Show off your aux fuse panels.
Discussion in 'Lighting' started by Newlife, Dec 29, 2013.
  1. Aug 23, 2017 at 5:31 AM
    #341
    lynyrd3
    Bill
    East Central Upstate NY
    Ordering up a Blue Sea auxiliary fuse block and breaker this week !
  2. Aug 23, 2017 at 8:01 AM
    #342
    2BeersPlease
    2BeersPlease Well-Known Member
    If you like DIY stuff, you can do what I did: 6-channel wireless controller. Works great for auxiliary lighting. I like being able to turn lights on/off when I'm not in the cab. The relays are 10 amp, so you're limited in that respect. However, you could still use it to trigger higher amperage relays.
    I don't have a detailed thread, but I'd be happy to share what I did.
  3. Aug 23, 2017 at 8:06 AM
    #343
    CO_0321er
    CO_0321er Well-Known Member
    2017 TRD OR
    palfrey standard fuse panel
    blue sea fuse block
    blue sea 100a breaker
    powering bed lights, side lights on my roof rack, bumper lights, and air compressor.
    NOTE: I am a novice at electrical work. if you are nervous about doing any of this, shoot me a PM and ill help you out. I have an in depth wiring map I can send you that makes all as easy as building legos.
  4. Aug 23, 2017 at 7:25 PM
    #344
    yonah
    yonah Well-Known Member
    Calling-in from east of the Rockies
    @TheDrMaSuess - Thanks brother. It's been a fun ongoing project.
  5. Aug 23, 2017 at 7:31 PM
    #345
    Radarninja
    Radarninja Safety 3rd
    Northern California
    06 taco
    Chromed out radiator cap
    I'll admit it. This is my main fuse panel. If you look closely you'll see @916TacoTruck
    Stryker420, lynyrd3, VE7OSR and 2 others like this.
  6. Aug 23, 2017 at 10:20 PM
    #346
    outxider
    outxider Never stop exploring. Rest in Paradise Big Bro.
    Sang
    East Bay, CA
    06 DCSB 4x4
    A few mods here and there and counting....
    In progress....
  7. Aug 24, 2017 at 1:07 PM
    #347
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    Simple resistive loads will draw less current at 12V than at 13.6V. Output current regulated devices such as power inverters or led boost regulators will draw more current as the input voltage drops. Wires need to be sized sufficiently greater than the maximum current the device can draw so there's headroom to fit the fuse value safely in between. You don't want to be constantly replacing 10A fuses for a 10A load nor risking an engine bay fire by using 10A rated wire for that 10A load.
  8. Aug 26, 2017 at 10:58 AM
    #348
    famous187
    famous187 Active Member
    looks good. who made your plate?
  9. Aug 26, 2017 at 12:42 PM
    #349
    paranoid56
    paranoid56 Well-Known Member
    San Diego
    14 double cab taco
  10. Aug 26, 2017 at 12:48 PM
    #350
    LadyRed
    LadyRed Making all the right wrong turns
    Leah
    Florida/Mississippi
    2016 4x4 TRD OR DCSB
    OME Lift Total Chaos UCA SCS Ray 10s
    Would you want to make me a set? How much?
  11. Aug 27, 2017 at 8:48 PM
    #351
    outxider
    Sang
    East Bay, CA
    06 DCSB 4x4
    More progress. Mocked up and loosely bolted down. Paint it black or leave it raw aluminum? :cool:
    robssol likes this.
  12. Aug 27, 2017 at 10:07 PM
    #352
    bagleboy
    Scott
    Norcal, Santa Rosa
    What color is the engine bay?
  13. Aug 28, 2017 at 8:22 AM
    #353
    outxider
    Sang
    East Bay, CA
    06 DCSB 4x4
    Silver. Should have this mounted sometime next week.
  14. Aug 28, 2017 at 6:53 PM
    #354
    bagleboy
    Scott
    Norcal, Santa Rosa
    I guess you could go either way then.
  15. Aug 28, 2017 at 7:03 PM
    #355
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Heres my setup. Looks like a lot of wires, but thats because theres a lot going on.. northstar 31M battery, 100w renogy solar panel on top of the shell, Blue solar MPPT charge controller, 1000w pure sine inverter, and blue sea 12 circuit fuse block all routed to this central circuit board. Dual battery is mounted on a custom built receiver hitch battery box
    GC8Steve and Hawco636 like this.
  16. Aug 30, 2017 at 4:09 AM
    #356
    clc clc
    clc clc Well-Known Member
    PA
    2012 4x4 reg cab tacoma/2020 subaru crosstrek
    Slowly making progress on my fuse block. My friend has been helping me out. I couldn't do it without him!
    robssol likes this.
  17. Aug 30, 2017 at 4:35 PM
    #357
    robssol
    robssol If it ain't broke, leave it the eff alone!
    Rob
    S. Wisconsin
    06 Tacoma, TRD Sport, SR5, 4X4, AC
    Totaled but still alive! Frame 2.0, Fog lights anytime, Seatbelt reminder delete, Secondary air filter delete, LED bed lights, Running boards, 2017 Rims, Ultra gauge, Cup holder/consol/glove compartment lights, Interior LED conversion, Blue Sea aux. fuse panel, fuse panel mounting plate by Yotamac, ProEFX heated towing mirrors, LED engine bay lights, Redline Quicklift Elite hood struts, Wet Okole Heated Seat Covers,m, Rear bumper 2.0, Decal free visors, Washable cabin air filter, Overhead consol auto dimming override switch, BulletProof Fabricating Skid plate, 2lo module.
    OK, so what are you showing us here?:notsure:
  18. Aug 30, 2017 at 7:14 PM
    #358
    samiam
    samiam Always here, never there
    Sam
    Stinky Vegas
    2008 TRD OR DCSB 4.0 6MT 1E7 Alu Cab
    Workin' on Workin' on it
    Looks like a homemade fuse panel made from lexan and heatgun.
  19. Aug 30, 2017 at 7:31 PM
    #359
    Slickrick0999
    Slickrick0999 Well-Known Member
    Rick
    2010 SR5 4x4 dblcab shorty
    Fixed console button Cabinet lock on panel under seat 2016 wheels
    Did someone have a setup for sale in here?
  20. Aug 30, 2017 at 8:31 PM
    #360
    malburg114
    malburg114 Well-Known Member
    Las Vegas, NV
    2001 Toyota Tacoma TRD
    Don't really have the time or want to make one so just want to buy something. Looking for an alternative to a Spod or switch pro etc. Saw the Apollointech one on Amazon and was considering that for the price (https://www.amazon.com/Apollointech...ead-6-Switch/dp/B01CDTW03K/ref=cm_wl_huc_item ) or Rough country has one for 200 bucks as well. (http://www.roughcountry.com/mlc6-multiple-light-controller-70962.html ) So mainly looking for any feed back on the 2 or if anyone on here makes a similar setup for close to the price.
    I can make my own bracket but just want something with switches that are wired and all I need to do is hook up to the battery and hook my lights, etc. to it.
