Show me your sliders?!?! PLEASE!!!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by SR/PRO-TACO, Sep 20, 2020.
  1. Nov 21, 2020 at 8:35 AM
    #61
    plurby
    plurby Member
    2017 TRD OR DCSB
    I just ended up ordering a set of @Mobtown Offroad sliders as well as a front skid from them today. Went with the heavy-duty sliders, as I've been eyeing them for more than half a year now. Now that I'm reading the thread, though, I'm wondering what degree they're at. The website doesn't state it anymore, and I distinctly recall being able to select what angle you want. Dig the thread, though, love looking at builds.
    hotrodder636 and indoomitable like this.
  2. Nov 21, 2020 at 11:50 AM
    #62
    OZ TRD
    OZ TRD Well-Known Member
    Central Coast CA
    6sp Manual TRD PRO - Lunar Rock '21
    Evo A SmartCap, Cali Raised Sliders (0 degree), 2WD low Mod, Puddle Pods, 3 switch overhead panel, 8 slot middle console panel, Custom driver's switch panel, Rek Gens, 265 75 16 Falkens, lil B Bed Stiffeners, All new Speakers, Diff Breather, AC Drain, Many interior bits...
    @Travis727 @CaliRaisedLed - These are pretty good looking - very clean... For those of you familiar with these; Are they good for the weight of the Taco?
    I would expect light use from my end... nothing crazy. Just want the protection in case of a slip / slide onto something
  3. Nov 21, 2020 at 11:55 AM
    #63
    boston23
    boston23 Well-Known Member
    Adam
    Eastie
    2019 SR5 DCSB 4x4
    Mobtown overland sliders
  4. Nov 21, 2020 at 12:07 PM
    #64
    IndyTac
    IndyTac Well-Known Member
    Indianapolis
    2019 TRD OR DCSB w/JBL
    Total Chaos bed stiffeners CaliRaised bed tie-downs CaliRaised 0-degree, bolt-on rock sliders Meso Customs Gas Hole JDM console and dash organizer Ceramic front tint Ceramic windshield coating Ziebart underbody and rust proofing Taco Garage Dashtop Multi-Mount (DMM) Black SR5 Grille Surround Swap Tacos4cheap Grille Badge Redarc Tow Pro Liberty Brake Controller Car Solutions Anytime Camera Mod TacoMods Radio Knobs Desert Does It Seat Jackers
    CaliRaised 0 degree bolt-on with filler plates. Rhino everything. If I had to do it over, I’d powder coat the sliders and rhino the inserts only.
  5. Nov 21, 2020 at 12:08 PM
    #65
    plurby
    plurby Member
    2017 TRD OR DCSB
    Seems like most people opt for the 0-degree. Any reason aside from using them as steps?
  6. Nov 21, 2020 at 12:14 PM
    #66
    IndyTac
    Indianapolis
    Steps are why I went for the 0 degree. They’re basically frame-mounted steps, so I don’t have to worry about the flex of the rocker-mounted steps damaging the rocker over time. I know a guy who punched a hole in his rocker panel when he and his son stepped on his rocker-mounted steps at the same time to get into the truck (they’re both pretty big dudes). I also don’t do any serious off-roading since I live in the Midwest, so I don’t need the better clearance offered by the ones that hug the rocker more tightly.
  7. Nov 21, 2020 at 12:19 PM
    #67
    OZ TRD
    Central Coast CA
    @IndyTac - Can you elaborate on the revision of choice of Rhino vs Powdercoat? Most seem to say that the Rhino or line x is stronger / longer lasting... I am interested in your experience.
  8. Nov 21, 2020 at 12:25 PM
    #68
    IndyTac
    Indianapolis
    The Rhino is thicker and messed *slightly* with the alignment when I was trying to bolt them on. I had a slight variance in my frame, which lined up perfectly (in a bad way) with a slight variance in my slider. With the combination of the variances and the rhino, I couldn’t get the starter bolt in. I had to modify the slider slightly by grinding out a little bit of metal in the bolt hole. Once you cut the rhino, though, it starts to peel. Bc I was putting a bolt there, it didn’t really matter, bc the bolt would keep the rhino from peeling more, and I just covered the bare metal that exposed from grinding with a little bit of paint. Also, when you’re cranking down the bolts, the washers can slightly cut the rhino lining. I really like the rhino on the filler plates, but I think powdercoating the sliders themselves would’ve made things easier and better protected the sliders in the long term from rust. After I installed my sliders, I had my underbody coated (I know there’s a big debate on here about whether that helps or hurts), but I felt like that also sealed any cuts in the rhino. Otherwise, I considered getting a can of raptor liner or something and touching it up in spots.
  9. Nov 21, 2020 at 1:26 PM
    #69
    indoomitable
    indoomitable Baby-steppin' down the stairs
    Texas
    2018 OR 4x4 DCSB
    They're badass!! The angle is 20 degree and you can still use them as a step if want
  10. Nov 21, 2020 at 2:15 PM
    #70
    boston23
    Adam
    Eastie
    2019 SR5 DCSB 4x4
    In addition to using it as a step to access my (future) roof rack, i felt like the zero degree gave me more protection if i slide sideways into a tree from the ground surface being muddy slick clay.
