Sliders or Tube Steps
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mattioss, Oct 28, 2009.
  1. Oct 28, 2009 at 8:29 AM
    mattioss
    mattioss [OP] Well-Known Member
    Milford, De
    08 Prerunner DB TRD Sport
    None
    Fellaz and Ladies,
    I know there are plenty of posts out there but which would be better. I have a white Double Cab, and I want to add something on the side to help the mother and son get into the truck. I only have a PreRunner but i was tube steps that are black (preferably i want stockers to removed the silver and powdercoat black) but I also have been looking at sliders. What do you guys suggest? I am open to all opinions. I an going for an all black and white look for my truck. The pics I've seen of some sliders look like they are pointing upwards on an angle. I want something that is close to the cab of the truck too so my sons leg/s dont fall through.
    Thanks in advance,
  2. Oct 28, 2009 at 8:32 AM
    leg killa
    leg killa Well-Known Member
    AMERICA
    06 SBDB SR5 4x4
    TRD Hood/ Color matched grill/ De badged/ BHLM/ Viper remote start/ Pioneer AVIC Z-130BT/ BFG MT KM2/ MT Classic II/ OME Lift/ LR UCAs/ Pop and Lock
    If you aren't going off road I'd get tube steps..sliders can play two roles..use it to step into your truck and protect the frame
  3. Oct 28, 2009 at 8:32 AM
    JeffRock
    JeffRock Well-Known Member
    Capital region, NY
    09 Tacoma accesscab 4x4 SR5 2.7L
    Toyota all weather floor mats. Mag light that clunks around in the jack compartment. Dog hair. Dog drool on the windows.
    Sliders are not really for stepping, But for jacking the vehicle up, And gaurding the rocker panels.. From what I gather.
  4. Oct 28, 2009 at 9:38 AM
    Masada
    Masada Well-Known Member
    Taylor
    Laveen, AZ
    05 Tacoma 4x4 TRD Off Road
    All Pro Steel Plate Front Bumper| All Pro Light Bar| All Pro IFS Skid Plate| All Pro E-locker guard| PIAA 510 Fog Lights| Hella 700FF| Fox 2.5 Coilover| Bilstein 5100 on the rear| BHLM| Grill Craft MX Series insert| Added two D-rings to bed|AVID Off Road sliders| AFE Dry Flow S| Gibson Cat Back| Custom Bedbar with hilift mount| Camburg 1" Uni-Ball UCA's| Hi-Lift 48" Extreme
    +1
    If you get the sliders, paint them and then on the top get some grip tape or bed liner to improve grip. That way you can use them for steps and sliders :)
  5. Oct 28, 2009 at 9:40 AM
    Evil Monkey
    Evil Monkey There's an evil monkey in my truck
    Robert
    Escondido, CA
    07 4x4 DC SR5 TRD Off-road
    Weathertech front & rear mats, rear suspension TSB, Toytec AAL for TSB, Hi-Lift Jack, Bilstein 5100 & Toytec Adjustable coilovers, Built Right UCAs, KMC XD 795 Hoss Wheels, Definity Dakota MTs 285/75R16, Leer XR, Thule Tracker II & Thule MOAB basket
    Sliders are much tougher than step bars. They're also good for protecting your vehicle against parking lot door openers. Though they're not step bars, the definitely can be used as step bars if they sit out far enough. You might want to put some non-skid grip tape on the top of the bar to help prevent slipping. If you're debating between the two, I'd get sliders. Sliders can be used as step bars but step bars cannot be used as sliders as they're much thinner tubing and are more easily damaged.
  6. Oct 28, 2009 at 10:06 AM
    leg killa
    AMERICA
    06 SBDB SR5 4x4
    I vote sliders
  7. Oct 28, 2009 at 10:22 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    If you're using them as a step..... you can get double tube 'square tube' sliders from Demello. They work great as steps. I used them all the time on my 96 tacoma and they go wheel-to-wheel. They are flat. I covered mine with Herculiner. These are also great for jacking the truck up with when you gotta change a tire (w/hi lift jack).
    http://www.lieblweb.com/cpg/albums/ToyotaTacoma/1996Tacoma/normal_138.jpg
    The round tube sliders just aren't good for stepping duty.
    Or look into running boards, nerf bars, or tube steps. I have OEM running boards.
