Show off your aux fuse panels.
Discussion in 'Lighting' started by Newlife, Dec 29, 2013.
  1. Aug 23, 2024 at 8:50 AM
    #1841
    DesertRatliff
    DesertRatliff Well-Known Member
    Mt. Hood, OR
    Mas Tacos Por Favor
    Where are you all sourcing this distribution block? I can't seem to find a source using the part number in the picture. @Eddiebeer @wi_taco
    Aws123 likes this.
  2. Aug 23, 2024 at 9:11 AM
    #1842
    Eddiebeer
    Eddiebeer Active Member
    Ahmed
    Bend, OR, USA
    TRD Pro
    Icon Stage 10, Icon Rebound Wheels, OVTune
  3. Aug 23, 2024 at 9:21 AM
    #1843
    DesertRatliff
    Mt. Hood, OR
    Mas Tacos Por Favor
    Thanks for the quick response! Rainy day off today has me wanting to get parts ordered up and on their way. I appreciate the info.
  4. Aug 23, 2024 at 9:44 AM
    #1844
    Eddiebeer
    Ahmed
    Bend, OR, USA
    TRD Pro
    You got it. BTW, if you do order just the bare unit, make sure that you order 4 pin mini relays so you have the choice of orienting them either way. My 'kit' came with 5 pin relays so I had to cut & grind off the 5th leg to allow me to flip their orientation successfully.
    DesertRatliff likes this.
  5. Dec 21, 2024 at 5:14 PM
    #1845
    wradar
    wradar Well-Known Member
    Virginia
    2021 DC OR // 2002 DC Limited TRD OR(sold)
    I’m installing the Auxbeam mount from @switch and am having trouble figuring out how to drill the hole in the wheel well for the mount that goes immediately beneath the brake manifold lines. Does anyone who’s done this before have any tips?
  6. Dec 21, 2024 at 6:51 PM
    #1846
    switch
    switch Well-Known Member
    Norther California
    2022 Tacoma Access Cab
    I also replied to your question on Etsy.
    I used a 1/4" bit that was 6" long. I mounted the bracket in place using the other two mount positions: the existing hole in the wheel well and the fuse box nut (see #1 and #3 in figure 1 in the instructions). Then I marked the position to drill the hole using my drill bit without the drill because the chuck was in the way. I just turned the bit by hand until it had scratched the paint enough to see the correct location on the wheel well. Then I removed the mount so I could drill the hole. I still had to angle the bit because the chuck was so close to the break lines. You might find it easier to drill a pilot hole with a smaller bit and then drill up from the bottom with the 1/4" bit. Don't forget to put a dab of paint on the exposed metal edge of the hole to prevent rust.
    TheWildMan and wradar[QUOTED] like this.
  7. Dec 21, 2024 at 7:53 PM
    #1847
    wradar
    Virginia
    Much appreciated, @switch! (I wasn't sure if you were holidaying it up, hence the inquiries both here and on Etsy.) I'll grab a longer bit tomorrow and finish it up.
    Happy holidays!
  8. Dec 22, 2024 at 6:09 PM
    #1848
    TrevoTaco
    TrevoTaco New Member
    Trevor
    2020 MGM Tacoma TRD Sport Upgrade
  9. Jan 7, 2025 at 10:24 AM
    #1849
    SCTaco79
    SCTaco79 Member
    2023 LunarRock Tacoma TRD Offroad
  10. Jan 7, 2025 at 10:31 AM
    #1850
    guaco.supreme
    guaco.supreme Fk around and find out
    MN
    I like it.
    Does the Renogy DC-DC make a lot of noise? I had mine in the bed of the truck, but want to move it to the cab. Unsure if it has fan noise or anything.
  11. Jan 8, 2025 at 4:59 PM
    #1851
    SCTaco79
    SCTaco79 Member
    @TrevoTaco one quick question on that setup, where did you run your ground to? Again nice setup and thanks in advance!
  12. Jan 10, 2025 at 3:24 PM
    #1852
    BigRed2513
    BigRed2513 Active Member
    Grant
    Whistler, B.C., Canada
    2014 TRD Sport DCLB Super White
    Who manufactures trays? So far i've got Paranoid Fabrications, Overland Equipped, PowerTrays....
  13. Jan 10, 2025 at 7:13 PM
    #1853
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    I got mine from a salvage yard by weight, maybe a buck or two. All it needs is a right angle and some thickness( or a corner). Aluminum bakeware works. Yes, time spent, but it’s also recycling.
  14. Jan 11, 2025 at 8:51 PM
    #1854
    paranoid56
    paranoid56 Well-Known Member
    San Diego
    14 double cab taco
    we are also one of the few that will do a custom setup per your drawings too :D
    BigRed2513[QUOTED] likes this.
  15. Jan 12, 2025 at 2:53 PM
    #1855
    Bootser
    Bootser Member
    Gary
    2021 White Tacoma TRD Offroad
    I was looking for a fuse/relay mounting tray but didn't want to pay $75 to $125 for something I could make myself. I found some black diamond plate sheets of 12" x 24" aluminum at Lowes on sale for $7.52, so I picked up two. I copied the Powertrays Blank for the TRD Offroad/Pro. Also needed to relocate the clutch reservoir, found some instructions with pictures, and made a simple bracket to mount to my tray. I did reach out to Powertrays about getting the relocation bracket for the blank tray (I was about to just buy the blank tray because it would have been easier) but they weren't very helpful.
    The Build:
    Took lots of measurements based on pictures of several different tray installations available online.
    Created a one-piece prototype.
    Used the prototype to test and realized that modular would be better.
    More measurements.
    Cut and fabricated each modular piece using:
    Jigsaw
    Bench and handheld grinders to smooth edges (metal gets too hot when using these to cut)
    Bench vise to bend parts.
    Propane torch to bend parts
    Rivet tool
    Pieces:
    Fender mount bracket.
    Tray.
    Wheel well mount bracket (goes to a ground screw below the main fuse distro panel).
    Clutch reservoir relocate bracket.
    Also used rivnuts for all the screw mounts.
    With the prototype, I couldn't get the main fuse distro panel lid open unless I loosened the tray. The modular tray allows easy removal without taking anything apart. Mostly because better final measurements.
    Foushee likes this.
  16. Jan 12, 2025 at 3:14 PM
    #1856
    Bootser
    Bootser Member
    Gary
  17. Jan 12, 2025 at 4:47 PM
    #1857
    DesertRatliff
    Mt. Hood, OR
    Mas Tacos Por Favor
    I used some aluminum 2" angle and some 1/8" aluminum sheet I had from another project, cut out the appropriate holes with a hole saw and Dremel, then wrapped it in carbon fiber vinyl wrap. I'm pleased enough with the results.
    Bootser likes this.
  18. Jan 12, 2025 at 6:25 PM
    #1858
    Bootser
    Bootser Member
    Gary
    Nice work! What hood strut setup did you install?
  19. Jan 12, 2025 at 7:36 PM
    #1859
    DesertRatliff
    Mt. Hood, OR
    Mas Tacos Por Favor
    Thanks! The hood struts are the Redline Tuning stainless struts.
    Bootser[QUOTED] likes this.
  20. Jan 15, 2025 at 11:33 PM
    #1860
    bagleboy
    Scott
    Norcal, Santa Rosa
    One nice thing about 5-pin relays is you can use a pair of them to create a reversing circuit using a low current on-off-on switch instead of running high current and wiring to a more expensive reversing switch.
