Shudder in drive train while coming to stop
Discussion in '3rd Gen. Tacomas (2016-2023)' started by nevadabugle, Mar 31, 2016.
  1. Dec 1, 2016 at 8:46 AM
    #261
    Bossman14
    Bossman14 Well-Known Member
    2016 white Tacoma TRD OffRoad access cab
    Stock
    I talked to the lead mechanic and they said they could replace the differential but the next one might do the same since the engineering on the spider gears has such a large range for tolerance that it hit and miss, toyota needs to fix their engineering, i have opted to not replace it, i will just deal with it until i get an arb locker.
  2. Dec 2, 2016 at 9:39 AM
    #262
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    There's been more than one poster here who has had their third gen lemon lawed for this
    moab4x432 likes this.
  3. Dec 2, 2016 at 9:55 AM
    #263
    Summitroad
    Summitroad Well-Known Member
    Northen CA
    TRD OR 4X4
    So do I, this truck is "not up to par"
    moab4x432[QUOTED] likes this.
  4. Dec 2, 2016 at 10:04 AM
    #264
    Scratch190
    Scratch190 Member
    I have a feeling since my truck has a 2.5" leveling kit they are going to try to use that as a way out of taking responsibility. Even though the issue started at 500 miles before the leveling kit was even installed and a factor. If anyone on here has gone the lemon law route any information on what that process consisted of would be great. The issue is getting progressively worse so I am hoping something fails so the issue is obvious.
  5. Dec 8, 2016 at 6:49 AM
    #265
    nevadabugle
    nevadabugle [OP] Desert Rat
    Elko, NV
    2016 DCSB TRDOR manual in quicksand
  6. Dec 8, 2016 at 7:03 AM
    #266
    Omar RVA
    Omar RVA Well-Known Member
    Omar
    OR
    2020 Ram 2500 Power Wagon; 2019 Land Cruiser
    Though I agree in principle, don't you have a lift and aftermarket spring pack? Even if your (beautifully built) truck was a 6AT, Toyota wouldn't touch it and if they did it would involve stock replacement leaf springs.
    Even if I could (I'm a fellow MT owner), I wouldn't have the TSB done because I want to lift down the road (I'm holding out for a diff howl TSB, however foolish that may be...). That said the steering wheel damper is around $25 online and I'm tempted to just buy and install myself; in any case it's treating a symptom and not the main issue.
    Don't mean any offense - just wanted to put that out there.
    EDIT: After actually reading your build thread, I was wrong - you're planning for an HD leaf pack but are currently only using sumo springs. My bad!
    OA
  7. Dec 8, 2016 at 7:32 AM
    #267
    nevadabugle
    Elko, NV
    No worries man, no offense taken. I have a 3 leaf AAL sitting at home. Have waited long enough to install. Once I do this TSB becomes irrelevant any way as you pointed out. So I will install and hope that stops these vibes.
    Any idea what a steering wheel dampener does?
  8. Dec 8, 2016 at 8:08 AM
    #268
    Omar RVA
    Omar
    OR
    I imagine it just soaks up some of the natural vibrations that come through the wheel. Looking at the part, it's difficult to tell how it works. If I cared enough I'd go to the dealer to actually touch one, but something tells me it probably isn't worth it lol.
    OA
  9. Dec 8, 2016 at 2:51 PM
    #269
    Scratch190
    Scratch190 Member
    Well I took it in to a second dealership and though they too wanted to pass accountability onto the 2" spacer calling it a needle bearing issue we finally got to the bottom. I agreed to have the bushing installed at a cost of $450 out of my pocket with the understanding that if it did not fix the issue I was not going to pay. A couple hours later the service tech informed me that the entire front differential needed to be replaced. So if you can isolate your vibration to the front driveline using a ziptie on the cross member to isolate it or just remove it all together I am guessing the same thing they forgot to do when assembling mine or doing QA has been overlooked on yours as well. Honestly at this point I will not be surprised to learn that they forgot to fill it with gear oil. Just like the Tow package tacomas that they did not account for the oil cooler in 2016. Now I am out a vehicle another week, and now they cant find me a rental....... WTF They say they are going to compensate me for the days I have not had a vehicle and my time and travel but we will see about that. I guess that is the last glimpse of hope they have to try to make this less embarrassing for them. Hope this can help all of you with the 35 mph in 2wd front drive line vibration that goes away when its put into 4wd or if you remove or isolate the front driveline.
  10. Dec 8, 2016 at 2:54 PM
    #270
    Scratch190
    Scratch190 Member
    Did I mention I told them the issue started before the leveling kit was put on and had pretty much diagnosed the issue for them with the help of this forum.........?
  11. Dec 13, 2016 at 11:51 AM
    #271
    Contra472
    Contra472 Well-Known Member
    2016 Tacoma DCSB 4X4 OR
    I see in your other thread you installed your AALs . did that help with the driveline vibes?
    I'm super bummed the new TSB doesn't cover our TRD ORs , so looking for options .
    Thanks!
  12. Dec 13, 2016 at 1:24 PM
    #272
    nevadabugle
    Elko, NV
    I did not notice them with the new leaf pack installed. however I only have about 60 miles on the new set up and my original one was hit ando miss on when it would do it. Bottom line is its too soon to tell if it helped.
  13. Dec 13, 2016 at 1:27 PM
    #273
    BlkTaco47
    BlkTaco47 Unhinged
    2018 TRD PRO Midnight Black Metallic
    I would think that should of fixed it, that's what they're
    replacing on mine when the parts come in.
  14. Dec 13, 2016 at 2:26 PM
    #274
    smitty99
    Scottsdale
    I wonder if this will have any impact on the clunk or harsh downshift when rolling to a stop
