Simple how-to: fix that crappy door trim
Discussion in '1st Gen. Tacomas (1995-2004)' started by scocar, Apr 29, 2011.
  1. Apr 29, 2011 at 10:45 PM
    scocar
    scocar [OP] hypotenoper
    This seems to be a pretty common issue on the first gens: the flipping stupid piece of trim at the bottom of your driver side window. There it is, every stinking time you get into the truck. All flaky and alligatored, "chrome" shining out from the black, uh, what is that stuff, anyway? Paint? Rubber? WTF? And if I pull this stuff off, am I going to break a bunch of little clips?
    Turns out, it is an extremely thin layer of rubber on top of aluminum. In sunny, hot regions, the rubber just cooks off after about a 100k miles. Not only that, but I realized the part that wipes against the glass had also become stiff and deformed away from the glass, allowing water to get inside the outer door. Bad. Some people just take this trim off and paint it black, but that won't fix the bad seal against the window.
    It is pretty damn ghetto (not that ghettos are bad). But it is an easy fix.
    Here are the part numbers for the Xtra cab, anyway. About $30 from the dealer. They call it weatherstrip:
    Note: others point out that you can do this without removing the mirror. I had never done this before, so I was picking it apart carefully to avoid breaking stuff.
    Anyway...enjoy.
    Pop off the little piece of plastic trim next to the mirror inside the door. Use a plastic putty knife or something similar.
    [EDIT: Others have said it is not necessary to remove the mirror. I removed it simply because I had not done this before and was being cautious.]
    This is what it looks like behind it. You aren't going to break anything.
    Remove the mirror nuts:
    Pull the mirror away to expose the front of the trim:
    Grasp the weatherstrip from above and pull upward. You are popping off three white clips. You might break one if you aren't careful, but the new parts include all the clips:
    Here's another shot:
    This is how the back end comes apart. The bottom piece slips into the rest of the weatherstrip:
    Installation, as usual, is the reverse. Start from the back forward.
    To help prevent this new rubber from going bad, I am applying 303 UV protectant on it after each wash.
    Final step, insert beer:
  2. Apr 29, 2011 at 10:53 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Well done!
  3. Apr 30, 2011 at 7:50 AM
    twfsa
    twfsa Well-Known Member
    Tom
    Omaha Ne
    04 TRD 4X4
    881 Front coils, Bilstien 5100's all the way front set to "0" Icon Dynamic's mini leafs in rear, stock tires.
    Nice write up!
    KilroyIsHere likes this.
  4. Apr 30, 2011 at 7:55 AM
    johnw
    johnw Well-Known Member
    john
    orlando florida
    06 prerunner v-6 4.0L 4 door
    well you asked for specs..... 06 trd sport speedway blue 5.3l v8 4.0 camburg lift spindles extended travel icons total chaos lowers allpro 4" leaf pack 17" xd hoss rims 37/12.5/17 mickey thompson baja atz Allpro hybrid bumper grill craft grill wicked flow muffler inside i have..... wet okole real tree camo seat cover blue oznium dome light stealth sub box with 2 10" kicker comp subs kicker 400 watt amp weathertech floor mats
    now do it on the 2nd gen so i can do it lol
    xguntherc likes this.
  5. Apr 30, 2011 at 11:19 AM
    brelandt
    brelandt Well-Known Member
    Terry
    Dublin, CA
    04 Prerunner reg cab SR5
    3" lift front and back
    every 6 months or so I apply silicone on all my rubber trim parts including the weather strip. The truck is a 2004 and the rubber feels and looks brand new still. hopfully that helps others with keeping their new trim in perfect condition?
    Nice write-up!
  6. Apr 30, 2011 at 11:25 AM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Donahoe CO, Donahoe Rear Resi, Deaver J59, 16" Pro Comp, 33" BFG AT, Hayden Trans Oil Cooler, Oil Filter Relocator, FM 40, ES Bushings, Beefed CB Drop, Deckplate, K&N Drop-In, DO Bed Bar, Cobra 75 WXST, Firestik Firefly, Philips D1R, Clarion Remote Start, Husky Liners
    Nice write up but it's not necessary to loosen or remove the side view mirror to install these. Simply pull the old ones off (no worrying about breaking clips as the new ones come with them) starting from the rear. Then slide the new ones on under the side view mirror, line up, & snap into place.
