Sienna odd sound coming from the top
Discussion in 'General Automotive' started by drmax, Dec 17, 2012.
  1. Dec 17, 2012 at 6:54 AM
    drmax
    drmax [OP] Well-Known Member
    IND
    95 DLX 4WD
    2005 AWD Sienna. With no check eng light, I'm getting a sort of rattle sound coming from the area above the timing cover side of eng. Verified is "NOT" coming from under the cover...So not tensioner, belt, waterpump, idler pulley, etc) in which can not be seen under that cover. (the covers was pulled and looked at stuff underneath) Also, those items were replace 6 months ago at 100K miles. Ok, the odd thing is...the sound goes away as soon as eng. warms up.
    It takes engine temp to get this sound to go away....no ambient temp. Car acts normal. No abnormal temps. or indications.
    A neighbor mentioned a varaible cam spool type sensor. We both doubt this, as no ck eng light.
    I doubt a valve, as it does not have the distinctive "tap", unless this lifter would make a different type sound. Guy mentioned to put a pint of dextron 4 in eng oil to clean out anything if depostited. I run 5w-30, as what is recommended, and a good brand.
    Almost a gurgley sound, then gradually disipates to normal eng sound. Anyone?
