Sigma SW40VE
Discussion in 'Guns & Hunting' started by 6spdtaco, Sep 25, 2010.
  1. Sep 25, 2010 at 3:31 PM
    6spdtaco
    6spdtaco [OP] Well-Known Member
    VT
    Taco
    I've put about 500 rounds through my .40. I noticed that the gun shoots up and right about 3-4" from about 10 yards. I know its not just me "pulling" because I have had several friends experience the same issue with my gun. Correcting for this is becoming a pain.
    Any suggestions for sighting corrections would be appreciated. The sights are fixed, so no easy adjustments that I know of.
    I know this is a inexpensive gun, so comments like "buy a better gun" are not necessary. I have owned inexpensive guns in the past that shoot very accurately.
  2. Sep 25, 2010 at 6:09 PM
    nomad
    nomad Well-Known Member
    3" to 4" off at 10 yards is a lot.
    Three suggestions:
    1) Try several different types/ brands of rounds. Some guns like certain rounds better than others... even two of the same gun.
    2) Keep shooting the same rounds, buy a laser grip and never worry about it again. As long as it keeps hitting in the exact same spot (even if it's not where your fixed sights are pointed), a laser will fix your problem.
    3) Take it to a gunsmith who KNOWS his/ her stuff and get them to work it for you.
    I personally would go with option 2. In an emergency you just put the dot on the target and squeeze. Plus, it's one less thing to worry about in a low light situation. From my experience, Sigmas aren't bad guns.
  3. Sep 25, 2010 at 6:11 PM
    nomad
    I forgot another option...
    Send it to S&W and let them know what's going on. They may be able to get it dead nuts on for you. They do a good job when they rework/ slick up their guns.
  4. Sep 25, 2010 at 8:09 PM
    Packman73
    Packman73 ^^^^ 3%er ^^^^
    The free state of Arizona
    2007 TRD Off Road
    Bilstein 5100's (front set @ .85"), OME 885's, chris4x4 anti-Taco-lean spacer on driver's side, Total Chaos UCAs, Rear Leaf Spring TSB, Toytec AALs, Black FJ TT Wheels, BFG 285/75R 16 AT Tires, TRD Exhaust, Viper Alarm, Fog Light Mod, De-badged, Blue LED Dome Light, EZ Clamped Tailgate, Wet Okoles, Satoshi Grill, 5% Tint, Engine Tick Fix, Black Rear Bumper, Black Center Valence, Exhaust Cut At Axle, Thanks for all the help chris4x4!
    ^This^
  5. Sep 25, 2010 at 8:30 PM
    t4daddy
    t4daddy Well-Known Member
    North Alabama
    2008 PreRunner Double Cab
    Smith makes these as through away guns, after a few hundred rounds you will find all types of problems, springs, feeding, and being able to hit your target down range...
