Shudder/vibration at 2000-2500 rpm manual
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Cdn 11 tacoma, Feb 14, 2025.
  1. Feb 14, 2025 at 8:38 AM
    Cdn 11 tacoma
    Cdn 11 tacoma [OP] Member
    2011 V6 TRD
    None
    I’m having issues when pressing the gas at approximately 2000-2500 rpm. V6 manual transmission.
  2. Feb 14, 2025 at 8:45 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    In what gear? Or all gears?
    On flat ground?
    On hills?
    Can you repeat it in neutral, truck not rolling?
    We kind of need to know what load is on the engine when this happens. The more info we get, the better we can help.
    Jimmyh likes this.
  3. Feb 14, 2025 at 8:49 AM
    Cdn 11 tacoma
    2011 V6 TRD
    None
    Ok all gears, just lightly accelerate, just holding in that rpm range. Flat, hill doesn’t matter same thing, and not in neutral only when driving. Stops when I release gas pedal. Recently had transmission replaced with one from ‘15. This started about 3 months later.
    ToxicTwin likes this.
  4. Feb 14, 2025 at 9:02 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    First I would check the universal joints in the driveshaft.
    BTO and TnShooter like this.
  5. Feb 14, 2025 at 9:09 AM
    Cdn 11 tacoma
    2011 V6 TRD
    None
    I looked at them don’t see anything obvious, I greased them, I’m gonna take a second look tonight or tomorrow when I’m off work. Thx
  6. Feb 14, 2025 at 11:21 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    For a proper inspection you need to remove the driveshaft and manipulate each joint by hand, looking for extra looseness or tightness. Also inspect the center support bearing.
  7. Feb 14, 2025 at 3:30 PM
    Cdn 11 tacoma
    2011 V6 TRD
    None
    So I’m gonna go ahead and just replace all 3 u-joints if I have the shaft out might as well just do all 3 I figure. Are all 3 the same part ?
  8. Feb 14, 2025 at 3:35 PM
    TnShooter
    Deogee
    STOCK
    If you're going to throw parts at it. Throw all the parts at it and include a carrier bearing too.
    I'll have to look for part #'s and get back to you.
    Jimmyh likes this.
  9. Feb 14, 2025 at 3:37 PM
    TnShooter
    Deogee
    STOCK
  10. Feb 14, 2025 at 4:43 PM
    Cdn 11 tacoma
    2011 V6 TRD
    None
    Ok thx, can’t seem to find ones for the front though.
  11. Feb 15, 2025 at 5:04 PM
    Cdn 11 tacoma
    2011 V6 TRD
    None
    Ok so took drive shaft out today, had to cut off the bolts but I definitely have a bad u-joint at the rear, just waiting on parts to be delivered for reinstalling. Thx again folks, will update when all done but might be a couple weeks as I work away.
    Jimmyh likes this.
  12. Mar 15, 2025 at 2:55 PM
    Cdn 11 tacoma
    2011 V6 TRD
    None
    U-joints replaced vibration gone
    Jimmyh likes this.
