Sidewall tool box?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BelchFire, Sep 2, 2008.
  1. Sep 2, 2008 at 12:01 PM
    BelchFire
    BelchFire [OP] Member
    "Right" Coast
    08 Prerunner SR-5 QuadCab
    A.R.E. Tonneau
    A LOOOOOONG time ago, I saw a brochure for a company that modified your truck bed into a toolbox. It was the coolest thing I'd ever seen. Basically the sides of the bed opened up from the outside and the wall of the bed was filled with shelves. The inside of the bed remained the same. The toolbox was the empty space between the outside panels and the inside of the bed. It locked, of course, and was hinged on top with nitro cylinders to hold the side wall up when it was open. The latch (and lock IIRC) were on bottom so when it was closed, the only thing you could see was the hinge. Coolest thing ever! Has anyone ever seen anything like that for a Taco (for that matter, has anyone ever seen this at all?)
  2. Sep 2, 2008 at 3:27 PM
    concrete jedi
    concrete jedi Well-Known Member
    Rochester N.Y
    06 Tacoma 4 door indigo blue
    Broken and scratched tailgate, cracked rear tail light lens, coffee stain in driver seat.
    Sounds pretty cool but that is new to me, most commercial trucks with heavy duty tool boxes are domestics, although I am starting to see a lot of heavy duty trucks powered by diesels by International, Freightliner, and peterbuilt, these are smaller chasis trucks for there brand, but bigger than a ford or chevy.
  3. Sep 2, 2008 at 3:30 PM
    BelchFire
    "Right" Coast
    A.R.E. Tonneau
    jedi,
    The neat thing about this conversion is that they use(d) the existing sidewalls, not a boring, industrial looking flat panel. I wish I knew more about it. I'm sure it's not cheap, but I'd give it some serious consideration while the truck is new.
