Side mirrors w/ turn signal
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bjboucher, Sep 16, 2012.
  1. Sep 16, 2012 at 4:45 AM
    bjboucher
    bjboucher [OP] Mama says Tacoma World is da devil!
    Brad
    San Antonio, Texas
    Former 2012 DCLB 4x4 SR5 Texas Edition
    OME complete kit w/ 885s on Nitrocharger Sports, 1/4" spacers, Dakars w/ Nitrocharger Sports, LR UCAs, 265/70-17, Duratracs, G4 Elite tonneau, Weathertech Window Deflectors, Weathertech digital floor liners, factory JBL/Entune, rear differential breather relocate.
    Tried searching, which is hard on this site....TONS of threads on here makes it hard to sift through! Not a bad thing I guess.
    I really want the body color side mirrors with turn signals in them that they put on the TRD Sports for my truck. Have a couple questions though:
    1. Is my SR5 model pre-wired for turn signals?
    2. Is replacing the mirrors a pain?
    3. Anyone have a part number for the 2012 mirrors? Seem very hard to find on-line right now. All I can find are the 2005-2011 mirrors. I think the style changed slightly for 2012.
    As long as my DCLB truck is, I can't believe it didn't come with some sort of side marker turn signal. My tiny former Mazda3 even had them and it was like half the length! lol.
  2. Sep 16, 2012 at 9:02 AM
    Jones
    Jones Well-Known Member
    Texas DFW
    06 SSM Prerunner TRD-OFFROAD
    Front: 5100@1.75 with SR5 coils; Rear: 5100 and 1.5 Toytec aal; Tires: Hankook 265/75R16 RF08 ATM; Wheels: powdercoated off-road wheels with FJ TRD center caps
    I have no clue if the SR5 are prewired, but Toyota seems to prewire a lot of their things.
    The thread should help if not prewired.
    http://www.tacomaworld.com/forum/2n...nal-approach-lighting-power-fold-yes-wip.html
    For replacing the mirrors, remove the door panels, then unbolt the three bolts. Not to hard.
    http://www.tacomaworld.com/forum/2n...how-dis-assembling-your-mirrors-painting.html
    Sorry no part numbers but Toyota of Dallas has a pretty good website for parts.
    http://www.toyotapartsales.com/part...teid=214074&vehicleid=1502964&diagram=8512605
  3. Feb 11, 2018 at 8:14 PM
    Y3ll0wJ4ck3t
    Y3ll0wJ4ck3t Member
    '12 Base 4wd 5pd 2.7
    3in Procomp Lift, 34in swampers, Stickers.
    Was it pre wired? I’m looking to do this on my 2012 base 4wd
  4. Feb 11, 2018 at 9:30 PM
    MattDaddy
    MattDaddy Well-Known Member
    Matthew
    So-Cal
    2015 TRD OR AC 4x4 6MT
    I’m pretty sure you don’t have to remove the door panels, just the triangle piece above the door panel. Then there should be a couple fasteners and the mirrors will drop. At least that’s how they were last time I replaced one.
  5. Feb 12, 2018 at 5:59 AM
    CITY TACO
    CITY TACO Well-Known Member
    Greater New Brunswick
    15 TRD Barcelona Red
    You can't acces the wires by just taking off the triangle. You need to take off the door panel to see the round connector as it is buried lower. Check the connector to see if there are more wires on the lower one then on the upper one. If so you have the lights prewired if not you have a larger job on your hand. You do not have to buy the sport mirrors as all the bases are the same. There is a outside cover that pops off, if you move the mirror glass you will see the tabs. When you take it off you should see what looks like a slot with a couple of screw holes, this is where the light goes. The signal light came standard on the 2009 - 2012 RAV4, sienna, and highlander. Wrecking yards are full of them and best place to get them as you need some of the wiring also. Toyota wants big bucks for them as I was quoted $130 each here in Canada. There are also sellers on eBay from China that sell them for $25 US free shipping.
    Toyota sells just the outer cover for the mirror in your trucks color, they want $80 each up here but appear to be a lot less in the US. Do not buy the mirror assembly off eBay or Amazon they are crap and if you break the mirror glass you can't get a replacement as they are an odd size and smaller then the Toyota ones.
  6. Feb 12, 2018 at 6:09 AM
    ChadsPride
    Sponsored by TacomaWorld.com
    Good info!​
    inwood customs likes this.
  7. May 6, 2024 at 5:52 PM
    BronxTaco
    BronxTaco Member
    2015 Tacoma Access Cab 4X4 4CYL. 5 Speed Manual
    I just got the turn signal mirrors and they worked when plugged in on my 2015 base access cab 4x4
  8. May 13, 2024 at 1:12 AM
    Custom.taco
    Custom.taco New Member
    2009 Manual 4x4 Regular Cab
    2009 Regular Cab Tacoma 4x4 Manual 2.7L 4cyl 36k mileage CURRENT MODS: Steering wheel cover 7in antenna Envelope style Bed Net Floor mats Seat covers Trailer hitch Toyota cap. 20% ceramic tint sides and back ARE bed cover with 3 spare keys Programmed KARR replacement fob FM bluetooth adapter NED TO FIX: Passenger door lock/unlock actuator. (The karr alarm only works on driver side) WANT: Electric Side steps In-channel vent visors Tire valve caps Dash cover Bed lights Bed Carpeted bed insert Bed cover/tailgate rubber seal Leveling kit + spacers to fit the gap FUTURE ADD ONS: Install OEM Power inverter Install 2012+ OEM steering wheel working airbag only. Install 2012+ OEM stereo to match the redish color on my dash lights. Install 2012+ OEM front end
    I have a 2009 manual regular cab tacoma 4cyl. Im looking to swap out the basic side mirrors for some can be controlled with a button to position the mirror and Id like it to also include a turn signal. Has anyone been able to do this?
