Silly Question: Removing Glove Box
Discussion in '2nd Gen. Tacomas (2005-2015)' started by RiverRatMatt, Feb 6, 2011.
  1. Feb 6, 2011 at 4:22 PM
    RiverRatMatt
    RiverRatMatt [OP] Member
    Idaho
    2010 Tacoma 2.7L 4x4 Manual Transmision
    1986 Front Tow Hook Yellow Wire Mod Fan squeak fix
    I have a 2010 Taco and am doing the Yellow Wire Mod and fixing my blower motor squeak, but I'm having trouble removing my glove box.
    I got the semi-hydraulic lowering assist arm off, but I feel like I'm going to break something when I try to pop off the hinges on the bottom.... what am I doing wrong?
  2. Feb 6, 2011 at 4:32 PM
    B_brand
    B_brand Well-Known Member
    Brandon
    Oklahoma
    I have a 2010 as well and removed the glove box a while back to fix the blower motor. After you remove the spring loaded arm you should be able to pop the glove box out. Mine took quite a bit of force before it came out though.
  3. Feb 6, 2011 at 4:33 PM
    flightcancled
    flightcancled Addicted
    Syracuse NY/ Nantucket MA
    Camper top with racks, Custom fogs behind lower bumper. Interior LED lighting, Rock Lights, Hella 500s with upraged bulbs behind black billet grill, AAL, Front 5100s
    If you push the walls inward it will help pop it loose the first few times.
  4. Feb 6, 2011 at 4:34 PM
    Max-4_Yota
    Max-4_Yota The Welfare Cadilac
    Michael
    South Carolina
    3rd gen Tacoma
    Chicken lights, chrome and smoke tunes.
    On alot of vehicles you have to open the glove box and push the sides in to remove it.
  5. Feb 6, 2011 at 4:36 PM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    The piston will need a little force to remove, you'll be alright. Sometimes putting it back in is the hard part though.
  6. Feb 6, 2011 at 4:40 PM
    RiverRatMatt
    Idaho
    Just a quick update, for today I decided to just do the yellow wire mod, and to do that all you need to do is push in the walls of the glove box, let it rotate downward and it will give you enough room to reach in and snip the wire :)
    Will have to remove it for the blower motor regreasing.... that sound drives me nuts!
  7. Feb 6, 2011 at 4:42 PM
    jdkeller
    jdkeller How many words can be fit in this s
    Jonathan
    Inland Empire, Ca
    2008 Tacoma Prerunner TRD Offroad
    Dome light LED, 6000k HID Headlights and fogs, Grillcraft black mesh, rear 5100's, Total Chaos UCA's, 285/75/16 BFG KM2's, Spidertrax spacers, Blacked out emblems, cb,kenwood tm270 ham radio, All Pro 3" leaf pack, Fox 2.0 coilovers, Revenge Fab Sliders, u bolt flip kit, Pioneer avh4200, bed bar with light and antenna, Wet Okoles, Weathertech Mats, Wet Okole Armrests, Rear KR Fab bumper, bed mat, N-Fab spare tire carrier with full size spare on 16" TRD rim, Bedlinered flares and grille. Camburg Spindles, All Pro front fenders.
    What is this yellow wire mod?
  8. Feb 6, 2011 at 8:46 PM
    island808
    island808 Me l've got brains.
    Jedediah
    hawaii
    '10 6speed 4x4 access cab
    a different thread.
  9. Feb 6, 2011 at 9:03 PM
    jdkeller
    Jonathan
    Inland Empire, Ca
    So it's not a mod to get rid of that blower noise?
  10. Feb 6, 2011 at 9:45 PM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    Your cabin air filter is there, too... Replace it if you been in dust!
    Yes, it snaps off and on at the hindge points, after you remove the little strut on one side... thats the hydraulic thing.
  11. Feb 7, 2011 at 10:03 AM
    island808
    Jedediah
    hawaii
    interesting fact, neither my wife's or my toyotas have the filter in them. Checked out hers the other day due to excessive blower noise.. empty compartment. Checked mine to find the same. Maybe they forgot, maybe its a regional option.
  12. Feb 7, 2011 at 10:40 AM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
    Thats weird, you should have a filter in there. Not a regional option as far as I know.
  13. Feb 10, 2011 at 6:43 PM
    dwr80
    dwr80 Well-Known Member
    My question is... the little piston arm.. how do you get that back? Just had to fix satellite recv'r which was behind under the glove box and having a hard time installing that little piston thing.
  14. Feb 10, 2011 at 6:56 PM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    to remove the glove box, press in sides, it swings down disconnect the absorber on the box and you can just pull it off the lower hinge, be careful but itll come off...
    the reistall the shock, i used a piece of string/fishingline through the hole. Once you put the glove box back you can use the string to pull the top loop to the top mount. once its on, the string just slides right out
    JD, yellow wire mod lets my truck kick your trucks butt. :p
  15. Feb 11, 2011 at 7:41 AM
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    I posted pics of the whole process of removing the glove box to get to the filter here:
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/137493-cabin-filter-change.html#post2684203
    To reattach the piston to the glove box, simply pull it out (extend it) with your fingers before pushing the glove box back up and slide it on (or use a pair of pliers after the glove box is almost closed...this is the easier method).
    Just FYI to all,
    Remove the piston from the glove box side. If the piston comes off the dash end, you probably need to install something between the tabs on the dash end to keep them spread and holding the piston on. It's a common problem. You'll see I used a screw (5 years ago) while others have used 3M tape in the slot instead of a screw.
