Siping Tires... How Much Improvement?
Discussion in 'Wheels & Tires' started by eltaco, Oct 9, 2009.
  1. Oct 9, 2009 at 8:50 PM
    eltaco
    eltaco [OP] Well-Known Member
    Littleton, CO
    '07 4x4 DC Offroad
    Winter is upon us, and I'm considering siping my tires as opposed to getting new ones. I have a set of Pro Comp Mud Terrains with a lot of tread left on them, however, they are terrible in the winter.
    I'm curious about siping; never have done it before. What kind of difference could I expect from siped tires as opposed to non-siped mud terrains? If it's not a huge difference, I guess I'll be dropping $850 on some BFGoodrich A/Ts.
  2. Oct 9, 2009 at 9:32 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Siping makes a huge difference in wet weather traction. Im not sure in snow, but I siped my MTR's on my M-37, and the difference was night and day in the wet.
  3. Oct 9, 2009 at 9:50 PM
    WATRD
    WATRD Keyser Soze
    Rob
    Duvall, WA
    '01 S/C SAS TRD
    WATRD.com
    There is a big gain in traction, as well as heat dissipation. It's most obvious when you sipe a mud terrain with big blocks, rather than an all terrain where there are more edges for contact anyway.
    The effect is most pronounced on ice and rock, as well as other hard, slick surfaces, but you will see an improvement across the board.
    The downside is that it is easier to knock chunks out of the tires, so be prepared for that. It's most cosmetic, but it looks ugly.
    Well worth it, in my opinion.
  4. Oct 9, 2009 at 9:58 PM
    cheehab
    cheehab I bleed Black and Gold
    Adam
    Winter Park, CO
    2015 Tundra TRD Pro CrewMax
    The guys at my local shop swear by siping on MT's. For $15 bucks a tire, it sounds well worth it to me. I'm too much of a chickenshit to cut into $800 of tires, so i bought AT's.
  5. Oct 9, 2009 at 10:19 PM
    jeremiekc
    jeremiekc Well-Known Member
    Jeremie
    Vilseck, Germany
    07 Regular Cab Base Model
    Secondary Air Filter removed, Painted Brake Calipers, AFN Drop in air cleaner, OEM Chrome Bumper, OEM Chrome grilll, OEM Cruise Control, OEM Interval Wipers, Hard Wired Garmin Nuvi 670, X-Runner Rims, Devil Horns, 6000w HID's, Bling Light Fogs with Blue Halo, OEM Bilstein Rear Shocks, 12V Plug in Truck Bed pocket. Debagged, 13" Antennax, Color Matched Satoshi Grill, URD Short Shifter, WeatherTech Floor Mats, PainLess Wiring Switched Fuse Box, Black Sand Pearl X-Runner Badges
    It is definately the way to go, especially if you live in a snowy climate. I have driven on studs and All weathers and none of them beat the traction and response from a set of sipped tires. For the price you really can't beat it.
  6. Oct 9, 2009 at 10:56 PM
    Zac808
    Zac808 Custom User Title
    Zac
    Viva Las Vegas
    08 TRD DC SB 4x4
    In my sig
    Siping will make them wear a hell of a lot faster when dry.
  7. Oct 10, 2009 at 6:05 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Not nesesarilly. Siping also allows the tire to more easilly cool down, or run cooler, extending its life.
  8. Oct 10, 2009 at 6:10 AM
    gupster88
    gupster88 Well-Known Member
    Brett
    Almost Heaven, WV
    2021 Cement Grey Off Road
    Stock
    siping is the way to go for sure. just know that many manufacturers will void the warranty of the tire if they are siped.
  9. Oct 10, 2009 at 6:36 AM
    WATRD
    WATRD Keyser Soze
    Rob
    Duvall, WA
    '01 S/C SAS TRD
    WATRD.com
    Not true. In fact siped tires tend to last longer, due to the improved heat transfer. The exception might be on a street tire, driven only on pavement, especially hot pavement, But I can find only anecdotal evidence to support that. My experience, that of most people on the forums, and the recommendations of most of the dealers, is that wear is not accelerated in any way under most circumstances. I have been siping my BFG M/T's for a lot of years and seen no increase in wear, beyond the mild "chunking" I described earlier.
    Siping doesn't remove any material, like grooving does. http://www.lesschwab.com/siping.asp "Our SIPING process doesn't remove ANY rubber from the tread allowing the individual SIPES to support each other."
    Perhaps, but most of the major tire dealers perform siping and will honor the warranty anyway, if they do the siping. In fact, at Discount Tire, their full replacement warranty for any reason is still in effect. I understand Schwab also backs theirs 100%.
    http://www.discounttire.com/dtcs/tireSiping.dos
  10. Oct 10, 2009 at 6:48 AM
    mws4ua
    mws4ua I'll try being nicer if you try being smarter.
    Birmingham
    2018 GMC Sierra SLT Z71 4x4... Yeah yeah, I know.
    wtf is siping?
    :crapstorm:
  11. Oct 10, 2009 at 6:52 AM
    WATRD
    WATRD Keyser Soze
    Rob
    Duvall, WA
    '01 S/C SAS TRD
    WATRD.com
