Show off your aux fuse panels.
Discussion in 'Lighting' started by Newlife, Dec 29, 2013.
  1. Dec 24, 2017 at 10:24 AM
    #461
    Friedtacolover
    Friedtacolover Well-Known Member
    Travis
    Ontario, Ca
    2017 DCSB Off Road 4x4
    my build tread: https://www.tacomaworld.com/threads/socal-no-shame-poser-build.513084/
    Thanks. My relays for light harness etc are all full size can they be swapped for the minis?
    destin_meeks likes this.
  2. Dec 24, 2017 at 10:33 AM
    #462
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
  3. Dec 24, 2017 at 12:03 PM
    #463
    Sub_Par
    Sub_Par Well-Known Member
    Buffalo NY
    2011 TRD Off Road
    I’m using this box, I did have to use two busbars. One for power and one for all grounds, then they go straight the chassis ground and battery power. It’s a tight fit with the lower cover on, and I had to drill holes for some wires to come out the bottom. Over I’m happy with it for what it costs. Also @paranoid56 made me a custom plate for it with a cutout to mount it where everyone’s mounting their bussman.
    Friedtacolover likes this.
  4. Dec 29, 2017 at 7:24 PM
    #464
    inthebed
    inthebed Well-Known Member
    2010 Tacoma TRD Off-Road Prerunner
  5. Dec 29, 2017 at 8:57 PM
    #465
    Sub_Par
    Buffalo NY
    2011 TRD Off Road
    Is the whole thing only rated for 30 amps? That would work for some low draw led’s but not much else.
  6. Dec 30, 2017 at 12:52 AM
    #466
    robssol
    robssol If it ain't broke, leave it the eff alone!
    Rob
    S. Wisconsin
    06 Tacoma, TRD Sport, SR5, 4X4, AC
    Totaled but still alive! Frame 2.0, Fog lights anytime, Seatbelt reminder delete, Secondary air filter delete, LED bed lights, Running boards, 2017 Rims, Ultra gauge, Cup holder/consol/glove compartment lights, Interior LED conversion, Blue Sea aux. fuse panel, fuse panel mounting plate by Yotamac, ProEFX heated towing mirrors, LED engine bay lights, Redline Quicklift Elite hood struts, Wet Okole Heated Seat Covers,m, Rear bumper 2.0, Decal free visors, Washable cabin air filter, Overhead consol auto dimming override switch, BulletProof Fabricating Skid plate, 2lo module.
  7. Dec 30, 2017 at 4:10 PM
    #467
    bkrdave36
    bkrdave36 Well-Known Member
    Dave
    Wittmann,AZ
    06 Prerunner Double Cab Black
    Front OME Springs, Upper Control Arms, Icon Stage 3 Rear Leaf Springs, Durobump bump stops,Bilstein 5125 shocks, BFG All Terrain KO2 Tires, Avid Light bar and step rails, Victory 4x4 bed rack with Tepui Ayer Rooftop Tent, Anytime Fog light mod, Outside Air Temp Gauge mod, ImMrYo Rearview Mirror mod, Chinese Knockoff LED lights, Body Armor 4x4 Offroad Swingout rear tire carrier and bumper, Victory 4x4 Bed Stiffeners, Rattle can Custom Camo paint stripe, Truxedo Lo Pro tonneau cover, various Blue Ridge Overland Gear storage solutions in cab, thats it so far .... to be continued!
    Stupid question ... at what point should I consider a second battery?
  8. Dec 30, 2017 at 9:12 PM
    #468
    inthebed
    Apparently you can jump yourself off if you have two...
  9. Dec 30, 2017 at 11:00 PM
    #469
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    pretty sure this is not a common bus bar, rather individual connections. Each connection is rated upto 30A. Ensure that all the strands of wire make it into the terminal, yet are not stripped too long as to reveal bare wire.
    This is more what you would be looking for as distribution. https://www.waytekwire.com/item/78260B/Blue-Sea-Systems-2722-DualBus-Plus-BusBar/
  10. Dec 31, 2017 at 3:19 AM
    #470
    robssol
    Rob
    S. Wisconsin
    When you get a winch.
  11. Dec 31, 2017 at 8:21 AM
    #471
    bagleboy
    Scott
    Norcal, Santa Rosa
    When you need it for power when you're parked.
  12. Jan 1, 2018 at 2:15 PM
    #472
    famous187
    famous187 Active Member
    @paranoid56 , hey man are you setup to make the 2nd gen blank plates with ATRAC cutout now? Thanks
  13. Jan 1, 2018 at 2:25 PM
    #473
    paranoid56
    paranoid56 Well-Known Member
    San Diego
    14 double cab taco
    I am cutting one out today for a person to try out, will post up to see how it goes.
  14. Jan 3, 2018 at 3:29 AM
    #474
    inthebed
    I can't seem to find a cooper bussmann that accepts bosche relays and regular size fuses. Any ideas where I might find one?
  15. Jan 19, 2018 at 9:59 AM
    #475
    SIZZLE
    SIZZLE Pro-party
    Novato, CA
    2014 DCSB TRD Off Road
    A little a this, a little a that...
    What kind of soldering gun/pen do you guys recommend for these types of projects? Thanks
  16. Jan 19, 2018 at 10:05 AM
    #476
    Sub_Par
    Buffalo NY
    2011 TRD Off Road
    It’s usually best to use crimp connectors of some sort. Solder can break from vibrations. I used weatherpack connectors on everything for ease of use.
    SIZZLE[QUOTED] likes this.
  17. Jan 19, 2018 at 10:17 AM
    #477
    outxider
    outxider Never stop exploring. Rest in Paradise Big Bro.
    Sang
    East Bay, CA
    06 DCSB 4x4
    A few mods here and there and counting....
    Agreed. Crimp connectors and heat shrink tubing is all you need.
    Stryker420 and SIZZLE like this.
  18. Jan 19, 2018 at 10:26 AM
    #478
    SIZZLE
    SIZZLE Pro-party
    Novato, CA
    Cool. Thanks guys.
  19. Jan 19, 2018 at 11:02 AM
    #479
    Sub_Par
    Buffalo NY
    2011 TRD Off Road
    No problem. It’s kind of fitting that your avatar picture is of astronauts, considering NASA does not allow any solder on spaceships.
  20. Jan 19, 2018 at 12:25 PM
    #480
    SIZZLE
    SIZZLE Pro-party
    Novato, CA
    Being Toyota guys, I just figured you'd solder and crimp.
