Skid Plate for '22 OR
Discussion in '3rd Gen. Tacomas (2016-2023)' started by desertprospect, Apr 10, 2025.
  1. Apr 10, 2025 at 2:12 PM
    desertprospect
    desertprospect [OP] Member
    Hi.
    I have a '22 Tacoma OR Access Cab. I have read a bit about front skid plates. Wondering what opinions are.
    Looking at Cali Raised and the TRD skid plate. I gather TRD is pretty rugged. And wouldn't mind the saved weight of going with aluminum. But if folks think steel is simply better, than will go that way.
    Or, have you found another brand that is less expensive, but that also has oil access?
    Also, have been looking on Marketplace and Ebay for used. Not much around. Any thoughts on how to get one used? I'm in Tucson.
    Off topic, but do you know if there are inexpensive wheel caps available somewhere? Everything starts at ~$25 PER cap. Lost one someone along the desert road. It could even be a set of blank caps. Just want to have caps on all wheels, whether they have Yota logo, or not.
    Thank you.
  2. Apr 10, 2025 at 2:15 PM
    MDFM31
    MDFM31 Well-Known Member
    Chester Co, PA
    16 DCSBOR
    I like my steel ARB's. They are half the thickness of other steel plates but plenty rugged for my purposes. They weigh what popular aluminum plates weigh. If I was planning on slamming down on jagged rocks regularly, I'd go heavier. Mine have saved me numerous times when I have slid off a rock or just had no other choice. The TRD plate is not for hard use.
    desertprospect[OP] likes this.
  3. Apr 10, 2025 at 2:17 PM
    RichochetRabbit
    RichochetRabbit Bing Bing Bing
    My RCI steel engine+transmission skid and the aluminum wings on transmission that protect catalytic converters are about 100 lbs total. The steel has taken a couple big gouges, scrapes and thumps and still looks "in the correct shape".
    But that is just my opinion that a few extra pounds for steel over aluminum is worth it.
  4. Apr 10, 2025 at 2:34 PM
    txags92
    txags92 Well-Known Member
    2016 DCLB TRD OR 4x4 BBP
    Check out Talon's Garage as well. They have both steel and aluminum options. I have their aluminum skids on my 2016 Tacoma OR and a 2022 4Runner ORP.
    Talon2006 and desertprospect[OP] like this.
  5. Apr 10, 2025 at 2:50 PM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    I like my oem one, but I don't do rock crawling....
  6. Apr 10, 2025 at 2:51 PM
    RichochetRabbit
    Steel or aluminum .. get aluminum at least 1/4 in or steel 3/16 in. And get some catalytic converter guards. But if you are going to seriously rock-crawl instead just lighter off-roading and forest roads go with steel
  7. Apr 10, 2025 at 3:16 PM
    majpooper
    majpooper Well-Known Member
    Dennis
    North Carolina
    2022 Black TRD OR
    OTT Tune Front 2" lift OME 888 coil Bilstein 5100 DuroBump extended front bump stops Archive Garage extended rear bump stops Rear 1.85" lift Icon RXT leaf pack Bilstein 5100 SPC UCA DX4 16x8 +10 wheels 285/75R16 KO2 viper cut CMC sway bar delete exhaust reroute exhaust cut just past the rear axle U-bolt flip LFD engine skid plate RCI transmission and x-fer case skid plates Spindle gussets
  8. Apr 10, 2025 at 5:46 PM
    Tallgrass05
    Tallgrass05 Well-Known Member
    Do you want them just to have them or do you really need them?
    desertprospect[OP] and Chew like this.
  9. Apr 10, 2025 at 6:04 PM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    I went aluminum. Aluminum is great for sticks, small stones, and the occasional 18 wheeler's discarded tire. I have no intention to plow boulders with my truck.
  10. Apr 10, 2025 at 8:57 PM
    RichochetRabbit
    But that scraping sound is just soooo satisfying. o_O
  11. Apr 11, 2025 at 8:54 AM
    TacoGranny
    TacoGranny Well-Known Member
    2020 TRDOR DCSB Cement 6MT
    33's, Sliders, Skid Plates, Softopper, ATH rear bumper
    That's not very Rock Lobster of you.
  12. Apr 11, 2025 at 10:17 AM
    majpooper
    Dennis
    North Carolina
    2022 Black TRD OR
    Aluminum is great for light wheeling - unfortunately in my case I go places I probably have no business going. I really do try to take good lines and not do crazy . . . . . so why do my skid plates take a beating ? Please don't answer that.
    walleye_slayer likes this.
  13. Apr 11, 2025 at 10:42 AM
    Letstacobit
    Letstacobit Well-Known Member
    Orange County, CA
    2022 Off-Road
    I have RCI engine/tranny/transfer case (steel). They're not light but they work well. The exhaust panel is really functional/slides better than expected. Having them and wheeling is a waaay more enjoyable experience.
    Solid resource for weight management:
    https://www.tacomaworld.com/threads/list-of-armor-weights.701692/
    RollTide! and majpooper like this.
  14. Apr 11, 2025 at 10:45 AM
    RichochetRabbit
    Maybe the moderators can change his username to Pebble Lobster. :boink::rofl::rofl:
  15. Apr 11, 2025 at 10:48 AM
    monoman
    monoman Time to get dirty!
    Dave
    Exotic, San Jose, Cal.
    2018 Silver Sky Tacoma SR Access Cab 4X4
    SnugTop SuperSport shell CaliRaisedLED light bar BFG K0 AT’s Bilstein 5100's up front, (#2) & 4600 in rear N-2 Designs remote start/keyless entry Anytime 12v outlets... one by shifter & one in bed Daily driver....
    I'm happy with my RCI skid, very easy install & seems to be well built..:thumbsup:
  16. Apr 11, 2025 at 11:19 AM
    Rock Lobster
    Dee Eff Dub
    I drive a Miata.
  17. Apr 11, 2025 at 4:40 PM
    desertprospect
    I really need them. I have already bent something under there pretty bad. Don't want to make it worse.
    majpooper likes this.
  18. Apr 11, 2025 at 4:41 PM
    desertprospect
    A lot of love for the RCI's. Anyone know why folks aren't saying anything more about the Talon's Garage skids? they are considerably less expensive, come in two pieces (which could make installation easier), and seem like a solid option.
    Talon2006 likes this.
  19. Apr 11, 2025 at 7:12 PM
    RichochetRabbit
    Steel. No doubt.
  20. Apr 12, 2025 at 11:21 AM
    Rock Lobster
    Dee Eff Dub
    I drive a Miata.
    Or... Hear me out here....
    Learn to pick better lines.
    :anonymous::bananadead:
    :crapstorm:
