Significant drop in fuel economy... ideas?
Discussion in 'Technical Chat' started by eltaco, Dec 22, 2011.
  1. Dec 22, 2011 at 8:59 AM
    eltaco
    eltaco [OP] Well-Known Member
    Littleton, CO
    '07 4x4 DC Offroad
    I'm driving (not as I type this) back home to visit family for Christmas and have been getting significantly less gas mileage than what is typical for my truck. I do have 285s on the truck, but have been running them for a couple of years. I typically get between 18-19mpg on the highway, but have only seen 12-14mpg on the 750mi I've driven thus far... what could be causing such a significant decrease?
    Ambient temps have been 22-34F.
    I'm driving interstate at 77-82mph. RPMs are constantly at 2100-2200rpm... flat land so no climbing.
    Loaded with two adults, suitcases and dog.. fairly light load.
    Tires inflated to 29/32.
    Engine and differential oil are fresh. New air filter prior to leaving.
    Truck sounds good and is running strong... no obvious issues.
    Any thoughts?
  2. Dec 22, 2011 at 9:00 AM
    98tacoma27
    Ben
    Not Beech Creek
    Winter gas with the added weight. And your tires seem a little under inflated (to me).
  3. Dec 22, 2011 at 9:02 AM
    chadderkdawg
    chadderkdawg Don't ask questions you don't want the answer to..
    Des Moines, Iowa
    09 FX4 F150
    This too
  4. Dec 22, 2011 at 9:03 AM
    98tacoma27
    Ben
    Not Beech Creek
    Good point. I missed that
  5. Dec 22, 2011 at 9:05 AM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    Speed, tire inflation(which seems pretty low considering they're 285s) winter fuel, and possibly plugs(is it time to change them?) are probably your main issues.
  6. Dec 22, 2011 at 9:07 AM
    himmy33
    himmy33 Well-Known Member
    Washington
    2014 Tundra 1794 edition.
    Winter gas. I saw a sudden drop in my gas mileage as well. I use fuelly and it was amazing to look at the chart and see the difference when they switch to winter blend fuel.
    Check in out
    http://www.fuelly.com/driver/himmy33/tacoma
  7. Dec 22, 2011 at 9:08 AM
    chadderkdawg
    Des Moines, Iowa
    09 FX4 F150
    Is that for real? Whats so different about winter gas?
  8. Dec 22, 2011 at 9:13 AM
    eltaco
    Littleton, CO
    '07 4x4 DC Offroad
    I know the speed is at the top end of what I run... still don't think I've ever seen below 15mpg with my tire pressure as it is currently. What pressure do y'all recommend for 285s while not losing too much winter traction?
    You really think winter fuel makes that much difference? Sheesh... news to me.
  9. Dec 22, 2011 at 9:22 AM
    jeremy_283
    jeremy_283 Super Member
    08 TRD Offroad Access Cab 4x4 Auto 4.0L
    Hella Rallye 4000 Cornering Lights PIAA 510 Fog Lights All Pro Front Bumper All Pro Rear Bumper All Pro Transfer Case Skid All Pro IFS Skid All Pro Rock Sliders All Pro High Clearance Hitch OME Dakar Leaf Springs OME Rear Shocks OME Front Shocks OME 885 Front Coils Wet Okole Seat Covers WeatherTech Floor Liners Sony Head Unit JL XD600/1 Amp 2 JL Audio 10” Subwoofers Custom Subwoofer Enclosure Kenwood Front Speakers Sony Rear Speakers Sound Deadening Mats LED Interior Lighting Pop N’ Lock Tailgate Lock Viper Alarm System Extra D-Rings In Truck Bed Maglite Seat Mount Disable Seatbelt Chime Rear Differential Breather Relocation Hi-Lift Bed Mount Flexible Front Mud Flaps 110v Inverter Always At 400w ABS Kill Switch Locking Center Console Removed Sway Bar
    Have you checked your muffler bearings lately? If your muffler bearings are not properly maintained the EGE (exhaust gas evacuator) will not spin freely and there will be increased back pressure on your pistons and valves causing a larger load on your engine. This causes increased fuel consumption and leads to worse gas mileage.