    I have a double cab & it's the same for rear.
    Local dealer wanted $34 each. Get them from an online sales dealer for $17ea. Conicelli offers free shipping on orders over $100 & is where I got mine.
    KilroyIsHere, Hamer95USA and Jetrell like this.
  7. Apr 30, 2011 at 8:26 PM
    rab89
    rab89 Well-Known Member
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    AWESOME! I have been wanting to paint mine, definitely doing this though!
    cruxofthebisquit likes this.
  8. Apr 30, 2011 at 11:54 PM
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    Great write up! I haven't noticed it but ill check tomorrow!
  9. May 7, 2011 at 2:49 AM
    onesixseven
    onesixseven Well-Known Member
    Tyler
    Santa Clarita California
    02 Prerunner SR5
    3.5" Kind Coilovers Total Chaos UCA's 31" BFG A/T's 8000k hi/lo HID kit Flowmaster Super 44 5% tint all around exterior LED's Deck Plate Mod bedlined flares debadged Full Fosgate/JL Audio Stereo
    dude i f***ing love u and in conjunction this website. been wondering how to replace, and now i am doing that next week! awesome write up!
    JohnnyCash57 and Atowns40 like this.
  10. May 7, 2011 at 6:09 AM
    Yamaha Dave
    Yamaha Dave Well-Known Member
    AWESOME AWESOME AWESOME! Mine has a little sun damage and it's always bothered me. I think I'm going to do mine now. Thanks!
  11. May 7, 2011 at 8:54 AM
    scocar
    Glad you guys are finding this helpful. I can feel the love. In fact, it feels a little damp and sticky in here.
    ToyotaJim and GQ7227 like this.
  12. May 7, 2011 at 10:21 AM
    Supra TT
    Supra TT Supercharged Lifter
    Eric
    Indiana
    2000 SAS D60 F/R Supercharged
    Supercharged on One Tons
    That's the humidity, not what you are thinking. Haha. :eek:
  13. May 7, 2011 at 10:29 AM
    jesus
    jesus Well-Known Member
    jesus
    bakersfield
    K&N ram intake & doug exs.
    Great job....
  14. May 7, 2011 at 10:33 AM
    Watari06V6
    Watari06V6 Faster than a speeding ticket
    Wounded Knee
    TRD-V6-SR5-06
    awesome tip- TY!:D
  15. May 7, 2011 at 10:33 AM
    scocar
    Coming from Jesus, that means a lot.
  16. May 7, 2011 at 7:45 PM
    Scott78
    Scott78 Well-Known Member
    Scott
    Flagstaff, AZ
    '19 OR DCLB
    +1 cred
  17. May 7, 2011 at 10:46 PM
    TacoBlitz
    TacoBlitz Well-Known Member
    Jake
    Omaha, Nebraska
    01 DoubleCab SR5 TRD, white
    Topper, Yakima Racks, Yakima Loadwarrior roof basket (lights all around) 20% window tint (all 4 doors), Spectre ProFab Air Intake System, Black grille, Rino Lined rocker panels, rear bumper and flares Suspension: New OME 881 coils and OME 5 leaf rear springs, Blilstein shocks and struts, Daystar Greasable lift shackels Extended rear brake line
    Thanks for the info. this problem has been bugging me for a while, didnt realize that there would be this easy of a solution. thank you!
  18. May 21, 2011 at 7:22 PM
    duckfan
    duckfan Well-Known Member
    '01 Doublecab Prerunner
    I just replaced my fronts this morning. It's really easy. Thanks to OP for the how-to. I didn't need to loosen the mirror, just slide the trim under it.
  19. May 26, 2011 at 2:39 PM
    onesixseven
    Tyler
    02 Prerunner SR5
  20. May 26, 2011 at 2:52 PM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    medic2230 and cruxofthebisquit like this.
