Show off your aux fuse panels.
Discussion in 'Lighting' started by Newlife, Dec 29, 2013.
  1. Jan 17, 2014 at 10:08 AM
    llibrm
    llibrm OH NOOOOOO!
    Bill
    Winthrop, WA &Convection Oven, AZ
    06 DCSB, 06 LC120 (sold)
    Pelfreybilt Aluminum Bumper, KING 2.5 on all four corners, 4x4 illuminated switch, Cobra 75 w/ 3' Firestick, 2M/ 70cm Radio w/ Diamond NR770HB, Pelfreybilt bed bar, Lightforce Stiker 170s, BD 20" OnX6, BD S2 ditch lites on SDHQ mounts, BD SAE Fogs
    What is the bolt size for the two mounting holes on the inner fender?
    Thanks
  2. Jan 17, 2014 at 10:11 AM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    Just got my relay/fuse block. Not sure when I'll install it.
    This thing looks awesomely built and I can't wait to put it to use!
    You have the power and ground wire coming from the box, as well as one extra wire that can be used as a 12 volt source to power your switches.
    DSC_0002 (4) by PcBuilder14, on Flickr
    These are the five sets of wires for each relay. The bigger wire is the one you connect to your accessory. The smaller wire is the control wire that you connect to your switch.
    DSC_0004 (4) by PcBuilder14, on Flickr
    Each relay has a 30amp fuse. The 15amp fuse is for that extra wire that you can use for the switches 12 volt source. The other 4 blank fuse holders can be used for any non-relayed device such as a cb radio.
    DSC_0006 (3) by PcBuilder14, on Flickr
    Here you can see the extra wire, it's blurry, but it's there haha
    DSC_0007 (4) by PcBuilder14, on Flickr
    Once you've seen all of that, this should look pretty understandable to you. The green blanks that are between each red wire are used for the 4 extra blank fuse space on the box.
    DSC_0009 (4) by PcBuilder14, on Flickr
  3. Jan 17, 2014 at 10:32 AM
    tri2hunt
    tri2hunt Well-Known Member
    Micah
    Moscow, Idaho
    2012 DCSB 4x4
    ^^^^ Can you please let me know where you got this??
    I really want to get the same thing...
    Thank you very much!!
  4. Jan 17, 2014 at 10:50 AM
    PcBuilder14
    Brent
    Nor Cal
  5. Jan 17, 2014 at 11:01 AM
    Manwithoutaplan
    ID
    Arctic Taco likes this.
  6. Jan 17, 2014 at 11:19 AM
    tri2hunt
    Micah
    Moscow, Idaho
    2012 DCSB 4x4
  7. Jan 19, 2014 at 9:43 AM
    12thmanhawkfan
    12thmanhawkfan Well-Known Member
    Robby
    Bellingham, WA
    Access Cab 6-speed
    It's got some Mods
    Here's mine. Blue sea fuse block on a home made mount protected by an 80 amp Maxi fuse.
    TacoSurfer27 likes this.
  8. Jan 19, 2014 at 4:55 PM
    lawless
    lawless the rent is too damn high
    Lawson
    San Jose, CA
    2012 dcsb mgm sc
    ready to wire up bed lights, hood lights, led bar, rock lights, and rear lights.
    hopwheels, CRW and Stryker420 like this.
  9. Feb 12, 2014 at 10:36 AM
    paranoid56
    paranoid56 Well-Known Member
    San Diego
    14 double cab taco
    heres mine. also using the bussmann stup.
    Yossarian likes this.
  10. Feb 12, 2014 at 12:56 PM
    penguins_cc
    penguins_cc Well-Known Member
    Will
    Bellevue, WA
    Timberland Mica Limo!
    Perkins Performance Sliders, Warn 9000, Brute Force Fab front & rear bumper, OME/Dakar lift, full ATO skids and hi-lift mount, satoshi, Wet Okoles, illuminated 4x4 switch, Diff Breather.
    Has anybody installed an aux fuse panel inside the cab? Been looking around but don't see any such examples...
