Sizing of air lines
Discussion in 'General Automotive' started by brutalguyracing, Jun 8, 2013.
  1. Jun 8, 2013 at 7:10 AM
    brutalguyracing
    brutalguyracing [OP] BIG DADDY
    F.U> GUYZ
    broken mods
    Hey
    What size air lines are you all running from your mounted air compressors to you outlets
    My compressor has 1/4" male threads
    Was thinking of doing 3/8" rubber hose from hd.....and some barbed fittings
    Any insight????
    Also any wiring advise
    I have blue sea fuse biz and my own switch already run to area where compressor will be mounted
    So in assuming 10 or 12 gauge to compressor from battery and switch to relay
  2. Jun 8, 2013 at 4:55 PM
    brutalguyracing
    F.U> GUYZ
    broken mods
  3. Jun 8, 2013 at 5:03 PM
    OH-MAN
    OH-MAN Well-Known Member
    Sunny Az.
    10 4X4 O.R. White
    TRD skid painted black,
    Larger will not hurt a thing.
    I don't know crap about electrical ( anything that you can not see and can kill you is not to be trusted! ) ;)
  4. Jun 9, 2013 at 10:38 AM
    Conti
    Conti Member
    Pacific North West
    2006 TRD Sport
    - Taunu cover - Bull Bar - Nerf Bars - Tinted Front Windows - Bed Cubby Lights - Larger Tires - 265/70/17 Hankook Dynapro ATM - Fog Light Mod. - Under Hood Light - Tailgate Pop and Lock - Hood actuators - Ordered from RedLine Tuning - Roof Rack - Tacoma Roof Rack from Toyota Parts Zone - Ultra-Guage - 4 wheel drive switch illuminated - Custom board and leds - Mag Lite Mount - Mini Flash Lite Mount - Tview T90DVFD 9 Overhead DVD player - GPS System - Tom Tom 340 - Brake Controller : Tekonsha Prodigy Trailer Camper Brake Control - EGR In-Channel Window Visors - Drop in K&N Filter - Plasti Dipped Badges - Wired Aux jack into OEM Radio - Shorty antenna - Oem bed mat. - Weather Tech mats black. - Quick Fist Shovel and Ax Mount - Extra D Rings in front of Bed - LED Bed Cubby Lights - Reverse Lights - Hardwired with switch in cab. - Ride Rite Air Bags - On Board Air (OBA) : MV-50 compressor, Viair Tank (2.5 gal 200 psi), in cab dual needle gauge, manual paddle valve for air bag
    I used 3/8 hose from my compressor to outlets and tank.
    10 ga wire should be more than adequate to power the compressor. Google wire gauge chart to check your specs.
    Cheers.
  5. Jun 9, 2013 at 12:34 PM
    brutalguyracing
    F.U> GUYZ
    broken mods
    IS IT RUBBER 3/8" HOSE AND BARBED CONNECTIONS?
  6. Jun 10, 2013 at 10:38 AM
    Conti
    Conti Member
    Pacific North West
    2006 TRD Sport
  7. Jun 10, 2013 at 11:07 AM
    Southern01Taco
    Southern01Taco Well-Known Member
    Sean
    Holden, La
    01 V6 4x4 Xtra Cab SR5
    Personally I would run air line like this.
    http://thorbros.com/catalog/air-line-dot
    They also sell any type of fitting you can think of.
    http://thorbros.com/catalog/fittings
    Here is another good site to order from.
    http://www.avsontheweb.com/home.php?cat=124
    The size of the wire depends on how far away the comp. is from the battery and how many amps it pulls at full load. 10ga should be fine but if you are putting it under your bed or something, I would step it down to 6ga or maybe even 4ga.
  8. Jun 11, 2013 at 6:55 PM
    brutalguyracing
    F.U> GUYZ
    broken mods
    thanks for the help guyz
    now how does one mount air chucks on my bumpers.....
    i was looking to drill a hole and thread some fitting through?
    i know someone has done this before?
    pics would be great?
    also how do these ait fittings work?
    i have never used or seen them before?
  9. Jun 13, 2013 at 5:39 PM
    brutalguyracing
    F.U> GUYZ
    broken mods
    bump
