Sirius/Factory radio install 2009 Tacoma
Discussion in 'Audio & Video' started by BPachom, Mar 1, 2009.
  1. Jul 13, 2010 at 5:23 AM
    #61
    topherjus
    topherjus New Member
    South Carolina
    2009 Double Cab TRD Sport 4x4
    I have had problems with this set up. Occassionally I lose all functions, and I have to reset the device. The most common problem is the fact that my volume is maxed out and it is no where near the quality of even standard radio
  2. Jul 13, 2010 at 11:39 AM
    #62
    cortez_a
    cortez_a Active Member
    Andy
    Colorado
    I did it to my 2010 and it worked great. Just make sure you have the two switches set correctly and that you type in that code to make the volume a little louder.
  3. Jul 13, 2010 at 12:19 PM
    #63
    Warrior74
    Warrior74 Member
    Mark
    Ontario, Canada
    2010 TRD Sport Dbl Cab Black
    Tint driver and passenger windows, weathertech front and rear black floor mats, wetokale front seat covers, toyota bed mat, SIRIUS factory SAT, Extang Trifold soft toneau cover.
    Called tss before they shipped out my order of the TOY-SC1 and SCC1 combo kit. They recommended the iSimple set up for the 2010. I'll keep ya posted.
  4. Jul 13, 2010 at 12:36 PM
    #64
    KnurledNut
    KnurledNut Cracker in a Taco
    Sonova Beach
    '10 PreRunner SR5
    I changed my HU to a nice Sony unit w/ Sirius and purchased the proper interface, receiver, and shark fin antenna adapter. I get no signal from the shark fin antenna on the roof. However if I use the cheapie magnetic antenna I get a signal. From what I've read on the net there is an issue with the shark fin antenna being compatible with Sirius as the shark fin antenna is XM.
  5. Jul 13, 2010 at 8:19 PM
    #65
    BPachom
    BPachom [OP] Well-Known Member
    Long Island
    09 Tacoma SR5, 4cyl 4X4, Black
    Access roll-up tonneau cover, Factory radio W/Sirius, Tailgate clamp, HID head lights, Stainless nerf bars.
    I have the factory roof mount antenna with the shark fin adapter for a Sirius radio and do NOT have any signal problems.
  6. Jul 14, 2010 at 5:05 AM
    #66
    KnurledNut
    Sonova Beach
    '10 PreRunner SR5
    Some work and some don't...mine doesn't work.
    Since I have the Sat Ready option I tried having the dealer check the wiring from the roof antenna to the connector behind the kick panel, they refused. So I'm just SOL. But you can bet I will never buy a Toyota again just because of this.
  7. Jul 14, 2010 at 6:05 AM
    #67
    BPachom
    Long Island
    Can't believe a dealer would leave you hanging like that, well..... I guess yeah, some dealers might do that :(
    Did you try another dealer?
    I wonder if the antenna itself is defective?
    (Just some thoughts)
  8. Jul 14, 2010 at 7:19 AM
    #68
    Snapp
    Snapp Member
    Delaware
    10 TRD Sport LB
    Looking forward to hearing your experience. Since I also have 2010 if yours goes well I am going purchase the same set up.
  9. Jul 17, 2010 at 8:03 PM
    #69
    Warrior74
    Warrior74 Member
    Mark
    Ontario, Canada
    Well I got the kit and tried the install.... Not working! I followed the install to a tee. It's not rocket science. Sirius is activated. All I get is SAT3 AUX. No sound no nothing. I try and scroll through channels or anything, nothing works, SAT wise anyway. AM/FM radio works fine. Hooked up my ipod to the provided AUX cable and I gotta max out volume just to get a minor sound more like a wisper. Try again tomorrow. Using the iSimple kit and Sirius SCC1 with shark fin adapter.
  10. Jul 18, 2010 at 5:43 PM
    #70
    Warrior74
    Warrior74 Member
    Mark
    Ontario, Canada
    Well boys I am an official idiot. The hardware works from iSimple and so does the SCC1 and the Shark fin. Apparently I had to disconnect the antenna from OEM radio as well before I completed the install, (missed that). All works great including the sound! Thanks for the help and replies. Love this site!!::D
  11. Jul 19, 2010 at 8:18 AM
    #71
    Snapp
    Snapp Member
    Delaware
    10 TRD Sport LB
    thanks for the update. I think I am going to pull the trigger and do the same install. Can you post exactly what parts you bought in order to complete this install? Thanks
  12. Aug 9, 2010 at 10:04 AM
    #72
    dbrenner
    dbrenner Member
    Fairfax, VA
    09 TRD SR5
    I will be trying this install when I get home tonight, with the same parts used by BPachom. I am hoping that the wire harness that comes with the parts will be long enough to mount the tuner and interface under the rear seat in my Double Cab, so they will be completely out of sight.
    How long (ft) is the harness?
  13. Aug 9, 2010 at 7:13 PM
    #73
    BPachom
    Long Island
    DBrenner;
    Good luck with your install.
    I do not remember the wire harness being too long, perhaps 1 1/2' - 2'??
    There may be room inside the dash (behind and next to) the factory radio for the Sirius tuner and interface.
