Shudder/Vibration while towing?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Supra TT, Sep 23, 2011.
  1. Sep 23, 2011 at 5:06 PM
    Supra TT
    Supra TT [OP] Solid Axle FTMFW!!
    Eric
    Lafayette, Indiana
    2000 SAS D60 F/R
    SAS.. Need I say more.
    Title says it all pretty much...2008 dc TRD or. Extreme vibrating at any speeds while towing my 2000 Sas Tacoma on a jerry james 16 foot tandem axle trailer. Total weight truck and trsiler 10.6k. I've towed this 15 times, some days it does it the other days it doesnt. Any ideas?? My only guess is rear driveshaft angle. Truck has 1.5" aal.. sorry bad punctuation, on my phone.
  2. Sep 24, 2011 at 12:03 PM
    matts11
    matts11 Well-Known Member
    TN
    Here is an idea...you are towing .....oh.....about double what your truck can comfortably tow. If you are towing 10600 pounds behind a Tacoma i think vibration is the least of your problems. But I would imagine the vibes are related to the way the trailer is loaded. A little bit of weight transfer on a trailer can make a difference. Play around with how the truck sits on the trailer and find the sweetspot where you dont get vibes...then mark it. But seriously....are you nuts?
  3. Sep 24, 2011 at 12:15 PM
    JasonJump
    JasonJump Well-Known Member
    Yukon Oklahoma
    '05 Tacoma TRD Sport 4X4 D Cab Debadged
    Billy 5100's set at 2.5, iPhone innerface, TRD Sport wheels powdercoated Anthracite grey wrapped in 265/70/17 Duratracs, Custom Sliders
    :facepalm:
  4. Sep 24, 2011 at 12:26 PM
    KenLyns
    KenLyns 8-in. Third Member
    Belly of the Beast
    4x4 TRD Off Road Full-Auto
    All-Pro Bumper, CBI Sliders, Icon Coilovers, BudBuilt Skids, aFe Intake, Icon VS Rear Shocks, Timbren Bumpstops, All-Pro UCAs, JDM Steering Wheel, ViAir Compressor, Klearz LED 3rd Brake Light, Pop-N-Lock Tailgate Handle, Husky Front Flaps
    I'm assuming 10600 lb is the gross combined weight of your 2008 towing truck and the trailer? How much is the tongue weight?
  5. Sep 24, 2011 at 12:34 PM
    Oat
    Oat Well-Known Member
    Florida
    2001 Prerunner
    Gibson Exhaust, Painted factory steel wheels, Chrome wheel caps, K&N Air intake, Tint, Regular Bilstein (yellow/blue) all around, Leveling spacer kit upfront, Partially de-badged, Westin Bullbar with skidplate, White, Double Cab Prerunner SR5
    With a 2.7L i think you're over-towing...
  6. Sep 24, 2011 at 2:16 PM
    HEAVY WT
    HEAVY WT Well-Known Member
    Matthew
    LA
    16 T4R TEP
    I had to tow my car one time and with the trailer and car, it was about 4700#. I got a strange vibration that cycled through slowly when at highway speeds. I don't tow a lot and my buddy's boat doesn't do it, so haven't paid much attention to it. Hopefully nothing major...
  7. Sep 24, 2011 at 3:33 PM
    KenLyns
    Belly of the Beast
    @Supra_TT: Next time you are towing, ask a friend to watch the trailer's movement. Should be able to tell quickly whether the trailer is oscillating in pitch or in yaw (sway).
    Do you have a sway control damper on the trailer/ball mount?
    http://www.etrailer.com/Weight-Distribution/Pro-Series/83660.html
    Are the trailer's tires balanced?
  8. Sep 25, 2011 at 6:17 AM
    Supra TT
    Eric
    Lafayette, Indiana
    2000 SAS D60 F/R
    First of all im only towing around 5,000 #s... and ill try and move the truck around, thanks.
    yes, gcvw. And I'm not sure honestly.
    4.0....
    I do not have a sway control, but will order one soon. also the trailer has driven fine on 3 8 hour trips and numerous other smaller trips, but unsure if they really are or not.
  9. Sep 25, 2011 at 6:19 PM
    Supra TT
    Eric
    Lafayette, Indiana
    2000 SAS D60 F/R
    Update: I moved the truck 3 inches farther forward... seems to work a lot better, but its adding more tongue weight and keeping the suspension 2" from stops which I don't like. Time for air bags maybe, and definitely a sway control.