  10. Dec 22, 2011 at 1:14 PM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Yep thats easy
    Here is your problem
    Where
    [​IMG] is the force of drag,[​IMG] is the density of the fluid,[12][​IMG] is the speed of the object relative to the fluid,[​IMG] is the drag coefficient (a dimensionless parameter, e.g. 0.25 to 0.45 for a car)[​IMG] is the reference area,
    more here
    http://en.wikipedia.org/wiki/Drag_(physics)
  11. Dec 22, 2011 at 8:10 PM
    jeremy_283
  12. Dec 23, 2011 at 1:53 PM
    himmy33
    Washington
    Sure is real. What they do/blend to the gas is beyond me. Not sure what they are adding...
  13. Dec 23, 2011 at 9:37 PM
    MountainEarth
    MountainEarth Well-Known Member
    Bryan
    CO
    2010 TRD OR Access
    Leer 100XR Shell, BedRug mat - comfy sleeping, GT Covers microfiber seat covers, BFG All Terrains 265/70r16, Dashmat, Antennax 13" shorty antenna, Weathertech liners, Ultra Gauge, Avid Light Bar, PIAA 520 ATPs, one old dog
    That's a HUGE drop in MPG. And considering he's running the same tires he's been running for a couple years (with good mileage), the tires or tire pressure wouldn't be it. Nor would oil or diff fluids or air filter (says all new). And witner blends might drop your MPG a couple points, but not from 18-19 to 12-14. So the mystery stands. I'd say the OP has a very legitimate complaint.
  14. Dec 24, 2011 at 8:23 AM
    krap22
    krap22 Well-Known Member
    anyone have a link to this "winter blend" and have proof that it exists?
    i think it has more to do with the low temps and the fuel not atomizing as well as the air is more dense at lower temps so it creates more wind resistance.
  15. Dec 24, 2011 at 8:28 AM
    Warputer
    Warputer Dirt Road Inspector
    Lake Murray, South Carolina
    2011 TRD Off Road
    9" of Super Bro lift
    Even with my stock truck, I've never seen 18/19mpg while driving 80mph.
  16. Dec 24, 2011 at 8:47 AM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    tire pressure does not increase with tire size. Pressure is more of a constant, the volume of air increases but the pressure in a 37x12.5 (be it 29) is the same as a 225/75 at 29...its just an increase/decrease in volume.
    Shit my tires are at 20 psi in order to pass the chalk line test. And I get 24 mpg, 4 cylinder
  17. Dec 25, 2011 at 3:03 PM
    eltaco
    Littleton, CO
    '07 4x4 DC Offroad
    Thanks... this was my thoughts exactly. I only provides all that info in case something sounds way off.
    I drove one stretch of highway at 45mph due to snowy conditions, and I pulled 15.8mpg through that section... still nowhere near normal for me.
    I'm headed back home tomorrow, I'm assuming everything stays the same, unfortunately. This trip got a lot more expensive than I anticipated at 2000 mi round trip.
  18. Dec 25, 2011 at 3:33 PM
    tx novice
    tx novice Foward momentum
    Ron
    OAHU
    11 DC 4X4 TX PRO silver
    Trd, Cal Tech, Weather tech, Viper, Al's tinting . L.E.D's , Hide a Hitch or Chrome Stinger , Walker Evans Resi's w/AllPro 3" lift ,FLM, ProComp Xtreme MT2 , Diff Breather Mod, 4x4 Switch Light mod, Plastic Derped. Trailer Socket Relocate mod via Miles , 4:56 G2 gears. Blue Intake Spacer, S.S. Brake Lines F&R, Sway Bar Deleted, Roll-X, Pop-N-Lock Electric. Red metal TRD badges. Paid Off Mod- Chee Hu, Superbumbs(f),Timbrens(r).Pelfrey Bilt, Bamf, Urd. Cobra Heat Shield.CMC .Mishimoto (custom bracket by Nate), Powerstop, Rampage 50".Depo Taillights,SPPC Black Headlights, Rigid Industries. Factor 55.American AirFlow.
    :D yeah and check your turn signal fluid too. Oh , and your piston return spring . You might not be getting enough torque from your engine .
  19. Dec 25, 2011 at 4:48 PM
    2008taco
    2008taco Well-Known Member
    chris
    san diego
  20. Dec 25, 2011 at 5:08 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    OP, how are you measuring the MPG?