    I’ve realized why most are angled up though. Better for rock crawling. If you drop down on a boulder the angled sliders will take the impact better than the zero degree which i imagine could bend.
    I’ve also found the zero degree are pretty useless as a step for getting in. I’d say if i could do it again id get c4 or demello sliders, with 20 or 25 degree. Not a huge fan of how mine bolt up.
    Make sure when buying you really pay attention to the mounting plates. Are they flat? Are they a right angle? That kind of thing
  11. Nov 21, 2020 at 2:15 PM
    #71
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Yea, that's how I feel too. :amen:
    Interbeing[QUOTED] likes this.
  12. Nov 22, 2020 at 7:53 AM
    #72
    Interbeing
    Interbeing A Canadian living in Texas
    Austin, TX
    2020 Tacoma TRD Off-Road 4x4 DCSB AT
    TRD Pro suspension with Headstrong 3 Leaf AAL, DV8 OR front slimline bumper & Engine Skid Plate, RCI OR high clearance bumper, CaliRaised Trail Edition Sliders, Spidertrax 1.25" Wheel Spacers, 265/75 16 GY Duratracs, wrapped the OEM wheels, OR Roof Rack, Extang Exceed Hard top Tri fold tonneau.
    CaliRaisedLED Trail Bolt Ons, $552 OTD, went on easy, very solid, and I’m very satisfied.
  13. Nov 22, 2020 at 8:38 AM
    #73
    mnmsddy
    mnmsddy Well-Known Member
    portland, or suburbs
    2018 White Tacoma TRD Offroad
    Not Sliders in the traditional sense, but these beasts will take a beating, Frame mounted and rock solid. I think a swat team could ride on them.
    Manufactured by a local guy here in the Portland, OR area.
    If you look closely behind the front flair, you will see where someone creased the fender with a car mirror, the sliders kept them off of the rest of the truck. Just buffed off the tire marks on the steps.
    CrazyAirborne likes this.
  14. Nov 22, 2020 at 8:50 AM
    #74
    su.b.rat
    su.b.rat broken truck
    SDHQ chromemolys 5°, save me 50lbs from HREW or DOM sliders. total with hardware about 99 lbs.
  15. Nov 22, 2020 at 9:43 AM
    #75
    Alberta_Taco
    Alberta_Taco Well-Known Member
    Aaron
    2016 Black Taco TRD Sport
    1st Mod: installed Trifecta tri-fold tonneau cover 2nd Mods: removed air foil damper, decals and badges 3rd Mod: installed a Compustar remote starter (its Alberta people) 4th Mod: installed full set skid plates 5th Mod: installed rock rails Spring 2021: roof rack w/ LED bar & CB radio Summer 2021: hybrid bumper, winch & LED bar
    Hey CAC, what did you use for finishing your rock rails? I just received a set of bare metal rock rails. I'm starting to look at the numerous possibilities for finishing: Sandblasting & paint, Sandblasting & powder coat, Just paint, or other.
    Curious as to what you chose and why?
    thanks
    AB_Taco
  16. Nov 22, 2020 at 9:45 AM
    #76
    Alberta_Taco
    Aaron
    Hey Boston23, what did you use for finishing your rock rails? I just received a set of bare metal rock rails. I'm starting to look at the numerous possibilities for finishing: Sandblasting & paint, Sandblasting & powder coat, Just paint, or other.
    thanks
    AB_Taco
  17. Nov 22, 2020 at 12:38 PM
    #77
    CocaineAndCreatine
    CocaineAndCreatine Strong in arm and weak in head
    Portland, Oregon
    2018 Beige DCSB OR
    SCS F5s
    I did two coats of flat black Rustoleum. They’re going to get damaged anyway, so something easy to touch up is a must.
  18. Nov 22, 2020 at 3:12 PM
    #78
    Interbeing
    Austin, TX
    I lightly sanded with 500 Grid Sandpaper, then cleaned thoroughly with Acetone. I wore gloves to avoid any skin oils to compromise the surface. Once dry, I did three coats of Etching Primer, then five coats of Rustoleum Mat Black enamel, I let dry for about 12 hours then installed them on my truck. After installation, I touched up where I had some scratches. It turned out very good, and I am happy with the results. Time will tell how well it holds up.
    cmacblue42 likes this.
  19. Nov 22, 2020 at 3:25 PM
    #79
    j-utah
    j-utah Well-Known Member
    2024 Tundra SR5 Air Suspension
    RCI’s. They are OK. Rusting a little bit underneath. Will need to address that. The rust is tied to the top plate being added. When they did that, it makes it hard for primer and powder coat to get into the crevices. This is where I am getting rust already. Maybe it’s just what happens.
    Kolter45 and Taco_Craig like this.
  20. Nov 22, 2020 at 5:12 PM
    #80
    Alberta_Taco
    Aaron
    thanks. Yeah. I was thinking something similar for that same reason. Appreciate the info
