Show off your aux fuse panels.
Discussion in 'Lighting' started by Newlife, Dec 29, 2013.
  1. Oct 24, 2022 at 9:01 AM
    #1661
    TheTacomaInn
    TheTacomaInn Well-Known Member
    Rob
    Littleton, CO
    17 OR Access Cab, OME 887,HD Dakars, 285s
    I did the same thing and honestly it wasn't that bad. The aluminum street signs bend fairly easily. I started my bends by hand and then used a rubber mallet to get a crisper bend.
  2. Oct 24, 2022 at 12:17 PM
    #1662
    helix66
    helix66 Well-Known Member
    DPRC
    2017 DclB TRDor MgM
    ProGrille,MesoStuff,Tinted,AllPro sliders, RCI ALL skids, BAMF diff skid, KDmaxPro tune, Demello bumper, Warn evo10s, BD s8 & squadrons, Accutune UCAs, Fox 2.5pes, Eibach & Deaver
    I have an aluminum shelf from an equipment rack, I’ll have to give it a try.
    Nazupag524 likes this.
  3. Oct 24, 2022 at 12:33 PM
    #1663
    Nazupag524
    Nazupag524 Well-Known Member
    Jeremy
    Elizabeth, CO
    07 DCSB 4x4
    Heavy ass pig sitting on 35s
    It's not bad at all. I use a large dead blow hammer.
    helix66[QUOTED] and skeletron like this.
  4. Oct 24, 2022 at 1:24 PM
    #1664
    JERBEAR69
    JERBEAR69 Member
    @Nazupag524 - where did you get the street sign? I was trying like hell to get one for a project on my truck but came up snake-eyes every place I looked.
  5. Oct 24, 2022 at 1:40 PM
    #1665
    dpele
    dpele Pele Prints Vendor
    Dan
    Edmonton, Alberta
    2010 Tacoma DCSB
    Elka 2.0 w/ OME Dakars, 285/70/R17 Duratracs, & more!
    Did you "buy" these at your local street corner?
    helix66 likes this.
  6. Oct 24, 2022 at 3:42 PM
    #1666
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    Cheap aluminum baking pans also work(real ones, not the disposable kind). And you can preserve the ends/corners to maintain a gusseted ell.
    TheTacomaInn, dpele, srspicer and 2 others like this.
  7. Oct 24, 2022 at 4:16 PM
    #1667
    Nazupag524
    Jeremy
    Elizabeth, CO
    07 DCSB 4x4
    I’m a lineman so whenever we replace a pole I take one. If you’re local Colorado I’d give you one. I’ve got plenty.
    Taco-Obsessed and helix66 like this.
  8. Oct 26, 2022 at 8:28 AM
    #1668
    TheTacomaInn
    Rob
    Littleton, CO
    The complex I was living in at the time was replacing some signs so I grabbed one out of the trash. I think you can buy blanks online for a reasonable price.
    dpele[QUOTED] likes this.
  9. Oct 26, 2022 at 5:12 PM
    #1669
    SigBoy
    SigBoy Well-Known Member
    2020 TRD Off-Road, Access Cab
    I didn't have the right vice either until I went and bought one. 1/8" aluminum sheet and bent by hand with the vice. That thickness is about all I can do without cutting relief cuts where I want it to bend.
  10. Nov 13, 2022 at 5:44 PM
    #1670
    switch
    switch Well-Known Member
    Norther California
    2022 Tacoma Access Cab
    Wow! Nice work!!
    demo243[QUOTED] likes this.
  11. Nov 18, 2022 at 8:18 PM
    #1671
    matthewjw5
    matthewjw5 New Member
    So for the low voltage cut off device you have here. Will the ground (negative) on the love voltage cut off device serve as the ground for all the devices i have being powered through the fuse box?
    I guess my question is what is the best way to ground all of the relays in the true mod fuse box?
  12. Nov 19, 2022 at 12:08 AM
    #1672
    switch
    Norther California
    I used the factory ground point by the battery. It’s less than two feet away.
  13. Nov 19, 2022 at 8:25 AM
    #1673
    matthewjw5
    Gotcha. And so every fuse has to be ground separately that way correct?
  14. Nov 22, 2022 at 8:39 PM
    #1674
    GBourne
    GBourne Just a regular guy
    Grant
    Surprise, AZ.
    23 Ram 1500 Classic
    Dumped the Tacoma, that's all it needed.
    ...Huh..?
    All powers run to ground...
    So, fuses that go to ground end up being tested fuses (burnt, popped, dead...)
    Each fuse POWERS a load (positive wire to the light/air compressor/seat vibrator/whatever) and the load is grounded on the other side (the negative wire on the light/air compressor/seat vibrator/whatever)
  15. Nov 22, 2022 at 9:04 PM
    #1675
    twhalm
    twhalm Well-Known Member
    Denver, CO
    2015 TRD/OR Manual, OME , Dual battery
    Fuses don't power loads they protect loads.
    If I understand, your question and the OP it looks like since the fusebox used does not have a grounding bus (or a ground in general) they plan to ground whatever lights/accessories they power on the vehicle frame where it is convenient instead of running a ground all of the way back to the box.
  16. Nov 22, 2022 at 9:33 PM
    #1676
    GBourne
    Grant
    Surprise, AZ.
    23 Ram 1500 Classic
    well, yes, fuses indeed protect loads. Fully correct, and I should have worded my reply that way.
    Each fuse protects the load it supplies power to from the fuse block.
    As for grounding individually or grouped, that’s all situational/preference. Im not going to run a ground all the way across the vehicle to a common/main ground when there are better options. Makes no sense, causes more work, and costs more.
  17. Nov 22, 2022 at 9:56 PM
    #1677
    bagleboy
    Scott
    Norcal, Santa Rosa
    Except in cases of high individual loads with dedicated circuits I prefer to place ground busses strategically with one in the engine bay with my 80A Bussman panel, one in the cab with an 8-way fuse panel, and another in the bed with yet another fuse panel. This gives me the benefit of reliable grounding for all accessories, shortens wire runs, and reduces the number of wires into and out of the cab. Set ups and priorities vary, model your set up according to what suits you best.
    VE7OSR and RCRcer like this.
  18. Dec 14, 2022 at 10:20 PM
    #1678
    MGMDesertTaco
    Hey, I just sent you message through Etsy when you have a moment. I need to order another circuit breaker mount if possible please. :oops: I managed to accidentally snap the circuit breaker mount tab off while trying to pull the assembly away from the master cylinder/brake lines. It appears to be rubbing, but I noticed a buyer on Etsy used a piece of rubber hose zipped tied over the line. Thanks! :hattip:
    dpele likes this.
  19. Dec 14, 2022 at 10:23 PM
    #1679
    MGMDesertTaco
    @switch Here's the rubber hose mod I'm referring to...
    I'm wondering if there's something else that can be done other than using the rubber hose over the brake line?
  20. Dec 14, 2022 at 11:16 PM
    #1680
    switch
    Norther California
    MGMDesertTaco likes this.
