Single axle vs dual axlw RV Towing?
Discussion in 'Towing' started by HabFanTacomaOwner, Jan 27, 2011.
  1. Jan 27, 2011 at 6:14 PM
    HabFanTacomaOwner
    HabFanTacomaOwner [OP] Member
    Ontario, Canada
    '10 DBL Cab TRD Sport 4X4, Long Bed Auto
    Stainless step tubes, Trifecta tonneau cover so far
    Can anyone provide some insight from experience in pulling something around a 22 ft TT (actual total length), in the 3500 - 3800 lb (loaded) weight range, with a single axle? I've heard stay away from single axle for this length, but apparently this trailer's weight allows a single axle to be adequate. We're looking at the Gulf Stream 19 RSD, in case you're familiar with it.
    Much appreciated!
  2. Jan 31, 2011 at 8:06 PM
    "OLYMPIC VIEW"
    "OLYMPIC VIEW" Well-Known Member
    WHIDBEY ISLAND, WA
    2011 TRD SPORT D/C LB...1987 SR-5 4WD XCAB
    The tandem axle will track much better and will not sway as bad in high winds/poor weather conditions as the single...If it has the Dexter axles and they are rated for 3500-3800 #'s then you should be alright, also check the spring pack and make sure it's adequate...does it have shocks? We had an Arctic Fox TT that had shocks and springs both, helped absorb bad road conditions and eliminated some of the bounce if the trailer was not loaded properly all the time...maybe go up a size if the floorplan is okay and get the tandex axle...?? Good luck---
