Show off your aux fuse panels.
Discussion in 'Lighting' started by Newlife, Dec 29, 2013.
  1. Jun 16, 2018 at 7:48 AM
    #581
    Lugnut42
    Lugnut42 Active Member
    Ontario
    2016 DCLB-TRDSport
    LUND 5" Steele Oval SideSteps
    I get it scott. Thank you sir. My search continues. I'll let ya'll know how I make out....
  2. Jun 16, 2018 at 7:48 AM
    #582
    Lugnut42
    Ontario
    2016 DCLB-TRDSport
    Cool Jason. Thanks.!
  3. Jul 6, 2018 at 6:49 AM
    #583
    mrjoshyman
    mrjoshyman Well-Known Member
    Josh
    For those of you running your aux fuse panel off of the auxillary dual battery, can you show the location of where you protected the fuse box with either 100 A fuse of circuit breaker? Matt from OGE recommended it be no more than 8-12 inches from the battery. Since the circuit breaker comes to be mounted and that seems like a more popular option I'm curious how y'all have been doing that...
  4. Jul 6, 2018 at 7:11 AM
    #584
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Nothing that fancy, not running air compressor, not running dual batteries and only 1 set of lights running off it right now...............(pic is before lights hooked up)
    Cool_Calm_B, lynyrd3 and robssol like this.
  5. Jul 11, 2018 at 10:50 AM
    #585
    ZRXDean
    ZRXDean Well-Known Member
    Langhorne PA
    DCLB - Pabst Metallic
    OME 885, Billstein 5100, Deaver 2" AAL, ARE CX Cap, Go Rhino Dominator steps
    I'm gathering the parts to build me one of these - does anyone use a a solenoid between the circuit breaker and the aux fuse box? The idea being that I would wire the solenoid to switch on with the keyed power and thus control power to the aux fuse box and accessories. Something like this:https://www.amazon.com/dp/B00BGTL9G...&pd_rd_r=c2532d76-8532-11e8-9f96-9391f60fc1b0
    Stryker420 likes this.
  6. Jul 11, 2018 at 12:06 PM
    #586
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    I think most people just use an ign keyed trigger wire for the relays instead of a solenoid for the whole fuse panel.
    Yossarian likes this.
  7. Jul 11, 2018 at 12:11 PM
    #587
    ZRXDean
    Langhorne PA
    So run the power for the switches to a switched source in the cab fuse box and then run the switch to the relay? I'm a newb at this and there's clearly some parts I'm not getting!
    Essentially if the switch doesn't have power then it can't trip the relay - eliminating the risk of leaving something on when I turn the truck off?
  8. Jul 11, 2018 at 9:20 PM
    #588
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    Exactly. There are things that I want to be able to run without ignition on and those get powered straight from the rtmr.
  9. Jul 12, 2018 at 4:28 AM
    #589
    ZRXDean
    Langhorne PA
    Makes sense - thanks. If I run the entire aux box with a solenoid I'd lose the ability to run anything without the truck being on.... Thanks!
  10. Jul 14, 2018 at 2:17 AM
    #590
    inthebed
    inthebed Well-Known Member
    2010 Tacoma TRD Off-Road Prerunner
    It's not needed because the relays you'll find will have an option to turn them on/off with the ignition if you wire them properly.
  11. Jul 14, 2018 at 8:28 AM
    #591
    paranoid56
    paranoid56 Well-Known Member
    San Diego
    14 double cab taco
    it will depends on what his end goal is. if he doesnt want any of that aux fuse box powered when the car is off then he will need a high powered relay. I dont think i would use a old school solenoid, as they make some nicer ones.
  12. Jul 14, 2018 at 8:37 AM
    #592
    ZRXDean
    Langhorne PA
    I think I want the option to run stuff while the truck is off - on board air maybe - roof rack lights. I would want driving/bumper lights switched though.
  13. Jul 14, 2018 at 8:38 AM
    #593
    paranoid56
    San Diego
    14 double cab taco
    then he is right, just run the wire (short wire) from the battery to the circuit breaker to your fuse block. from there you will setup your relays and allow them to be triggered if the car is on or off
    ZRXDean[QUOTED] likes this.
  14. Jul 14, 2018 at 11:24 AM
    #594
    bagleboy
    Scott
    Norcal, Santa Rosa
    Since I want to have power ports that are always hot I'll be using the 12v socket line to feed a separate aux fuse box that's ignition only for low power items so I don't need a fuse tap. It's located under the cup holders in my 5m. I removed the clips and filed down the rear tab to make it easier to pull out but it still snaps in securely enough. I like that spot as you don't need to be a contortionist to access it or see it.1305942E-8EA9-45BF-B3AB-49C1F13CD6E1_zps_a264a21ddd5cf306ebd74728dba67a18afc28dcd.jpg
    Skada and Papadave418 like this.
  15. Jul 14, 2018 at 11:34 AM
    #595
    Doogz
    Doogz Well-Known Member
    Bryce
    Western MA
    2009 MGM AC
    yep..
    Some nice setups here.
    Still need to wire up another panel in the bed cubby.
    E-Paz 732NJ, lynyrd3 and VE7OSR like this.
  16. Jul 18, 2018 at 9:24 AM
    #596
    HawaiianSON
    HawaiianSON Blood makes the grass grow, OORAH!
    Nasty
    San Diego by way of HILO, HI
    2015 white DCLB
    Kustom54lighting /bruteofrce/brushed BRONZE
  17. Jul 18, 2018 at 9:27 AM
    #597
    HawaiianSON
    Nasty
    2015 white DCLB
  18. Jul 23, 2018 at 7:01 PM
    #598
    m603holden
    m603holden @Koditten Pirate Radio member #063
    Marteeen
    New England
    2017 Tacoma DCSB OR MT
    Lots of sail boat fuel
    Just double checking to make sure I have this right. I've got a pelfrey aux fuse plate, blue sea fuse box and am adding a breaker. The breaker gets rated for the maxium the box can handle correct? Which the one I have is the 2 banks of 6 circuits rated at 30amp / circuit.
  19. Jul 23, 2018 at 7:11 PM
    #599
    bagleboy
    Scott
    Norcal, Santa Rosa
    Yes, the breaker is for the fuse box but not for the sum of all the 30A circuits it can hold. Each box has a max amp rating, that's the rating the breaker should have. The Bussman rtmr is 80A and one of the Blue Seas models is 100A.
    rob1208 and m603holden[QUOTED] like this.
  20. Jul 26, 2018 at 10:26 AM
    #600
    ZRXDean
    Langhorne PA
    Just about done. Have to make the 4awg ground and positive cables and connect them but overall happy so far. Thanks to ALL for the inspiration, ideas and help!
    Anyone know the bolt size to mount the panel to the fender well?
    1F3F1DF1-69D1-4288-AD9D-0472CB53F3CE.jpg E1E29648-9419-4D92-9B8B-865550778F92.jpg
