Shurtrax Traction Aid
Discussion in 'Buy / Sell / Trade' started by AK2NM, Feb 3, 2013.
  1. Feb 3, 2013 at 2:45 PM
    AK2NM
    AK2NM [OP] Active Member
    Surprise, AZ
    spacer lift,275/60R17, hi-lift mounted in bed, tailgate secured, rear window bar,many to come
    Like new Shurtrax traction aid. $100 obo. No rips, tears, or patches. Size is for a full size truck. By far the best and safest way to add weight to the bed of your truck.
    The ShurTrax All Weather Traction Aid for Full Size Pickup Trucks and SUVs safely and cleanly adds handling, traction control and traction weight over the rear axle, preventing axle hop and wheel hop. Simply add up to 400 pounds of water using a simple garden hose along with the included fill fitting. Four brass grommet tie-downs allow for safe, secure weight that improves vehicle balance, handling, cornering and traction on wet, slippery roads. ShurTrax answers the safety concerns of alternative sources of weight such as sandbags, concrete blocks, cord wood and other potential projectiles. Baffles are die-electrically welded into place to prevent surging during cornering. No need to worry about carrying cargo on top of ShurTrax, it has been tested to support 500 pounds. ShurTrax integrity is protected by a tough 25 millimeter vinyl outer chamber. This outer chamber vinyl is UV resistant and reinforced with woven nylon mesh for long service. The inner chamber is also 25 millimeters thick and flexes, enabling a smooth ride and improved handling.
  2. Feb 4, 2013 at 3:17 PM
    OH-MAN
    OH-MAN Well-Known Member
    Sunny Az.
    10 4X4 O.R. White
    TRD skid painted black,
    Pretty inexpensive way for the expo guys to carry 45-50 gallons of water as well as traction!!
    Best of luck on the sale.
