Skid plate ideas
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jasonstacoma, Aug 16, 2019.
  1. Aug 16, 2019 at 3:01 PM
    Jasonstacoma
    Jasonstacoma [OP] Well-Known Member
    2019 dcsb Barcelona red
    Stock
    Hey guys
    So I'm trying to read but can't find an exact answer. I'm looking to install some skid plates for full protection under the taco. I dont offroad much but want to feel safe doing so. I want more than a front skid Looking to do a full set up and get it all done. What do you think about this arb setup? Do I still need to buy a gas tank skid as well w this? What are you guys all running?
  2. Aug 16, 2019 at 3:12 PM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    Can you provide a link to the specs?
    I have stock OR wheels and 265/75/16’s so my frame is not much higher than stock. I did lift it 1.75” so I have some body clearance, but decided to get all steel Mobtown plates, and also added sliders and covered my fuel tank and differential. This was a good thing to do for me as we do like to explore remote trails and roads out there by ourselves and they are not always maintained or the best, so we have scraped on ledges and hit rocks.
    If you are on muddy roads or lose sand and gravel a lot, those plates look like they would clean out easier than the solid bottom plates, but they also look like they will snag on rocks. Are they aluminum? Snagging will tear them up I would think if they are very light steel or aluminum.
  3. Aug 16, 2019 at 3:12 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    If you do light rocks (below), should be fine. Also consider a small lift and look into getting sliders.
  4. Aug 16, 2019 at 3:15 PM
    Jasonstacoma
    Stock
    I do want to get sliders after skids. I just don't know, or can't figure out, how to do the most coverage underneath. I'd rather spend money protecting it, vs paying to repair it, ya know. I saw motown offers different plates, but im not sure which ones I'd all need
  5. Aug 16, 2019 at 3:18 PM
    OnHartung'sRoad
    Must have been really light rocks, what was that following you?
    tcjacado and Skydvrr like this.
  6. Aug 16, 2019 at 3:33 PM
    OnHartung'sRoad
    I just read they’re 3mm steel, not much difference than the stock OR or TRD plate. If you do hit rocks with it, it will get dented up, but its better than nothing under there.
    As for Mobtown and others, you will need the three plates to cover what you said you wanted. The main one is the front or IFS skid plate, the second (optional) is the transfer case skid and the last (optional) is the transmission skid.
    Also consider getting your exhaust pipe leading from the left (drivers) side rerouted where it passes under the transmission, with a stock truck you are more likely to hit it and it is the lowest part of your truck besides the differential.
  7. Aug 16, 2019 at 4:03 PM
    Taco_Craig
    Taco_Craig Well-Known Member
    Craig
    2016 MGM Tacoma, DCSB TRD-OR
    RCI Sliders/Plates, Icon [Stage 3] Suspension
    Like someone said above, there are three skid plates: front, mid, trans. Mobtown, CBI, RCI, etc. all sell them. Pick a manufacturer. Buy them in that order. They're about $200-300 each.
    Jasonstacoma[OP] and wiljayhi like this.
  8. Aug 16, 2019 at 4:55 PM
    Jasonstacoma
    Stock
    Anyone running a gas tank skid too?
  9. Aug 16, 2019 at 5:03 PM
    Taco_Craig
    Craig
    It would be nice (on my list), but if I drag on a rock and I feel it sliding along my whole underside, I usually just stop and back up... choose a new line... You can do a lot without that much armor. You might get more bang out of front skid + sliders than full underarmor.
  10. Aug 16, 2019 at 5:18 PM
    OnHartung'sRoad
    True, but you are more likely to hit it another way, too. I had an issue with it going across a washout with a steep drop and ended up close to a high center with my 1st gen. Luckily, it came with a steel OEM gas tank and a steel plate on it, so it was fine. So, I put on a steel CBI gas tank plate on my 3rd gen too.
