Sliders knocking on pinch weld
Discussion in '2nd Gen. Tacomas (2005-2015)' started by raco.the.taco, Oct 20, 2017.
  1. Oct 20, 2017 at 8:10 PM
    raco.the.taco
    raco.the.taco [OP] Well-Known Member
    Chad
    Denver, CO
    Locked, Geared & 1/2 Long Traveled
    Pelfreybilt Front Bumper, All-Pro Rear Bumper & Sliders, 35's, Toytect Boss Coilovers, JBA UCA's, DTF SUA Kit w/ E30 Deavers, Wheelers superbumps, Front & Rear Locked, 4.56 Gears
    Hey guys, I've endured my all-pro sliders knocking on my pinch weld everytime i hit a bump for the last 6 months and am finally tired of it. It makes my truck sound like a POS when i hit bumps. I've stuffed sliced 3/8"s braided fuel in between the pinch weld and slider bar which reduced the noise but is not the fix. Any suggestions? I know people have cut the pinch weld for clearance but i'm looking for other options that don't require pulling my sliders back off if possible. Thanks!
  2. Oct 20, 2017 at 8:22 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    I’ve got the same sliders and don’t have have that issue. But it is mentioned in the instructions that clearance issues could be a possibility, with the prescribed solution being to notch the pinch weld. But your sliders should not move when you hit a bump. Did you drill out the lower frame mounts and use all your mounting hardware? What is your static clearance between the pinch weld and the slider support?
  3. Oct 20, 2017 at 8:26 PM
    raco.the.taco
    Chad
    Denver, CO
    It's between 1/16 & 1/8 of clearance. It wasn't very bad until i had to use my farmjack a few times to lift the truck using the sliders.
  4. Oct 20, 2017 at 8:28 PM
    tcjacado
    tcjacado Well-Known Member
    Can you and 3 of your friends stand on it and try to bend it back?
  5. Oct 20, 2017 at 8:31 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    I’d try retorquing all the fasteners.
  6. Oct 20, 2017 at 9:13 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    You could use a hammer and punch and bend the pinch seam in a little above every point where it is hitting. I would dab a little paint on each spot to keep it from rusting if/where you crack the paint.
  7. Oct 20, 2017 at 9:22 PM
    Oreo Cat
    Oreo Cat Worst Member
    Coeur d’Alene, Idaho
    Hmm.. Wonder if this could be my phantom knock..
  8. Oct 20, 2017 at 9:25 PM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
    Very common for AllPro sliders to hit the pinch weld. If you don't want to modify the pinch weld, probably the only other thing you could do is replace the cab mount bushings for a slightly higher clearance.
    https://www.tacomaworld.com/threads/all-pro-slider-install.464236
    https://www.tacomaworld.com/threads/all-pro-apex-bolt-on-sliders.450494
    https://www.tacomaworld.com/threads/allpro-sliders-annoyance.90341
    https://www.tacomaworld.com/threads/is-this-normal-with-all-pro-sliders.327990
    https://www.tacomaworld.com/threads/all-pro-sliders.19930
  9. Oct 20, 2017 at 9:25 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    New body mount bushings ?
  10. Oct 20, 2017 at 9:26 PM
    TACORIDER
    TACORIDER Just another statistic
    JAKE
    EAST TAWAKONI TEXAS
    12 TACO and some other Toyota’s
    Chisel and mini sledge or don't be lazy, do it right and cut it since it's only a few bolts I believe or sell them and get weld on ones.
  11. Oct 20, 2017 at 9:28 PM
    Lord Helmet
    Lord Helmet Prepare To Attack
    Nick
    '24 X3 M40i
    :rofl::rofl::rofl::rofl:
    crashnburn80 likes this.
