Simplified Guide to Traction Controls (TRAC, AUTO LSD, TRAC OFF, VSC OFF)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by David K, Dec 9, 2016.
  1. Dec 12, 2016 at 9:39 AM
    David K
    David K [OP] Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    How did you get out?
    Rear locker no help, I would guess?
    The front tires don't look stuck and with just one front tire with traction, the A-TRAC can pull the truck out.
    Did you turn the front tires left and right while attempting to drive (so they could grab at fresh soil)?
    Next time: try just feathering the gas in A-TRAC to simulate what CRAWL control does on the 2016+. The system rotates different tires to find which ones have traction... Just go slow.. never give up!
  2. Dec 12, 2016 at 9:49 AM
    Bannerman
    Bannerman Tasteful Thickness
    Johnson
    Charlotte, NC
    22 Tremor 402A, 22 T4R ORP
    Yeah it was slick as owl shit. I just had another truck pull me out, I was starting to scratch my back wheel pretty bad from some small rocks in the soil. More wheel speed to clean the lugs may have done it but there was just zero traction. It had been raining for about two weeks and I forgot that we had dug a hole there with the bobcat about 9 months before. What was the hole for you may ask? Well we buried a dead mule there. :)
  3. Dec 12, 2016 at 10:55 AM
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 SUPERCHARGED DCLB TRD SPORT
    We got some snow around here, and was really impressed with the AUTO LSD in 2WD from a stop.
    Made a stop at an intersection, when it was time go, the wheels just spun. Turned on the AUTO LSD and took off with ease.
    I have a question...
    If I hold the the button, turns off TRAC and VSC, am I pretty much running with open diffs?
    Is AUTO LSD possible in 4HI and 4LO?
    With the AUTO LSD, am I only limited to certain speed?
  4. Dec 12, 2016 at 11:04 AM
    David K
    Wow-zers! Glad you didn't bring up the mule (out of the grave)!
    I have heard that East Coast clay is pretty bad... maybe tires were more of an issue? It seemed odd your front went through without them getting stuck (where all the weight is) but the back end dug in? Almost like you were in 2WD at first, and that only the back tires spun??
    Thanks for sharing! I have done clay-like mud on a (usually) dry lake bed in Baja. I had mud tires on, and that probably helped (Cooper Discoverer STT). Most often the mud I cross is sea water filled mangrove mud, again in Baja. Never stuck in it... fortunately.
  5. Dec 12, 2016 at 11:11 AM
    David K
    Looks like three questions, so I am adding letters to help:
    a) If you stop the truck and press and hold-in the button for a few seconds, you go into VSC OFF mode. That is turning off the VSC and TRACtion controls... so yes, like open differentials and no limited slip.
    b) No, AUTO LSD is only in H2. In H4 it is called TRAC OFF (but essentially is the same thing as Auto LSD). In L4, the ONLY traction system is A-TRAC and MTS, on the Off Road TRD only.
    c) AUTO LSD stays on until you press the button again or restart the truck. The VSC goes off until you reach a speed of 30 mph, in AUTO LSD. I do not know if the same is true of TRAC OFF in H4?
  6. Dec 12, 2016 at 11:15 AM
    David K
    How about a favor to ask of you all with 2012 or newer 4x4 Tacomas?
    When you press the VSC OFF button in H4, you get a light 'TRAC OFF', yes? Do you also get the VSC OFF indicator (car with wavy lines)? Does it go out at 30 mph, as it does in H2 with Auto LSD?
    Thank you!
  7. Dec 12, 2016 at 1:06 PM
    Bannerman
    Johnson
    Charlotte, NC
    I can check on this for you.
  8. Dec 12, 2016 at 1:08 PM
    Bannerman
    Johnson
    Charlotte, NC
    Yeah I think thats what happened, I was in 2wd to begin with. I had brand new KO2s on but they just clogged right up with the red mud. They are great for alot of conditions but you really need a dedicated Mud tire for stuff like that.
  9. Dec 12, 2016 at 1:47 PM
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    2015 Tacoma DCLB Better Than TRD
    See Build Page
    You.... don't have ATRAC. You have a 2015.
    :facepalm:
  10. Dec 12, 2016 at 1:47 PM
    Bannerman
    Johnson
    Charlotte, NC
    You.... are wrong. Are you confusing ATRAC and Crawl Control?
    Norton likes this.
  11. Dec 12, 2016 at 1:50 PM
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    See Build Page
    Guess I'd thought ATRAC was added into 3rd Gens. Probably am thinking crawl control. That's what I get for posting while at work.
    Doesn't matter though cause I got air lockers front and rear. :D
  12. Dec 12, 2016 at 1:55 PM
    D-Rose
    D-Rose Well-Known Member
    Devon
    Las Vegas, NV
    2011 dcsb tx pro
    I just got a 4x4 and am coming from a 2wd off road package. I do mostly higher speed desert stuff. In my last truck I would just Lock the rear diff but I've read you can't lock it in the 4x4 unless you're in 4lo. I'm guessing my best setting would be 4hi with the Vdc held down?
  13. Dec 12, 2016 at 2:30 PM
    David K
    I thought so!!! ALWAYS go into H4 when you leave the pavement... even if only to "lube" the parts.
  14. Dec 12, 2016 at 2:35 PM
    David K
    Well, if you want locker traction, that is meant for slow crawling/ climbing... so L4.
    If you were locked just to scream across the desert, then the 4x4 won't lock in anything but L4. However, there is a "locker anytime" mod. Just search TW.
    H4 with VSC (Vdc?) turned OFF (stop and hold in 3 seconds) is 'no limited slip' and 'no stability control'... unless you drive dangerously, then they will come on automatically to keep you from rolling.
  15. Dec 12, 2016 at 2:36 PM
    #35
    David K
    A-TRAC was available on all 4x4 Off Road Tacomas beginning in 2009.
    Norton likes this.
  16. Dec 12, 2016 at 5:45 PM
    #36
    Bannerman
    Johnson
    Charlotte, NC
    Yeah ATRAC has been around in various forms for at least 15 years.
  17. Dec 12, 2016 at 5:52 PM
    #37
    David K
    Y
    Yes, it has been on other Toyota and Lexus vehicle before it was added to the Tacoma in 2009.
  18. Dec 12, 2016 at 5:58 PM
    #38
    DVexile
    DVexile Exiled to the East
    Ken
    2015 DCSB V6 TRD OR 4X4
    Just to clarify - short press results in *more* traction control than normal and long press results in *less* traction control than normal. Do I have that right?
  19. Dec 12, 2016 at 7:59 PM
    #39
    David K
    Yes... and yes, but actually no control at all.
    DVexile[QUOTED] likes this.
  20. Dec 14, 2016 at 11:34 AM
    #40
    ccallen
    ccallen Well-Known Member
    Chase
    Missoula Mt.
    2016 tacoma TRD Off Road BBP
    SCS SR8's 17" TRD Adventure Edition
    So I've read through most of this but still a little uncertain. Please forgive me. I'm trying to find out if you can totally shut off traction control it might be more than that. I have a 2016 TRD Off road. What I'm trying to achieve is the ability to play around in 2wd you know be able to spin it in the snow kinda stuff. But, even when i hit the traction control button to turn it off it still kicks in when i go to get sideways.. Please and thank you for all the help! Sorry if i missed this in a previous post. Cheers!
    trabo likes this.