  14. Aug 10, 2010 at 7:55 AM
    #74
    dbrenner
    dbrenner Member
    Fairfax, VA
    09 TRD SR5
    Got the install finished with the three parts designated by BPachom. After hooking everything up I activated the radio and it works like a charm.
    I hid the tuner behind the passenger kick wall, and have the interface hanging out on the floor of the passenger side right now. I plan to attach it to the back of the glovebox somehow, maybe double face tape will do it.
    As an FYI, the biggest difficulties with this, at least for myself, were removing the radio from the dash (without breaking anything) after removing the four bolts and connecting the sirius wire harness to the radio itself. I eventually completely disconnected the radio so I could remove it to attach the wire harness. The plug was a pretty tight fit but it did connect.
  15. Nov 11, 2010 at 6:19 AM
    #75
    Snapp
    Snapp Member
    Delaware
    10 TRD Sport LB
    After procrastinating for quite some time I ordered my parts last week and they arrived on my doorstep yesterday. From the time I opened the box with the Sirius goodies to locking the truck when I was done maybe an hour elapsed. People have mentioned certain parts may or may not work with certain years. I have a 2010. I purchased everything from TSSRAdio https://www.tss-radio.com. Here is what I bought:
    - Toyota Lexus and Scion SIRIUS Connect TOY-SC1 SCC1 Package - http://www.tss-radio.com/products/toyota-lexus-and-scion-sirius-connect-toy-sc1-scc1-package
    - Lexus GS Shark Fin Antenna Adapter - http://www.tss-radio.com/products/lexus-gs-shark-fin-antenna-adapter
    I followed BPachom's write up and I had everything working in about 20 minutes. Here's some feedback
    - taking the factory radio out takes maybe 2 minutes, use a micro flat head screwdriver to pry out the temp controls and use a 10MM nut driver for the 4 bolts.
    - hardest part of the entire install is figuring out where to locate the 2 Sirius modules. I have one hidden in the center console and the other in the passenger kick plate. Over time I may move them.
    - shark fin adapter is plenty long enough to give you plenty of options
    - using the volume fix is a must. I definitely helps out.
    Thanks for everyone's feed back to make this install quick and successful.
  16. Dec 14, 2010 at 2:49 PM
    #76
    KeithB
    KeithB Well-Known Member
    Keith
    Cheshire, CT
    SWB '09 Tacoma DCSB Sport 4x4
    Wheels and Tires: 17x8" Ultra Goliath wheels with P285/70R17 Falken Wildpeak AT3/W tires, Suspension: Fox coilovers set at 2", TC UCA's, 1.5" lift 3 leaf pack with overload left in Other: TRD SS exhaust, Pioneer AVIC 4100 H/U with Android Auto (awesomeness), sat radio bluetooth, Accessories: Toyota roof rack, black Toyota running board steps, cargo divider, weathertech floor liners, Literider roll up soft tonneau, thule bars over tonneau, USB ports front and rear, seat heaters, birddawg mirror riser Cosmetic: window tint, grillcraft black mesh upper/lower grill, vinyl armrest in doors, Clazzio black seat covers with blue stitch, Redline steering wheel wrap Lighting: fogs only mod, back up lights, amber interior accent lighting, amber 10" LED light bar in hood scoop, 33" LED bar behind the lower grill, amber lamin-x on fog lights, Tacomabeast headlights and matching tails.
    So it's a year later and I still haven't done this yet but may do it soon. I don't think anyone answered my question though.
  17. Dec 14, 2010 at 7:40 PM
    #77
    ISUGrad05
    ISUGrad05 Public Servant Enemy #1
    Wichita, KS
    2012 4x4 5.7 Tundra DoubleCab
    One question, will this install work with the factory installed bluetooth on the non-JBL head unit for 2011 Taco? I was reading some info that there were some issues with factory XM and bluetooth. This looks like the route I want to go as I already have a Sirius subscription and a Sportster radio.
  18. Dec 15, 2010 at 7:50 AM
    #78
    Snapp
    Snapp Member
    Delaware
    10 TRD Sport LB
    Yes you need to take the radio out. Removing the kicker panel is only for the antenna. You still need install the wiring harness on the back of the factory radio.
  19. Dec 17, 2010 at 2:54 PM
    #79
    Rhody76
    Rhody76 Well-Known Member
    Rhode Island
    2011 SR5 DCLB 4x4
    Rear leaf TSB, Bilstein 5100s set at 1.75",1" blocks, UWS low profile toolbox in black, husky liners, tint, LED interior and reverse lights, yellow fogs
    This is a great thread with a lot of information but I have a couple questions:
    1. should I see the Sat1,sat2, sat3 display when I hit AM/SAT now. The truck does not have an existing satellite antenna. I plan to buy one from Toyota and install it along with all other components
    2. At what point will I see the sat display? After the tuner or interface is installed?
    3. Does anyone have experience with installing a factory satellite antenna or suggestions on how to go about it? I am a bit nervous about drilling a hole in the roof of my 2011 truck!
    Thanks in advance
  20. Dec 17, 2010 at 9:22 PM
    #80
    BPachom
    Long Island
    Are you sure the truck does not already have the satellite antenna on the roof??? Toyota first introduce this standard feature/option in 2009. I would be shocked if they discontinued it.
