Side view / description OEM roof rack?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Sidney Vicious, Apr 11, 2020.
  1. Apr 11, 2020 at 6:13 PM
    Sidney Vicious
    Sidney Vicious [OP] Well-Known Member
    NOLAUSA
    2013 Black DCSB Prerunner
    I am shopping for a roof rack for my 2013 DCSB to strap a canoe to and can’t get a good visual on the rack in pictures I have found to understand how a strap might run from side to side and then over the canoe - it looks like the side rails are solid? What am I missing?
  2. Apr 11, 2020 at 6:30 PM
    gasgasman
    gasgasman Well-Known Member
    Girard
    Texas
    On the OEM rack, the side rails unhook and rotate around to become cross bars.
    There are a couple lashing points on each side.
  3. Apr 11, 2020 at 6:33 PM
    Sidney Vicious
    NOLAUSA
    by lashing points is that a through-hole in the rail? Or like an eyelet? Having trouble picturing it. Thank you
  4. Apr 11, 2020 at 6:56 PM
    gasgasman
    Girard
    Texas
  5. Apr 11, 2020 at 8:09 PM
    Sidney Vicious
    NOLAUSA
    I found this picture following your link - I see the two loops on each side now - thanks.
  6. Apr 12, 2020 at 8:28 AM
    jbaker1976
    jbaker1976 It's always Taco Tuesday
    East TN
    2015 DCSB OR
    Camper shell with side windoors and bed slider, JL Audio Component Door Speakers, JL Audio Stealth box, Grill Craft Grill, Husky floor liners, Hondo Radio knobs, Predator steps, Remote Start, Pop N Lock, etc...
    I really don't think those plastic hoops will hold up to straping a canoe. I would strap to the cross bars and those are pretty weak too. I think you need at least one support point in the rear.
    Have you looked into a cheap ladder rack?
    https://www.amazon.com/dp/B009VOQ05U/ref=cm_sw_r_other_apa_i_7lZKEbBNW2PWD
    Check this thread out for ideas. If you use the factory rack I think you'll need something like this.
    The make a version that will get close to the cab height on the truck. Check out this thread for ideas.
    https://www.tacomaworld.com/threads...ith-your-canoe-or-kayak-mounted.333515/page-2
    You can find alot stuff used on Craigslist and Facebook marketplace
    Sidney Vicious[OP] likes this.