    @Jasonstacoma - Just like Craig suggests, if you don’t off-road much, I wouldn't go too overboard with plates- maybe just get a good front one and sliders, and wait until you decide to get a reroute on your exhaust crossover before getting the rest.
  11. Aug 16, 2019 at 5:35 PM
    Rockefelluh
    Rockefelluh Well-Known Member
    Rocky
    Orange County, CA
    2018 DCLB TRDOR 4x4
    ARB aren’t really thick enough to upgrade IMO.
    Gas tank armor is not necessary (maybe for the top 0.1%, hardcore). If you are getting a rock to hit that spot you might be screwed with or without armor, it’s way up there.
    Skydvrr and Jasonstacoma[OP] like this.
  12. Aug 16, 2019 at 9:12 PM
    Jasonstacoma
    Stock
    Would you recommend rci? I saw one that is all one piece all the way back.
    Taco_Craig likes this.
  13. Aug 16, 2019 at 9:28 PM
    RyanDCLB
    RyanDCLB Well-Known Member
    4/19 DCLBOR
  14. Aug 16, 2019 at 10:00 PM
    tcjacado
    tcjacado Well-Known Member
    Taco-Obsessed and essjay like this.
  15. Aug 16, 2019 at 10:09 PM
    Jasonstacoma
    Stock
    Any advantages/disadvantages to going all one piece vs 3
  16. Aug 16, 2019 at 10:19 PM
    the.sight.picture
    the.sight.picture Wishes he was in the woods.
    Nick
    Blue Ridge
    2018 QuickSand
    Check out my build thread (Beginning of Money Pit)
    I have mobtown 3/16 with flat bottom. That required me to re route my exhaust near my transfer case. Which is what id recommend doing. that way its true turtle bottom.
    Any 3/16 steel skid will do for mild offroading. If you plan on doing anything heavy Id say go buy a Beef ass BAMF 1/4 skid set
    Taco-Obsessed likes this.
  17. Aug 16, 2019 at 10:35 PM
    CZ5ANM Taco
    CZ5ANM Taco Well-Known Member
    BC, Canada
    2016 DCSB Manual 35x11.5s
    Front Suspension King Ext Fronts 700# Icon UCA delta joints JD fab spindle gussets All Pro cam tabs DuroBumps Warfab steering sleeves Rear Suspension Old Man Emu leafs -Radflo Ext travel rears Timbrens ubolt flip kit SCS stealth 6 Wheels 35x11.5 Maxxis Razr [ 34.5 x 9.75 on 8.5 rim not on truck] Heavy Stuff Relentless front bumper Smitty 3rd Gen winch Big County Customs skid plates Arc One industries rear HC bumper RCI sliders Misc Arb dual compressor Arb rear locker Pelfreybilt fuse panel tray Cali raised ditch light mounts Cali raised bed stiffeners 5th Gen 4runner LED fog lights Racks Retraxone XR tonneau Yakima load bars Sherpa Roof Rack Camping Smittybilt Tent Dometic CFX50 fridge
    Your oil filter is under the front stock skid plate. The bigger the skid the more you or the guy changing your oil will hate you.
    Mines made by a Canadian company and the front piece comes off similar to the stock one. It’s “fun” taking it off with one hand on it and one on the ratchet. (Driveway)
    Some other manufacturers have access windows to access the filter some don’t.
  18. Aug 16, 2019 at 11:37 PM
    RyanDCLB
    4/19 DCLBOR
    They're all multiple pices, you simply save money buying them all at once.
    Thanks! Added..
    tcjacado[QUOTED] likes this.
  19. Aug 17, 2019 at 3:14 AM
    4x4_Taco
    4x4_Taco Well-Known Member
    FL
    Silver SR5 4x4
    I’m running the RCI aluminum gas tank skid plate.
  20. Aug 17, 2019 at 6:08 AM
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    RyanDCLB[QUOTED] and Chunk like this.
