Shudder issue conclusions
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Mike_72, Jan 22, 2008.
  1. Feb 5, 2008 at 8:13 PM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    I've discovered that, in fact, mine does NOT do it when the A/C is off. I put the A/C on today for a bit (it was 73) and it did it at the first stop.
  2. Feb 9, 2008 at 12:15 PM
    Mike_72
    Mike_72 [OP] Member
    Tacoma SR5
    Does anyone know if putting a lift kit on their truck has eliminated the problem??
  3. Mar 4, 2008 at 11:17 PM
    tacopuppy
    tacopuppy Well-Known Member
    i have the same issue as Deer Pop. It only does it after the truck has been running for 10 minutes or so. it doesn't do it when there are more than two passengers in the truck. it also doesn't do it when i decelerate the truck in neutral, or when the truck is in 4x4. btw, I own a 07 DC, 4x4, auto
  4. Mar 4, 2008 at 11:27 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Not the same thing... That's the ABS system self check and perfectly normal.
    The shudder that I get doesn't make any noise. It happens without A/C. You'll be stopped for a couple seconds and then it'll feel like a *bump* (like someone bumped you in the rear-end). I'm gonna say it's transmission related - some sort of late downshift that cause the rpm's to increase briefly. Our previous Grand Cherokee did the same thing.
  5. Mar 21, 2012 at 11:22 AM
    AERO99
    AERO99 Member
    2012 TRD SPORT DC
    I have it when coming to a stop around 20 mph
  6. Mar 21, 2012 at 12:05 PM
    RV7Garage
    RV7Garage R.O.U.S.
    Paul
    Ill Annoy
    2012 DCSB Offroad, Nautical Blue
    Disable DRL, Jailbreak Fog Lights, ARE topper
    Wow, way to resurrect a 4-year-old thread! :cheers:
  7. Mar 22, 2012 at 1:11 PM
    AERO99
    AERO99 Member
    2012 TRD SPORT DC
    would the slip yoke need lube with under 1,000 miles on truck?
  8. Mar 26, 2012 at 7:16 AM
    650H1
    650H1 Well-Known Member
    Michael
    VA
    2020 (Cement) TRD O/R
    ^ how do you lube the slip yoke?
  9. Mar 26, 2012 at 12:31 PM
    lundy
    lundy Well-Known Member
    Justin
    Reno, NV
    2023 Double Cab 4x4
    Mine is the same as I begin to slow down (below 30mph)
    I've been to the dealership. They said its normal for a leveled Tacoma. I have Toytec springs up front and 265/70R17. Never thought a 1.25" front lift with tires an inch bigger would be such a nightmare.
  10. Mar 26, 2012 at 12:34 PM
    rondog
    rondog Well-Known Member
    Ronnie
    Escondido/San Diego
    my truck shakes about 5 seconds after I stop. It only happens when I am idling. If I am stopped and turn my wheel it goes away (idle goes up) and then starts doing it about 5 seconds later (idle came back down). *Sometimes* the fan speed on my AC will effect how much its shaking...other times it does nothing. It's very strange
  11. Mar 26, 2012 at 12:37 PM
    lundy
    Justin
    Reno, NV
    2023 Double Cab 4x4
    My toytec leveling springs didn't help. I never had this vibe until the dealer did the rear leaf TSB and replaced my front differential.
  12. Mar 28, 2012 at 10:44 AM
    lundy
    Justin
    Reno, NV
    2023 Double Cab 4x4
    Just a heads up, I went to a different dealership and they said the TSB leafs and the lift they added to the rear are causing the vibe/shudder due to the new drive shaft angle. I think they're full of it but they recommend the carrier bearing drop. I don't think it's gonna work but I ordered one anyways. Kinda sucks that I have to pay for a part that is "supposed" to fix a problem caused by Toyota's TSB springs.
  13. Mar 28, 2012 at 5:08 PM
    Profounddiver
    Profounddiver Well-Known Member
    Robert
    Miami
    2020 White TRD PRO
    Bakflip F1, K&N Air intake, Meso Puddle lights, Meso Interior lights, spiker struts, Cali Raised Molle Bed system
    I just came back from Advanced auto parts and I bought the leaf spring helper kit, I read up on it on a thread here and I am going to try it out. I too am having the rear-end bump when I come to a stop. I took it to the dealership and of course, it didnt do it when the mechanic drove it. I am going to try this easy fix first and see if it does the trick. I am getting tired of looking in the rear-view mirror to see if someone bumped me. :mad:
