Sick of this leak
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Yoda66, Feb 20, 2019.
  1. Feb 20, 2019 at 4:40 PM
    Yoda66
    Yoda66 [OP] Active Member
    Joe
    2007 Tacoma TRD Pre runner
    Water leaking on both sides of sliding window. Sealed back window and now only leaking on drivers side. Also replaced 3rd brake light. Still leaking. Going to reseal drivers side tomorrow.
    No water in headliner or on the floor/ carpet. Only gets wet on access cab rear seat back.
    This is driving me crazy.
  2. Feb 20, 2019 at 7:04 PM
    Troyken
    Troyken Well-Known Member
    NY
    2013 DCSB v6 off road 4x4 6 spd. MT
    I had rain water coming in on the passenger side upper corner of the rear window gasket. It leaked where the roof trim went down behind the window gasket. I cut the roof trim a little shorter and filled that joint and behind the window gasket with black permatex silicone. I also sealed the roof trim to the roof with the same sealer.If the water gets under the roof trim it will flow back in the roof trim channel ,right in behind the window gasket ,and into the cab somewhere. I did both the passenger and drivers side. Still dry. The water ran under the headliner down inside the rear pillar trim and along the floor to soak the front carpet. These leaks are a big pain in the neck.
    Yoda66[OP] likes this.
  3. Feb 20, 2019 at 7:23 PM
    steveo27
    steveo27 Ask me about my weiner
    Pittsburgh
    '11 TRD Off Road & 1992 VW GLI
    The same shit everyone else has.
    Watching this since mine does this in a heavy rain.
    It’ll drip down off the black weatherstrip on both sides one the rear seat back. Headliner never gets damp, just the fabric section of the seat.
    Curious to see what steps you take to solve this.
    Not sure if this is because I’ve had the 3rd brake light out before. The seal wasn’t damaged though.
  4. Feb 20, 2019 at 7:28 PM
    Troyken
    NY
    I replaced my third brake light with a Chevy Colorado? one I think it was. It has load space lights in it. I had to enlarge the opening as the Chevy light was slightly bigger. I just sealed it neatly to the body with black silicone and it does not leak. You can do that with your stock light. If you have removed it the gasket may have been damaged and leak.
  5. Feb 25, 2019 at 9:57 AM
    Yoda66
    Joe
    Leak fixed!! Now to put out 10 cups of vinegar.
  6. Feb 27, 2019 at 5:16 AM
    Dhannah
    Dhannah 2017 Tacoma OR DCSB
    Daniel
    North Carolina
    '17 DCSB OR TRD 4x4
    Under Construction
    My whole back seat was wet after heavy rain I'm going to have to do something soon. I thought it was the roof rack or third brake light but I don't know it's coming from both sides more from the passenger side.
  7. Feb 27, 2019 at 11:26 AM
    HansLanda
    HansLanda Well-Known Member
    Both sides of my sliding rear window used to leak water. I tried sealing it with silicone but it didn't work. Couldn't really tell where the leak was coming from exactly.
    Replaced it with a single pane of glass, and it's been great. The extra rear visibility is nice.
  8. Feb 27, 2019 at 7:25 PM
    Yoda66
    Joe
    That’s whet I eventually want to do is replace with non sliding window. Did you have to buy new weatherstrip? Mine is sealed and not leaking at the moment.
  9. Feb 28, 2019 at 10:54 AM
    HansLanda
    This is the aftermarket window I bought. Needs nothing else but glue to install. The seller has another listing with some glue included if you want to DIY.
    I didn't want to take the chance of another leak, so I had a shop install it for $249. Pretty expensive in total, but I was so sick of drying out the cab, I had to do it.
    Your OEM window's weather stripping will be destroyed when removed. They don't sell rear window weather stripping by itself, only included with an OEM rear window. So there is no going back, your OEM window will basically be destroyed.
    https://www.ebay.com/itm/273567195878
  10. Feb 28, 2019 at 4:52 PM
    Yoda66
    Joe
    Thanks. Definitely going this route
