Sliders and dealers???
Discussion in '2nd Gen. Tacomas (2005-2015)' started by blackwatertaco, Feb 3, 2010.
  1. Feb 3, 2010 at 10:32 AM
    blackwatertaco
    blackwatertaco [OP] If you ain't stuck, You ain't tryin hard enough.
    Jay
    Alvin/Pasadena, Tx
    08 taco, 4x4 2.7 5spd.
    One fucked up diff. breather mod, 265/75/16 Destiny Dakota M/T Black gulf states rims BHLM Magnaflow 14" muffler with cut off tail pipe. 10" pioneer slim truck sub with JBL 600W amp. PROJECT BLACK OUT
    Well with my tax return I want to get some sliders for my truck. The cheaper way is by welding them on. So will that void my warrenty??? I've read where it can and can't.:confused:
  2. Feb 3, 2010 at 10:33 AM
    Jigzor
    Jigzor Well-Known Member
    Pennsylvania
    20 Gladiator Rubicon
    Steersmarts Draglink, Tie rod, Track Bar
    What he said ^^^
  3. Feb 3, 2010 at 4:53 PM
    Evil Monkey
    Evil Monkey There's an evil monkey in my truck
    Robert
    Escondido, CA
    07 4x4 DC SR5 TRD Off-road
    Weathertech front & rear mats, rear suspension TSB, Toytec AAL for TSB, Hi-Lift Jack, Bilstein 5100 & Toytec Adjustable coilovers, Built Right UCAs, KMC XD 795 Hoss Wheels, Definity Dakota MTs 285/75R16, Leer XR, Thule Tracker II & Thule MOAB basket
    It would probably void the warranty if there was some damage to the frame resulting from the slider. It has to be relevant to the modification. So they couldn't deny a warranty claim on your engine or transmission because a slider was attached to the frame. They also have to prove the modification caused the problem. It's not enough to say that it's not covered just because there's a modification to it.
    So for example, if your frame developed a crack where the sliders were put on, they would probably deny warranty coverage of the frame.
  4. Feb 3, 2010 at 5:00 PM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Or when you fry any of the electronics while welding :D
