Show us what you tow.
Discussion in 'Towing' started by BBQ BOY, Feb 17, 2009.
  1. Feb 16, 2015 at 10:20 AM
    #2741
    Sterdog
    Sterdog Offline
    I am Groot
    People's Democratic Republic of Canuckistan
    15 FoST
    I did not find this, but I did find it extremely helpful to explain how each temp will effect the life of the transmission fluid. The fluid is the life of the transmission, if it goes bad you are SOL.
  2. Feb 16, 2015 at 10:22 AM
    #2742
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    Right into the Scangauge II. It's in one of the selectable menu's. Read the manual. It will come with detailed X-gauge instructions.
    The short form is you will enter the codes I've provided into your gauge and then gain those readings. It's not very hard ;).
  3. Feb 16, 2015 at 2:58 PM
    #2743
    jdavis92
    jdavis92 Well-Known Member
    Boise, ID
    2010 Regular Cab, 2.7L, 5spd
    Stock
    Still waiting for UG to have Trans Temp readability. It's really nice other than that.
  4. Feb 16, 2015 at 3:19 PM
    #2744
    AEmedic
    AEmedic Well-Known Member
    Boise, ID
    2014 DCLB 4X4 TRD Sport Supercharged
    TRD Supercharger, Toytec Adj. Coil-Overs, Bilstein 5100's, JL Audio system w/Kenwood DNX9980HD HU
    Agreed!
  5. Feb 16, 2015 at 3:41 PM
    #2745
    RKCRUZA
    RKCRUZA Well-Known Member
    Bob
    Placerville, Ca
    2015 TRD Pro in the Garage!
    Depends on what you have done to the 40...mine weighs in at about 4500# ready for the trail, so sat at close to 6k when on the Carson 16ft. flatbed. Never towed it with my Taco, but towed quite a bit with a 1st Gen Tundra which is pretty close to the size and weight of the new Taco's. If you are getting a trailer, go for Brakes on both axles! Also get some form of sway control (even the simple sliding friction ones help). I never used an equalizing hitch as I could adjust tongue weight by moving the rig on the trailer. If you have adjustable shocks on the 40 (like rancho 9000's, set them to stiff and also make sure you air the tires up to street pressure on the 40).....soft tires and shocks on softest setting gets real exciting if you have to do a quick evasive move with your truck....40 starts rocking and just keeps getting worse....major pucker factor! I used the axle straps to hook her to the trailer vs. strapping to the body.
  6. Feb 16, 2015 at 9:43 PM
    #2746
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
  7. Feb 17, 2015 at 3:24 AM
    #2747
    AEmedic
    Boise, ID
  8. Feb 17, 2015 at 4:23 AM
    #2748
    jdavis92
    Boise, ID
    Stock
    Nice! I just have to call them and make sure it's still available. The website isn't very clear about whether or not this option is still available.
    You might think, as much as folks have been bitching about getting trans temps, that UG would let folks know about this when it happens. Maybe by email or something. I'm on TW enough that I'm surprised I didn't see this.
    Oh well. Hopefully I can get it sent out today and get it back with tranny temps now.
    Jeff in Flagstaff
  9. Feb 20, 2015 at 4:50 PM
    #2749
    Savis
    Savis Well-Known Member
    Virginia Beach
    09 PreRunner
    Toytec 3" lift, Black Rhino Sidewinder, 285/70/17, Leer 100 XL
    Anybody towing a Rockwood mini lite 2306?? I am looking at buying one, it has a dry weight around 3800 pds. I have a 09 tacoma v6 with a towing package. What does everyone think about towing that weight? Thanks for any info!
  10. Feb 20, 2015 at 6:59 PM
    #2750
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    My Jayco weighs within a hundred pounds of that trailer dry. You should be fine as long as you don't over load it. My suggestion is to try and setup a test pull or to find a buddy who has a similar trailer and pull that around for a bit in every situation you can replicate. That's the only way to tell if you will be comfortable pulling that weight with your Tacoma.
    Oh, and read this http://www.tacomaworld.com/forum/towing/4031-tacoma-towing-bible.html
  11. Feb 20, 2015 at 9:06 PM
    #2751
    Savis
    Virginia Beach
    09 PreRunner
    Ok, thanks for the info
  12. Feb 22, 2015 at 7:47 AM
    #2752
    Scout957
    Scout957 Member
    SE Mass
    2014 Tacoma TRD Sport
    New guy here. I'm towing a stock M416 trailer. It has served many purposes over the years and seems a good fit for my recently acquired Taco.
  13. Feb 22, 2015 at 8:48 PM
    #2753
    HeliGav1
    HeliGav1 Member
    HeliGav1
    SW FL
    05 Double TRD OFF RD Black & Tan
    Trailer is aluminium (sorry I'm British) around 2200lbs & 39' long x 7' wide. Heli is 1500lbs empty - 1800 w fuel.
    Home-made gooseneck hitch - reinforced angle iron bolted then welded to frame. V V strong!
    Tows like a dream.
    Longest trip so far Indiana to Florida - Interstate all the way. Most difficult part was getting used to the turn radius in the first gas station - haha.
    Actually, the most difficult part is landing the bloody thing on the trailer in the first place! Str8UpAviation.com
  14. Feb 22, 2015 at 10:01 PM
    #2754
    evan164
    evan164 Well-Known Member
    Evan
    Louisiana
    05 Prerunner SR5
    Added a trailer hitch and the 4 pin connector
    ^----Yes!
  15. Feb 23, 2015 at 3:14 AM
    #2755
    AEmedic
    Boise, ID
    Very nice!
  16. Feb 23, 2015 at 8:37 AM
    #2756
    Jefes Taco
    Jefes Taco Well-Known Member
    Denver, CO
    14' DCLB TRD Sport supercharged
    Wouldn't it be simpler to just fly it to where it needs to be? :D
  17. Feb 23, 2015 at 4:57 PM
    #2757
    budd4766
    budd4766 Well-Known Member
    LaGrange, GA
    '11 Tacoma
    Pulled one of these home today. Jayco Jayfeather SLX.
    Was a lot easier than most of the uhaul trailers I've been pulling for the past few years.
    Only issue is, I need to add some mirror width. Anybody used any that they'd recommend?
  18. Feb 23, 2015 at 5:19 PM
    #2758
    Savis
    Virginia Beach
    09 PreRunner
    ^^^ nice looking trailer. What is the dry weight of your trailer?
  19. Feb 23, 2015 at 5:34 PM
    #2759
    53flattie
    53flattie Well-Known Member
    Upstate, SC
    2006 DC
    2.5" OME
    Curious about this as well...
  20. Feb 24, 2015 at 5:42 AM
    #2760
    HeliGav1
    HeliGav1 Member
    HeliGav1
    SW FL
    Yes and way more fun but also more $$$. Sometimes we use it for a static display when flying in to a show or fair would just literally blow every else's tents away!
