Show off your aux fuse panels.
Discussion in 'Lighting' started by Newlife, Dec 29, 2013.
  1. Dec 29, 2013 at 8:33 PM
    Newlife
    Newlife [OP] Well-Known Member
    Adam
    Knoxville TN
    2020 t4r orp
    Bone f’n stock for now
    Since there's so many threads about it why not compile them and if someone likes one that person can contact the person that made it. So let's see them.
    Blue sea 5025 panel
    Bussman 100amp breaker
    0 gauge wire
    Powering hids
    4 Off road lights
    adding three led bars
    12v constant hot power
    And possible cb
  2. Jan 3, 2014 at 2:07 PM
    Newlife
    Adam
    Knoxville TN
    2020 t4r orp
    Well this was a fail
    Mully, CowboyTaco, Snaeper and 8 others like this.
  3. Jan 4, 2014 at 8:33 AM
    Tunngavik
    Tunngavik Well-Known Member
    Alberta, Canada
    2018 TRD Off-Road Access Cab 6 speed manual
    KC-HiLites Fog Lamps, Kicker speaker and tweeter upgrade, USB in center console, Power tailgate lock, Soundproofing, 32" lightbar
    LOL. :D I've started threads like that before.
    I am putting together an aux fuse/relay box but it's going to take a few weeks before I get all the parts. I want to power my heated seats, heated side mirror and fog lights off of it.
    I actually found a Bussman automotive fuse/relay box off of Mouser.ca for cheaper than I can get a Blue Sea fuse box. Will look a lot better too as it's all enclosed in one, as opposed to the Blue Sea which would still force you to have a bunch of unsightly wires, going to and from the relays, on the outside of the box.
  4. Jan 4, 2014 at 8:36 AM
    Poolstick
    Poolstick Well-Known Member
    I was thinking about trying to buy one some where, but am struggling to find anyone who makes one for the 2nd gen 6 speed (clutch cylinder thingy gets in the way).
    I may just end up making one out of lexan, but I don't have the heat gun to bend it and I'd almost rather just pay someone to do the work for me as far as that goes.
  5. Jan 4, 2014 at 8:42 AM
    Newlife
    Adam
    Knoxville TN
    2020 t4r orp
    Man just get creative. It's honestly easy once you have an idea.
  6. Jan 4, 2014 at 8:47 AM
    acdronin
    acdronin Well-Known Member
    Two pairs of Hellas in the front
    Two pairs of KC's in the back
    LED lighting in the grill
    LED lights inside the shell
    12v power bus feed for switches inside cab
    TacoSurfer27 and TACOZAC like this.
  7. Jan 4, 2014 at 7:11 PM
    Ryan DCFS
    Ryan DCFS Elevator guy
    East Bay Area
    09 DC long bed TRD silver streak
    Sounds like a busman RTMR... I'm currently working on a similar project.
    Stryker420 likes this.
  8. Jan 4, 2014 at 7:26 PM
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
  9. Jan 4, 2014 at 10:24 PM
    Ryan DCFS
    East Bay Area
  10. Jan 4, 2014 at 10:34 PM
    Newlife
    Adam
    Knoxville TN
    2020 t4r orp
    So where do you plan on mounting all of your grounds as well as your relay grounds?
    My blue sea has a negative bus built in,
    dirt clod likes this.
  11. Jan 4, 2014 at 11:03 PM
    Ryan DCFS
    East Bay Area
    The RTMR can be ordered bussed, partially bussed, or not bussed. I'm probably going to get the partially bussed (10 fuses bussed, 5 relays not bussed) and I'll have the relay coils externally jumped/bussed together to a ground lug.
    My grounds for accessories will depend on location, and I'll probably run a negative bus into the cab for lighted switches.
  12. Jan 4, 2014 at 11:11 PM
    Tunngavik
    Alberta, Canada
    Thanks for the info. Can you confirm that is the relay you use for the panel?
  13. Jan 4, 2014 at 11:33 PM
    Ryan DCFS
    East Bay Area
  14. Jan 4, 2014 at 11:36 PM
    Yotamac
    Yotamac Well-Known Member Vendor
    Ze
    562- Cerritos, CA
    07 PreRunner
    Stuff, stuff and more stuff
    BarcelonaTom67 and Pirhett like this.
  15. Jan 4, 2014 at 11:53 PM
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Friedtacolover likes this.
  16. Jan 5, 2014 at 1:26 AM
    Ryan DCFS
    East Bay Area
    It's 35A switched, 20A continuous. It's dpst, so it's rated for 20A through the NC coil-cold circuit, 35A through the NO coil-hot (switched on) circuit.
  17. Jan 5, 2014 at 8:32 AM
    Tunngavik
    Alberta, Canada
  18. Jan 5, 2014 at 10:12 AM
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Switched rating is the maximum in-rush current the contacts can handle, typically when turning on inductive loads such as motors. This rating is only momentary. (less than one second) Continuous rating is the maximum current the relay can handle once the contact remains in its desired state.
    for resistive loads such as lighting, you don't have to worry about the switching current rating, only the continuous. Both the Normally Closed and the Normally Open contacts are rated the same.
    ahkouchi and Stryker420 like this.
  19. Jan 5, 2014 at 12:34 PM
    Ryan DCFS
    East Bay Area
    http://www.waytekwire.com/datasheet/75725.pdf
    This data sheet shows two different current ratings for the normally open circuit and the normally closed circuit.
    (Kinda into semantics now, because I'm going to use the SPST, 35A micro relays.)
  20. Jan 5, 2014 at 12:44 PM
    Ryan DCFS
    East Bay Area
