Skid plate removal for oil change?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Gasturbine, Jul 28, 2015.
  1. Jul 28, 2015 at 6:52 AM
    Gasturbine
    Gasturbine [OP] Well-Known Member
    Central Ohio
    2011 Regular Cab 2.7l 5-speed 4WD
    32" BFG KO tires on MT rims, Front lifted 2", N-Fab 12,000lb front pull point w/10,000lb red clevis, mud flap delete, tail pipe delete, 20" LED light bar, 2 Hella 500s, N-Fab light bar mount, tinted windows.
    Do I have to remove my skid plate to change my oil and filter on my 2011 4WD?
    Thanks!
  2. Jul 28, 2015 at 6:53 AM
    greeneggsnspam
    greeneggsnspam ಠ_ಠ
    Houston, TX
    .gif
    Too poor to list anything interesting.
    The filter is up top. And the bolt is below.
    You do not have to remove it. Unless you have an aftermarket one that blocks access to the drain hole.
  3. Jul 28, 2015 at 6:54 AM
    greeneggsnspam
    greeneggsnspam ಠ_ಠ
    Houston, TX
    .gif
  4. Jul 28, 2015 at 7:01 AM
    NAAC3TACO
    NAAC3TACO Middle aged member
    Just east of crazy, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Yokohama Geolander AT tires , Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts, unifilter on air pump.
    I used to have a 2008 with the 2.7 and I didn't have to remove anything to change the oil.
  5. Jul 28, 2015 at 7:01 AM
    Pigpen
    Dan
    Northwest Montana
    Crawl under the truck and look
    JBecker likes this.
  6. Jul 28, 2015 at 7:04 AM
    Gasturbine
    Central Ohio
    I was told my filter is on the bottom of my 2.7l?
  7. Jul 28, 2015 at 7:05 AM
    greeneggsnspam
    greeneggsnspam ಠ_ಠ
    Houston, TX
    .gif
    I need to read the deets more. Sorry, was on tapatalk.
  8. Jul 28, 2015 at 7:05 AM
    NAAC3TACO
    2014 SR5 DCLB 4x4
    It's on the passenger side up near the exhaust manifold. You have to access it from under the truck. You can see it through the right front wheel well.
  9. Jul 28, 2015 at 7:08 AM
    greeneggsnspam
    greeneggsnspam ಠ_ಠ
    Houston, TX
    .gif
  10. Jul 28, 2015 at 7:36 AM
    Gasturbine
    Central Ohio
    okay, thanks guys...Its most appreciated!
    I think Im going to get the Fumoto valve too.
  11. Jul 28, 2015 at 12:41 PM
    mcdee
    mcdee Well-Known Member
    mike
    Northern Cal
    12 PreRunner OffRoad TRD
    TRD center cap, quick bed mat, Gatekeeper, WTs, TRD skid plate from bpfab, plastidip emblems, security slider bar, interior LEDs, AFE Pro Dry air filter
    If you go with fumoto shop around, I had best OTD price from quik valve. Try code " speed15 ", may get you small discount.
  12. Jul 28, 2015 at 3:26 PM
    clc clc
    clc clc Well-Known Member
    PA
    2012 4x4 reg cab tacoma/2020 subaru crosstrek
    I don't see the need for the valve on the 2.7l since you will have to crawl under the truck regardless. If you go the after market IFS skid plate route you will need to remove it.
  13. Jul 28, 2015 at 3:52 PM
    Hartford
    Hartford Well-Known Member
    Maine
    2011 Acc Cab 5spd
    No you wont have to remove the skid, unless the aftermarket doesnt have an access hole for the drain bolt. Most of them do though, and if I got one that didnt I would put a hole in it.
    Access to the oil filter will be the same with/out the skid. If you do the filter right you wont ever need a filter wrench either.
    And the part about having to crawl under the truck regardless for the 2.7l makes no sense. The drain for the v6 pan is under the truck too, so you will have to crawl under the truck whether its 4 or 6cyl fumoto valve or not.
  14. Jul 28, 2015 at 3:57 PM
    clc clc
    PA
    No. What I'm saying is with after market skids they will have to be removed to access the oil filter on the 2.7l. I have a AP IFS skid and it only has a hole for the oil drain plug.
  15. Jul 28, 2015 at 4:11 PM
    Hartford
    Maine
    2011 Acc Cab 5spd
    That must be a really wide skid then. I can reach and grab my oil filter with mine on. Its fun twisting off a hot filter one handed, but not as much as pulling the skid.
    Just checked and I have ato skid.
  16. Jul 28, 2015 at 4:17 PM
    clc clc
    PA
    You're right, after looking at it I might be able to get my hand on the filter without pulling the skid. Looks tight though.
    Sorry if my OP wasn't clear but with the v6 you could do a oil pump type device and never have to get under the truck, no? If the 2.7l had the filter under the hood that's what I would do for making oil changes easy in my apartment parking lot.
  17. Jul 28, 2015 at 4:27 PM
    Hartford
    Maine
    2011 Acc Cab 5spd
    It is tight, but its a hell of a lot easier than pulling the skid everytime. I change my oil every two months on average. Have never used one of the suction devices for getting the oil out of the pan, but have seen my mother do it for her car. Ill get on my back, and it gives me chance to check stuff/grease. With the lift I dont even need ramps anymore.
    ETA: If you are going to do it the tight way nock any dirt that might be around the area off with a rag before you take the old one off. Dont want shit falling in the new filter.