  11. Feb 12, 2014 at 1:59 PM
    JustinL
    JustinL Well-Known Member
    Justin
    Berlin, CT
    2009 TRD OffRoad DCSB Pyrite Mica
    2012 Conversion
    There's someone that put his Blue Sea under the center console. Is have to search to find it. Give me a min.
  12. Feb 12, 2014 at 2:13 PM
    abarber11
    abarber11 Well-Known Member
    ATX
    2011 DCSB
    Mines in the cab behind the rear driver side passenger seat in a DCSB. Its hooked up to my aux battery that also lives behind that seat. Recently put a 100amp bussman circuit breaker in the place of that small in-line fuse so it looks a little different now.
    Kopasz, CRW, stealthmode and 2 others like this.
  13. Feb 12, 2014 at 2:29 PM
    penguins_cc
    Will
    Bellevue, WA
    Fantastic, thanks Alex. That's where I was thinking of installing mine, with an aux group 31 battery installed in my toolbox.
    The center console sounds like it has potential, but I have a Console Vault so I am still curious to see an example of where it was installed.
  14. Feb 12, 2014 at 2:54 PM
    JustinL
    Justin
    Berlin, CT
    2012 Conversion
    Will this is the one I saw
    Username Pepe98
    Slashaar and Pirhett like this.
  15. Feb 12, 2014 at 3:16 PM
    #35
    penguins_cc
    Will
    Bellevue, WA
    Thanks Justin! That's a pretty tight fit and it would be kind of difficult checking/replacing fuses. I'm thinking I'll explore the back seat option further. Thanks again guys :)
  16. Feb 12, 2014 at 3:25 PM
    #36
    SMKYTXN
    SMKYTXN If it can't be overdone it's not worth doing Vendor
    Nathan
    Houston
    11, 4dr, TRD Sport, 6sp
    DCFB
    ARC 8000
    stealthmode, Arctic Taco and Slashaar like this.
  17. Feb 15, 2014 at 9:43 PM
    #37
    BBell
    BBell Well-Known Member
    B
    Northwest
    13 Tacoma TX
    2013 Tacoma TX 4.0 6 Speed Manual Volant CAI and air scoop Volant throttle body spacer DigiFit Weathertech Kevlar Seat Covers - Grey Interior LEDs Fab Fours PreRunner Bumper Body Armor Rock Sliders Painted radiator Rigid Industries 3x3 D2's DTL lighting kit Rigid Grill and 20" SLR2 light bar Plasti- badges Plasti- front grille surround Plasti- rear bumper MATT black rear taillights Night Raider rear LED light bar :D
    No, it's a big help to us newbies with grandious ideas. Where did you find you hardware and did you build a step by step thread on this install?
    I've purchased some of my lighting, and working up the funds for additional, but I was sitting here thiking last night "I can't splice!! WTF do I need to do!?" And BAM Tacomaworld. Thanks man.
  18. Feb 15, 2014 at 10:42 PM
    #38
    JustinL
    Justin
    Berlin, CT
    2012 Conversion
  19. Feb 15, 2014 at 10:55 PM
    #39
    VanCity4x
    VanCity4x Well-Known Member
    AB
    05 Tacoma
    3link on tons
    Blue sea 12
    Stinger 100a breaker
    6 12v relays
    4ga wire to battery
    10ga wire to relays/lights
    9be9a92d894099266630e51d64c9121b_zps94ce_d04f8381e45938ee640cf00e76cb57df52cb5d66.jpg
    ba54b629832462270aa8d339ed8bc628_zps05f5_6795b065b7425022fbeb8cd099f7f5e505ae6166.jpg
    Relays are mounted on bottom side, under the fusebox. Did a few designs and this was the most functional for me. Relay terminals are easy to access but still hidden and securely mounted.
  20. Apr 24, 2014 at 8:37 PM
    #40
    Carrionman
    Carrionman Well-Known Member
    James
    Eastern NC
    2013 4x4 v6
    well shit I thought I was the only one to think of stashing the blue sea 12 back there :)
