Side to side play in steering rack piston? Normal?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Andyd103, Jan 15, 2020.
  1. Jan 19, 2020 at 1:56 PM
    RysiuM
    RysiuM Well-Known Member
    Rysiu
    Was Golden State, now Poland EU
    1995 4x4 LX Ext Cab, I4 2.7, MT, 335K miles
    DD Deck+backup camera, LED DRL, All LED except H4 Hella
    You are not supposed to "torque guide down", but there is very specific procedure about the setting the that "cap". If it's tighten to much, the rack will go very fast.
    https://youtu.be/r4Hhl225E8A?t=658
  2. Jan 19, 2020 at 1:57 PM
    RysiuM
    Rysiu
    Can you tell how much play did you have in the roller that would cause such play in the wheel?
  3. Jan 19, 2020 at 2:36 PM
    Andyd103
    Andyd103 [OP] Well-Known Member
    Andrew
    New Hampshire
    2002 Tacoma SR5 4WD (3.4L V6)
    Suspension Lift, 40mm Turbo
    the piston was mint, free of any marks or corrosion. The roller was not worn itself but there was some slop on the bearing and the setup itself either was worn out or allowed the piston to move too much. I torque it to 18ft pounds using a fish scale as my torque wrench doesn’t do that low. And then backed it up approximately 19 degrees.
    I replaced the guide, spring and cap.
    cruiserguy and RysiuM[QUOTED] like this.
  4. Jan 19, 2020 at 3:41 PM
    RysiuM
    Rysiu
    Like I wrote before I had quite side-to-side movement on the roller (the bearing was running smooth tho) that was causing the "piston" move, like you can see in this video below, but I never had such movement on the tire. By the way, I did wheel alignment a year before I replaced the roller for bushing so if if I had any slope in the wheel, they would never be able to adjust it. Of course, after I replaced the roller for bushing I did not need any wheel adjustment. Truck is driving the same, just does not make that rattling noise.
    https://youtu.be/XosdC0cujeE
  5. Jan 20, 2020 at 1:06 AM
    Andyd103
    Andrew
    New Hampshire
    I tested the torque on the old nut and it was 8 ft pounds at max depth almost. It think it was mostly lack of pressure on the drivers side end allowed it to move
  6. Jan 20, 2020 at 7:55 AM
    Timmah!
    Timmah! Well-Known Member
    TIM
    You mean like this?
    https://www.youtube.com/embed/r4Hhl225E8A
  7. Jan 20, 2020 at 12:55 PM
    Andyd103
    Andrew
    New Hampshire
  8. Jan 20, 2020 at 1:40 PM
    RysiuM
    Rysiu
    I am confused like hell. So you replaced the guide with the new one but the same roller type, correct? The slope you experienced was with worn bearings on the roller or just side to side movement or cap not torqued correctly or all of that?
  9. Jan 20, 2020 at 2:16 PM
    Andyd103
    Andrew
    New Hampshire
    I replaced the ROLLER bushing guide with the SOLID bushing guide, new spring and new cap. Before the replacement the rack piston on the drivers end side was able to move left to right and up and down within the sleeve.
  10. Jan 20, 2020 at 5:11 PM
    RysiuM
    Rysiu
    Got it. How that roller looks like - I mean bearing condition and how much is side to side roller movement inside the case?
