Show off your aux fuse panels.
Discussion in 'Lighting' started by Newlife, Dec 29, 2013.
  1. Apr 27, 2020 at 3:21 PM
    #1161
    Dan8906
    Dan8906 Well-Known Member
    Daniel
    Concord, California
    2004 Tacoma ext cab TRD 4x4
    CBI sliders, ADS extend travel with compression adjuster coil overs, 9” Bilstein 5125 rear shocks, Icon Tubular UCA, Alcan custom leafs, All Pro Apex bumper and skids, NWTI rear diy bumper, 295/70/17 Cooper St Maxxs and nitro 4.88s.
    Thanks. Been avoiding the hardware stores cause they have been limiting access which results in waiting in lines outside but maybe I’ll run over to ace and see what they have
    shane100700[QUOTED] likes this.
  2. Apr 27, 2020 at 4:09 PM
    #1162
    Badderup
    Badderup Well-Known Member
    Colby
    Utah
    2006 SWB TRD sport DCLB
    Harbor freight has a good variety pack too
  3. Apr 27, 2020 at 5:13 PM
    #1163
    shane100700
    shane100700 Bed, Bath & Beyond Crawler
    Montana
    2019 DCSB, OR
    Rocket Boosters
    Good suggestion! HF is across town, and Ace is right down the road, so I forget about them for little things.
    JKU3000 likes this.
  4. Apr 28, 2020 at 4:47 AM
    #1164
    HappyGilmore
    HappyGilmore LambTek Innovations
    Huntsville, AL
    2013 SC’d DCSB TRD OR 4x4 | 2012 Lexus IS-F
    Yes
    I got mine from McMaster
    shane100700 likes this.
  5. Apr 28, 2020 at 10:19 AM
    #1165
    ryfox0276
    ryfox0276 Well-Known Member
    Montana
    2013 RC 4x4
    Almost done building my panel. Doing it "the right way" this time. 10 relay circuits, 8 extra fused circuits (5 switched with key on, 3 always on), and my dual battery solenoid and fuse. Plenty of room for growth. Just waiting on a few more parts so I can install it and run all my wires.
    IMG_20200428_110838.jpg IMG_20200428_110850.jpg IMG_20200428_110834.jpg IMG_20200428_110811.jpg
  6. Apr 28, 2020 at 3:18 PM
    #1166
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    Is your ground buss cable the same gauge as your B+ cable? Looks like you have two positives and one is much bigger than the ground buss cable. If you’re planning on grounding to the chassis then you’ll need to upgrade the chassis to B- cable to handle all the current that you’re adding.
  7. Apr 28, 2020 at 3:36 PM
    #1167
    ryfox0276
    Montana
    2013 RC 4x4
    Yes, the positive and ground cable for the fuse panel are both the same size (4awg) the large red cable is for my second battery system. The ground cable for this system is not involved on the fuse panel.
    There is a lot going on on this panel and hard to really see everything from the photos
  8. Apr 30, 2020 at 8:59 AM
    #1168
    bagleboy
    Scott
    Norcal, Santa Rosa
    Sounds like you have it covered.
    ryfox0276[QUOTED] likes this.
  9. Apr 30, 2020 at 11:55 AM
    #1169
    Hyland33
    Hyland33 Well-Known Member
    Andrew
    Leicester, MA
    2015 Tacoma TRD Offroad
    Just put in a setup from Overland Equipped yesterday.
  10. May 3, 2020 at 3:47 PM
    #1170
    dustxking
    dustxking Well-Known Member
    I am about to do mine as well! Did you run any buss bars or relays?
    Dan8906 likes this.
  11. May 3, 2020 at 5:38 PM
    #1171
    Hyland33
    Andrew
    Leicester, MA
    Nope, I only have one relay which is on the harness for my light bar. The install was just connecting the battery to the breaker, putting the ground on the fender, and then moving my CB, bed lights, and light bar wiring to the fuse block.
  12. May 4, 2020 at 3:14 PM
    #1172
    seuss
    seuss Well-Known Member
    DFW, TX
    Big Bad Bertha
    ARB Front bumper with winch, arb front locker, king 2.5 coil overs, 35's
    Damn I should've seen this thread before buying my fusebox.
  13. May 6, 2020 at 7:40 AM
    #1173
    TacoInTacoma
    TacoInTacoma Well-Known Member
    Tyler
    Tacoma, WA
    2019 Tacoma Off-Road/Super White
    I got this from www.TacomaPros.com
    oni06 likes this.
  14. May 6, 2020 at 8:01 AM
    #1174
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    Currently assembling my aux panel. Just waiting for a few waterproof connections, wires/ cables, and the circuit breakers since the pandemic made even getting nuts and bolts difficult to get a hold of :cookiemonster:
    ST Blade Split Bus Fuse Block, 100A and 150A circuit breakers for an easier way to add in a second battery on the passenger side
    panel bed is from my Dad's old table saw extension wings.
    Taco-Obsessed likes this.
  15. May 10, 2020 at 4:18 PM
    #1175
    JeffBoyardee
    JeffBoyardee Well-Known Member
    Jeff
    Seminole, FL
    2011 TRD Off-Road Tacoma DCSB
  16. May 11, 2020 at 7:42 AM
    #1176
    paranoid56
    paranoid56 Well-Known Member
    San Diego
    14 double cab taco
  17. May 21, 2020 at 10:22 AM
    #1177
    dubktrd
    dubktrd Well-Known Member
    Wichita Kansas
    Just installed Overland Equipped. Quality product highly recommend . Wire already built for you.20200521_121442.jpg
  18. May 21, 2020 at 2:16 PM
    #1178
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    should do an update;
    Blue Seas fuse box panel is in and the Negative is all wired up with about a 2 ft length of 1/0
    Positive terminals and positive connections (for the relays) will go in once i get my circuit breakers. Still in the midsts of shipping for the last 3 weeks...
    :bananadead:
  19. May 21, 2020 at 5:05 PM
    #1179
    srspicer
    srspicer Paint it black
    Lower Bucks PA.
    05' Black DBLC short bed
    Painting things black
    That looks nice! $200 is not unreasonable either.
    dubktrd[QUOTED] likes this.
  20. May 21, 2020 at 5:14 PM
    #1180
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    that is an incredibly good price... Especially knowing that the fuse block is around $60 and the switch (depending where you get it) at about the same price.
    all the others i've seen start $4-500...
    shane100700 and dubktrd like this.
