twin exhaust, elbow mod, Westin bullbar with Hella 450 driving lights, Snugtop XTR camper shell, TRD off-road 2x4-black beauty.
    Hella 550's. They would look great on your 2nd gen too as you have enough round curves (ON YER TRUCK):D to offset w/square lites
  5. Jul 3, 2008 at 8:29 AM
    pittim
    pittim mittip backwards
    Pennsyltucky
    Boujee Prius
    It’sa Lexus, boogie woogie woogie
    mjp2, i was thinking about putting like 4 lights in front of my grille like your truck has. does it make your truck run any hotter (because of the lights blocking airflow) with them there?
  6. Jul 3, 2008 at 8:32 AM
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    his probably runs hotter because of the ton of tubing he has to haul around.
  7. Jul 3, 2008 at 8:46 AM
    mjp2
    NJ
    Gas mileage is in the dumper due to extra weight but no problems with heat. :)
    The shop made sure there was plenty of openings for airflow when the bumper was built. The base for each light has dimple dies and the front skidplate has an opening to allow air to reach the bottom part of the radiator.
    Since the hole had to be cut anyway we used the race team logo as the template:
    Scangauge shows the water temp running at a consistent 190-195 degrees.
  8. Jul 3, 2008 at 9:14 AM
    kristopherl
    kristopherl AKA: Jake the Wolf
    Cincinnati, Ohio
    08 Tacoma DC 4x4 Sport LB. Foglight
    Cup holder LEDs, Black Max Tonau, BHL Mod, N-Fab side steps
    HOLY CRAP!!! anyone mistake you for a UFO at night :thumbsup:
    do you need 1.21 gigawatts to power those
  9. Jul 3, 2008 at 9:21 AM
    mjp2
    NJ
    Dual Optima Red Tops, and I don't turn on the stereo amplifier when the lights are on. :)
  10. Jul 3, 2008 at 11:08 AM
    Janster
    Jandy
    Lancaster, PA
    I'm speechless.... Very nice.. :D
    At what point did you decide to stop at 6? If you had more room, would have more on there? (laugh)
  11. Jul 3, 2008 at 11:10 AM
    Janster
    Jandy
    Lancaster, PA
    Nice and inexpensive - I like that. How's the beam?
  12. Jul 3, 2008 at 11:13 AM
    Janster
    Jandy
    Lancaster, PA
    Fixed it for ya... ;)
    The girls get that *deer in the headlights* kinda look when they see them.
  13. Jul 3, 2008 at 11:14 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    here ya go,janster.......hella 500's from pepboys.......good and bright, and not too expensive. i paid $70 for my set.
  14. Jul 3, 2008 at 12:08 PM
    tacoskim
    tacoskim Tuned By Gadget
    Los Angeles, CA
    09 TRD 4x4 Pyrite Mica
    Stock
  15. Jul 3, 2008 at 5:02 PM
    silver07taco
    silver07taco Well-Known Member
    COIL
    Maryland
    13 Tundra RCSB 5.7 4x4,07 Tacoma AC 4.0 4x4
    2013 Tundra RCSB 5.7 4x4, 2007 Tacoma AC 4.0 4x4
    Thoses are wetin lights, I had on a bull bar before I got the all pro bumper
  16. Jul 3, 2008 at 7:24 PM
    pittim
    Pennsyltucky
    Boujee Prius
    hm thats good. I plan on doing a similar setup to Toy4Life's...ie no lightbar or anything, just right into the bumper cover (with a support under the cover.) Another thing I have to figure out is how I'm going to hook up all 4 lights to power so that they'll all be able to be on at the same time and not cause anything in the truck to work abnormally.
  17. Jul 3, 2008 at 7:33 PM
    SocalMan22
    SocalMan22 Well-Known Member
    Steve-0
    So*Cal
    06 PreRunner Dbl Cab
    What Mods!
    Heres mine lit up at night i have hella 500 they are nice and bright or as they say hella bright.
  18. Jul 3, 2008 at 8:11 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    i just hold a maglight out the window :eek:
    totally not kidding
    i have these pieces of CRAP from walmart too...i needed something for a night run and didnt have $100 bucks to drop on a decent pair...so i spend like $35 total i think
    they suck...they wont stay put...theyre bright though :rolleyes: when i take the covers off
  19. Jul 3, 2008 at 8:13 PM
    rhoppas
    rhoppas Land of Oz
    Topeka, KS
    07 Double Cab V6 TRD Sport Tow
    Earnhardt Cannons, Terra Grapplers, Viper alarm, Hunter4x4 Bull Bar, 6" Pro Comp Off-Road lights, extra set of bed D-rings, Chrome exhaust tip, Metra Ipod/MP3 adapter, Garmin GPS, CarriageWorks grill, Maglite mounted to driver seat, 9" Stubbie Antenna, WeatherTech floor liners, Saddleman Neoprene seat covers, DeeZee bed mat
    Here are my ProComp 6" offroad lights. They have a narrower beam that shines a very long ways. I got them from a local 4x4 shop for $70/pair. The blue ring around them matches the Speedway Blue.
  20. Jul 3, 2008 at 8:25 PM
    SocalMan22
    Steve-0
    So*Cal
    What Mods!
    Yes pencil beam lights are awesome when your traveling fast at night in the desert they come in handy.
