Sirius Radio installation in 2010 Tacoma Access Cab
Discussion in 'Audio & Video' started by opeapea, Feb 27, 2010.
  1. Feb 27, 2010 at 3:22 PM
    opeapea
    opeapea [OP] New Member
    Ootah
    Standard 6 V6
    Thanks to those who have posted previously regarding installing Sirius or XM receivers into Toyota Tacomas with satellite-ready radios possessing an AM/SAT (but NOT XM) button. Here’s what I did with my 2010 Tacoma access cab, standard 6 V6:
    It took some web surfing to determine if a Sirius system could be installed since most indications in the manual and elsewhere are that the OEM radio head unit is intended for XM. The short of it is yes, it can be done.
    I initially went to TSS-Radio Sales (http://www.tss-radio.com) and looked at the TOYSC1/SCC1 system. This is what their tech support folks told me:
    We do not recommend the TOYSCC1 for the 2010 model year because of software compatibility. We recommend the VAIS or the iSimple product instead. You can certainly try the TOYSC1/SCC1, but it hasn't been updated in quite some time and it may not yield the same results the SLS2 or the iSimple system would.
    This is the VAIS interface -
    http://www.tss-radio.com/toyota-sirius-interface-package-auxiliary-p-4471.html
    Another option, I gather, is this: http://www.tss-radio.com/isimple-toyota-factory-upgrade-kit-for-sirius-p-6961.html
    In the end, I opted for the Sirius receiver manufactured by Toyota, which I purchased from http://www.toyotapart.com:
    PT545-00080, SIRIUS SATELLITE RADIO RECEIVER, $115.79
    PT545-0C081, SIRIUS FIT KIT, $93.38
    Other vendors sell these two parts as well. I went this route in large part because there’s only one piece of equipment, the receiver, to be installed.
    If you’ve read any of the install-a-satellite-receiver-in-a-Tacoma blog entries, you know that you must also purchase the SFA12M adapter cable (http://www.discountcarstereo.com/detail.aspx?ID=1154) which allows you to use the factory satellite radio antenna instead of the magnetic antenna included in the receiver kit.
    My receiver and fit kit came promptly, but installation instructions were not included. You can find the instructions here:
    (http://www.toyotapart.com/2009-2010...SSY_PT545-00080_T-AI-0402-D_--PT545-35090.pdf)
    Oddly, these instructions seem not to include a description of how to affix the receiver in the rear auxiliary box area in the access cab model. But you can find that description in the XM receiver installation instructions here:
    As a bonus, these instructions provide info on how to remove the ridiculous subwoofer. But I digress….
    In the end, I elected not to hassle with removing all of the trim, seats, boxes, etc. that would allow for mounting in the back. I have read that there is space for mounting behind the passenger side kick panel, but I saw no available space. I chose a spot just forward of and left of the shift lever—mounted in the center console, driver’s side. If you want to get into the console, pull up the center cup holder. You should be able to do this by hand or with a nylon tool. Unscrew the four screws. Unscrew the shift knob. The forward part of the console is separate but connected to the aft portion. I expect that you could detach the front from the back, but I didn’t. Instead I lifted out the carpet from the center console storage box, and unscrewed the two bolts. The whole console will then lift back, up, and out. The inner sides of the console have sound insulation affixed to them. I removed a small piece of the insulation, matched with the size of the receiver. In order to mount the receiver, I flexed the screw tabs on the receiver until they snapped off, the breaks flush with the sides of the receiver. With these tabs gone, the receiver fits perfectly onto the inner surface of console. I affixed it Velcro tape, as I didn’t care for the provided double-sided tape.
    Removal of the footrest, scuff plate, and the cowl side trim board (kick panel), as described in the instructions, is straight forward and easy (I used a nylon trim tool). I hooked up the antenna and wire harness, using the power and antenna connectors behind the kick panel, before final installation to make sure everything was working (until you activate your receiver, ‘Station 184’ appears on the screen, and Sirius promo info is broadcast). I then tucked it all away and replaced all of the trim. Routing the wires from behind the kick panel area to up and behind the dash and back down into the console was a minor chore, but it should be ok, and the wires are tied up and out of sight.
    Cheers
  2. Mar 4, 2010 at 11:21 AM
    taco man31
    taco man31 Well-Known Member
  3. Mar 4, 2010 at 5:21 PM
    opeapea
    Ootah
    Standard 6 V6
    I didn't touch the head. The wiring and shark fin connect to the harness behind the kick plate, and everything works fine.
  4. Mar 4, 2010 at 6:45 PM
    taco man31
    wow this is going to be easier then i thought. I just ordered my equipment :)
  5. Mar 13, 2010 at 1:43 PM
    pauldotcom
    pauldotcom Well-Known Member
    Paul
    MA
    2012 Toyota Tacoma 4x4 TRD Sport Quad Cab
    OEM Roof Rack, Bilstein 5100's @ 1.75", Rear 1" block, TRD 17' Wheels
    It's cake. I installed it in the proper location and it took about 30 minutes because I took my time.
  6. Jul 2, 2019 at 7:14 AM
    PhizzleMo
    PhizzleMo New Member
    Phil
    2010 Tacoma SR5
