Single inlet dual outlet exhaust for 2.7
Discussion in '4 Cylinder' started by BobcatSR, Jul 6, 2020.
  1. Jul 6, 2020 at 10:10 AM
    BobcatSR
    BobcatSR [OP] Well-Known Member
    2021 Trail Edition AG 2017 DCSB SR (Sold)
    4" Maxtrac Spindles 17x9 Bronze Fuel Blocks 285/70r17 Toyo Open Country at3 MBRP Dual Exhaust ME-S0 Climate Control Rings Pool Ball Shifter & TRD Boot Collar Cap Demon Hooks Viofo A119 V3 with Dongar RockyMounts LoBall
    Hey everyone! Is there such thing as a y pipe/single inlet dual outlet exhaust system offered for the 3rd gen 2.7?
  2. Jul 9, 2020 at 11:02 PM
    69 Jim
    69 Jim 4-word Jimmy
    PNW
    2013 Standard Cab 4x4
  3. Jul 10, 2020 at 7:31 AM
    BobcatSR
    That link isn't working for me and a google search isn't yielding any results. Is this company still around?
  4. Jul 11, 2020 at 7:42 PM
    BobcatSR
    Ah gotcha. Alright. Someone in another thread just ran the possibility by me that the v6 and 4 cyl cat back systems could be interchangeable on the 3rd gen. How they sound on the 2.7 is an entirely separate beast but its a start! I'll also consider checking in with the local shops. Thanks for the help man.
  5. Jul 11, 2020 at 7:53 PM
    suaveflooder
    suaveflooder Well-Known Member
    2021 4Runner Venture
    Do it at the muffler?? There are single inlet duel outlet mufflers available.
    Wulf likes this.
  6. Jul 20, 2020 at 3:58 PM
    jeffmansion
    jeffmansion Well-Known Member
    16UTILITY4x4MT2.7
    K&N 63 series CAI, AVS Vent Visors, 16x8 Level 8 MK6 Rims, 285/75/16 MT, Eibach Pro lift, JBA UCAs, Wheelers 3leaf AAL, DV8 skidplate, Westin bedmat, Backrack, swaybar delete, Magnaflow cat-back, 9Drive throttle controller, 2LO Mod, Cali Raised Rock Sliders, Tyger rear bumper, Chinese Body Armor front bumper clone, 10K pound Winch, Smoked headlights, LED Bulbs.
    @BobcatSR any updates on the exhaust? I like the duals idea.
    BobcatSR[OP] likes this.
  7. Jul 21, 2020 at 10:49 AM
    BobcatSR
    Nothing yet! I stuck my head under the truck a while back to see if the exhaust flange between the cat and the muffer was in the same spot on the 2.7 as it is on the 3.5. I'm hoping I can just grab a whole v6 catback y pipe exhaust system from one of the big manufacturers instead of having to piece together a whole custom catback system, but I'm going to have to get some measurements instead of just trying to eyeball it.
    jeffmansion[QUOTED] likes this.
  8. Jul 29, 2020 at 10:03 PM
    trustyrusty436
    trustyrusty436 Well-Known Member
    2018 Tacoma, auto, 2.7, RWD Access cab, long bed, Utility model
    LCE exhaust header, AF Dymanics CAI, MagnaFlow cat back
    Putting a exhaust from a v6 on a 2.7 can cause a drop in low end torque, this not good, it's about all you have anyway. I put a 3" pipe on my 2.7, it ran like crap, gutless till about 3500 rpm. You may want to talk to a local muffler shop about this, as the tuning is really easy to mess up on these 2.7!
  9. Jul 30, 2020 at 6:58 AM
    BobcatSR
    Thanks for the heads up! I'll be sure to look into this! :thumbsup:
  10. Aug 28, 2020 at 2:51 PM
    KanakaRebel
    KanakaRebel Well-Known Member
    Kauai, HI
    2009 Tacoma 4x4 Single Cab
    Just look at flowmaster or magnaflow mufflers online, you can choose the option of dual outs. All you’d need to do is have an exhaust shop fab up a new cat back system for you, probably have to fab up some new hanger mounts on the drivers side for the next pipe coming out from that side if you’re doing one exhaust on either side of the truck.
  11. Oct 2, 2020 at 10:44 AM
    jeffmansion
    16UTILITY4x4MT2.7
    I called a local shop today that has done exhaust work for me in the past. He said duals likely would not be do-able on a tacoma without removing the spare tire. I have an oversized spare too.
    Not sure how credible his claim is, but thought I'd share.
    BobcatSR[OP] and KanakaRebel like this.
  12. Oct 17, 2020 at 3:41 PM
    KanakaRebel
    Kauai, HI
    If your spare has a tpms sensor, wouldn’t removing your spare cause the tpms light to be constantly on? There’s a lot of guys near me with 2nd and 3rd gen Tacoma’s with dual outs, I’ll check with them to see if they had to remove their spare, whether it be an oversized tire or not. I’m in no means an exhaust specialist, but unless you couldn’t do a 90 degree bend in front of the rear axle for some reason, whether it be something in the way or flow wise, I don’t see why it couldn’t be done.
