Simple CB Antenna Mount
Discussion in '2nd Gen. Tacomas (2005-2015)' started by HBMurphy, Jul 27, 2009.
  1. Jul 27, 2009 at 6:17 PM
    HBMurphy
    HBMurphy [OP] Ban Pending
    Paul
    So California Coast
    09 Off Road Delete Model
    None
    I wanted a simple antenna mount so here it is:
    Using the FireStik Fire Ring and the following parts:
    1 - 3/8" 24 TPI 2" stainless bolt ($2)
    1 - 3/8" SS washer ($0.30)
    1 - 3/8" coupling (SS if you can get one - I couldn't today) ($3.29)
    Drill out one of the holes in the bedside cleat to 3/8".
  2. Jul 27, 2009 at 9:11 PM
    j4x4ar3
    j4x4ar3 Well-Known Member
    Jay
    Austin, TX
    05 DC 4x4 - TRD Off Road - White
    Round Step Bars, Bed Mat, Cargo Bars, Rocky Mounts bike mount, JVC MP3 Head Unit, TRD Cat Back Exhaust, Rigid Industries front and rear light pods, dual HAM radio with remote mount heads.
    Cool idea makes it easily removable if you need to.
    Are you using the Firestik that doesn't require any ground plain? Model: FG3-648
  3. Jul 27, 2009 at 9:11 PM
    rab89
    rab89 Well-Known Member
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    i sure hope so!
  4. Jul 27, 2009 at 9:27 PM
    HBMurphy
    Paul
    So California Coast
    None
    I haven't hooked it up yet. My thoughts were to use one of these
    And ground the bolt to the chassis. Am I on the right track? - I was trained as a rocket scientist - Not an RF engineer. ;)
  5. Jul 27, 2009 at 9:31 PM
    HBMurphy
    Paul
    So California Coast
    None
    I was reading to use a min of 12 gauge for the ground... I was thinking bird shot?
  6. Jul 27, 2009 at 9:35 PM
    j4x4ar3
    Jay
    Austin, TX
    Glad I asked the question. Don't even try to ground it using the method you're thinking about. The rails bolt into the bed which are composite so there's no real place to run a ground wire. If you try to run any length of cable to a groundable site then you'll screw up the tuning on the antena big time. Your best bet is to go with the Firestick II no ground plane antena and save yourself the hassle.
    I like the mount idea though and might use it myself instead of drilling holes into the bed.
  7. Jul 27, 2009 at 9:36 PM
    HBMurphy
    Paul
    So California Coast
    None
    Thanks!
  8. Jul 27, 2009 at 9:41 PM
    HBMurphy
    Paul
    So California Coast
    None
    So this wouldn't work?
    From FireStik
    Also, keep this in mind. If it becomes necessary to run a ground wire or braid to a chassis ground point, use a wire of at least 12 gauge. We have reviewed installations where the installer used a small gauge wire (20ga) and when the SWR was tested it fell from over 3:1 to below 1.5:1. However, the power out put was very low due to the undersized path to ground provided by the thin wire. The path to ground must be sufficient enough to carry the power being applied to the antenna.
    I have the antenna cable running along side of the frame rail so my thought was to run a ground wire from the bolt to the frame.
  9. Jul 27, 2009 at 9:46 PM
    HBMurphy
    Paul
    So California Coast
    None
    Even better - just read the description of the antenna I already have - FireStik II = Sweetness! So, no need to ground?
    edit - Not so fast there Murphy! - That's not a NGP model!
  10. Jul 28, 2009 at 12:41 AM
    DDD
    DDD Shine bright like a hymen
    Derek
    Santa Clarita, CA
    This really is a good idea. I had to make a bracket that would connect to the track on the bed side. This would have been much easier.
  11. Jul 28, 2009 at 11:12 AM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    Great job!
  12. Jul 29, 2009 at 4:11 PM
    HBMurphy
    Paul
    So California Coast
    None
    Okay - I'm probably glad I didn't hook it up but here's the scoop from FireStik...
    "If you ground the only bolt I see in this photo you will short the antenna and it will not work ... will cause high swr that will harm the radio. Multiple problems here. The composite bed will not supply the counterpoise requirement (ground plane ... not to be confused with chassis ground). And it is the mount, not the antenna, that requires grounding. The only "remote" chance of this set up working would be if the slide rail is metal and is chassis grounded and the mount in the channel is metal so that it is chassis grounded via the slide rail. If so, you'd still have problems because the antenna stud mount is not insulated from that bracket it is affixed to. Even then ... there may not be enough ground plane to allow a standard ground plane dependent antenna to work. Wish we had the opportunity to discuss these issues before you got this far.
    You have a ground plane dependent antenna. These require both metallic mass and a grounded mount (typically grounded via the typically metal cargo box). Worked with a gentleman last week on same truck and left him with the following options ...
    1. Roof Mount
    2. Hood Channel Mount
    3. No-Ground-Plane antenna system on box. More on No-Ground-Plane
    I suspect that if you put an SWR meter on this install that you would find it very high and un-adjustable.
    If you moved to a hood channel installation you could salvage the antenna and the coax but would need a hood channel mount (SS-17 ... mount without shown stud) and a FireRing antenna stud mount. "
    I guess simple is as simple does!
  13. Sep 20, 2010 at 7:58 PM
    milo39
    milo39 Well-Known Member
    myles
    downey,ca
    07 doublecab prerunner trd off road
    looks awesome
  14. Sep 20, 2010 at 8:01 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    very nice mount
  15. Sep 20, 2010 at 8:18 PM
    Badwin45
    Badwin45 Well-Known Member
    OKC
    '10 DC 4x4 & '00 Pre-Runner
    Aries 4" Oval step tubes, Brute Force Fab rear bumper, Weathertech digifit floor liners.
    Were it me, I'd go with a magnet mount and place it on the roof. There are several that will work with your firestick.
    I used to run a Wilson 1000 magnet mount on mine and was always well pleased with it.
  16. Sep 20, 2010 at 8:49 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    Taylor helped me install mine, we mounted to the bed rail via the supplied bracket with the firestick it, got some mirror fasteners at Home Depot, drilled them out for the larger bolts, used some wing nuts... and walla a great removable setup in the bed rail. Of course, it's grounded to the body in the back. I can try and get some pics...
    SWR is great too, about 1.5 on chan near 1:1 on 40.
