Show off your aux fuse panels.
Discussion in 'Lighting' started by Newlife, Dec 29, 2013.
  1. Jan 29, 2018 at 2:22 PM
    #521
    2016Tacoman
    2016Tacoman Well-Known Member
    J
    2016 Tacoma 4x4 V6 Metallic
    Nice work.
  2. Jan 29, 2018 at 2:27 PM
    #522
    L J
    L J Well-Known Member
    Illinois
    07 4X4 SR5 TRD Sport DCLB
    Thanks!
  3. Feb 18, 2018 at 7:12 PM
    #523
    Justanotherhemi
    Justanotherhemi Space Cowboy/Ninja
    Rick James
    Area 52 (because area 51 was full)
    Intelligent Life Exists
    Sub’d for future use
  4. Feb 18, 2018 at 7:35 PM
    #524
    Justanotherhemi
    Rick James
    @BravesTaco95
    Here you go Adam. Plenty of info to read through
    BravesRunner likes this.
  5. Feb 18, 2018 at 7:50 PM
    #525
    BravesRunner
    BravesRunner “Exploration is curiosity put into action”
    Adam
    SC
    2021 GMC Sierra 1500 Denali
    Grandpa steps//Tri-fold Tonneau bed cover
    Sub’d
    Justanotherhemi likes this.
  6. Feb 19, 2018 at 8:39 AM
    #526
    BravesRunner
    Adam
    SC
    What size connectors are y’all using to connect to the fuse block? 3/8”? 5/16”?
    Also I assume most are using a 2-4 AWG wire from the battery?
    robssol likes this.
  7. Feb 19, 2018 at 12:43 PM
    #527
    robssol
    robssol If it ain't broke, leave it the eff alone!
    Rob
    S. Wisconsin
    06 Tacoma, TRD Sport, SR5, 4X4, AC
    Totaled but still alive! Frame 2.0, Fog lights anytime, Seatbelt reminder delete, Secondary air filter delete, LED bed lights, Running boards, 2017 Rims, Ultra gauge, Cup holder/consol/glove compartment lights, Interior LED conversion, Blue Sea aux. fuse panel, fuse panel mounting plate by Yotamac, ProEFX heated towing mirrors, LED engine bay lights, Redline Quicklift Elite hood struts, Wet Okole Heated Seat Covers,m, Rear bumper 2.0, Decal free visors, Washable cabin air filter, Overhead consol auto dimming override switch, BulletProof Fabricating Skid plate, 2lo module.
    Biggest connector that will fit correctly in the fuse block. Use the 2.
  8. Mar 2, 2018 at 2:45 PM
    #528
    Friedtacolover
    Friedtacolover Well-Known Member
    Travis
    Ontario, Ca
    2017 DCSB Off Road 4x4
    my build tread: https://www.tacomaworld.com/threads/socal-no-shame-poser-build.513084/
  9. Mar 5, 2018 at 12:35 AM
    #529
    Kirbstomp1287
    Kirbstomp1287 @MilSpecTaco
    17’ Inferno SR5 V6 DCSB XP
    Here are a couple of Diagrams I drew up for how I'm planning to set mine up. Shows both the fuse box and switch panel. I plan on using the 6 Fuse Blue Sea Fuse Box with Grounds. Let me know if anything is out of place! Hope this can help some people as well.
    EZ Harley and Friedtacolover like this.
  10. Mar 5, 2018 at 12:41 AM
    #530
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
  11. Mar 5, 2018 at 1:54 PM
    #531
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    Just a reminder that if you just ground accessories to the chassis then it's a good idea to upgrade the chassis ground strap on the battery.
    lynyrd3 likes this.
  12. Mar 9, 2018 at 12:47 PM
    #532
    TheTacomaInn
    TheTacomaInn Well-Known Member
    Rob
    Littleton, CO
    17 OR Access Cab, OME 887,HD Dakars, 285s
    Is there a benefit to having the relays in some sort of water/dust proof enclosure? I don't understand why there would be a benefit since the blue sea fuse block is not water proof. Have any of you that are running them open in engine bay had any issues? I originally wanted to mount them on the bottom side of my tray.
    Also, I am looking for relays that come with the wiring plugs to make wiring cleaner. All the relays I find are rated to 30 amps but only have 12 gauge load wires. Based on the blue sea wire size chart, 12 gauge can't handle 30 amps regardless of the length. Am i missing something here?
  13. Mar 9, 2018 at 1:19 PM
    #533
    paranoid56
    paranoid56 Well-Known Member
    San Diego
    14 double cab taco
    water does get into the engine bay when driving in rain, huge puddles, water crossings, so any exposed relays is always good to have a seal on them. I have had a few fail with water issues.
    as for the 30amp relays yes, should have 10ga at min, but most people dont run them at a full 30amps. I would say all of my 30amp relays only need to handle 10amps from led lights.
  14. Mar 9, 2018 at 1:32 PM
    #534
    Friedtacolover
    Travis
    Ontario, Ca
    If thats the case then why does a standard led lightbar harness rated for 300 watt that come with 30amp fuses come with 14g wire. They would be sued time and time again for electrical fires if they were under rated. Your fine. Just get the waterproof ones on Amazon and screw them to bottom of panel nicely then shrinkwrap ur connections or get waterproof connectors
  15. Mar 9, 2018 at 8:19 PM
    #535
    hammertaco11
    hammertaco11 Well-Known Member
    East Bay, Ca
    2014 Tacoma SR5 Pyrite Mica
    OME lift w/ HD Dakars Pro Comp 17" 7069 BFG KO2 275/70
    I asked this in my own thread, but wanna try my luck here, is there a way to have my aux fuse panel come on when my truck comes on and not 'always on'?
  16. Mar 9, 2018 at 8:38 PM
    #536
    bagleboy
    Scott
    Norcal, Santa Rosa
    You can have relays activated by ignition only powered switches. Or you could power the fuse box with an ignition only activated solenoid which acts like a big whopper relay. Like relays, solenoids use power themselves when in use though.
    robssol likes this.
  17. Mar 9, 2018 at 11:15 PM
    #537
    Kirbstomp1287
  18. Apr 26, 2018 at 11:02 AM
    #538
    Badderup
    Badderup Well-Known Member
    Colby
    Utah
    2006 SWB TRD sport DCLB
    I'm assuming you put your relays on the underside? You didn't happen to take any pics did you? I just got one of the panels from Paranoid and I'm just brainstorming how I want it laid out.
  19. Apr 26, 2018 at 11:19 AM
    #539
    outxider
    outxider Never stop exploring. Rest in Paradise Big Bro.
    Sang
    East Bay, CA
    06 DCSB 4x4
    A few mods here and there and counting....
    Yeah they're bolted underneath to the series of bolts in front of the kicker fuse holder.
  20. Apr 26, 2018 at 10:09 PM
    #540
    bagleboy
    Scott
    Norcal, Santa Rosa
    Middle piece is a center console bracket for a 6-way mini fuse panel. It will get power from the cig lighter plugs which will in turn be converted to always powered status fused directly from the bussman. A5ADC683-A495-4C6E-8BED-BD6C71101420_zps_cb75cb13acc89decf4398667dc360e14b2fcf429.jpg There are some extra 8mm tapped holes under th center console. The bracket gets captured by one of these at the back and the passenger side E-brake bolt at the front. Its also drilled to mount my oba manifold(two air outs[gage & regulator], relief valve, pressure switch, and shrader valve for aux CO2/air back up fills).
