Slight annoying vibration finally cured!!! Hub centric vs lug centric
Discussion in '2nd Gen. Tacomas (2005-2015)' started by sandjunkie, May 15, 2012.
  1. May 16, 2012 at 8:29 PM
    JTaco386
    JTaco386 Well-Known Member
    JT
    San Antonio, TX
    13 DCSB TRD Sport 4x4
    Sub'd for future reference when my wheels come in to see if I will experience these problems
  2. May 16, 2012 at 10:32 PM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
    great post. this is one of the reasons why i hate to use lug-centric wheels. it takes a little more effort to dismount and mount your wheels back on and avoid vibration issues. hence the reason, i always recommend hub-centric wheels as well as adapters/spacers.
    ET lugs help, but purchasing hub-centric wheels in the first place can help avoid these headaches.
  3. May 16, 2012 at 10:55 PM
    Twiostaco
    Twiostaco Well-Known Member
    Austin
    Utah
    08 White DC TRD Sport
    5100's front set to .85 w/eibach springs, 5100 rear w/toytec 2"AAL, Light Race UCA, 17" Black Rhino Ocotillo wheels, 265/70/17 KO2's, K&N drop in filter, Grill Craft front mesh, one piece driveshaft (vibes gone) rear diff breather mod, BHLM, Fog anytime, 886 reverse bulbs.
  4. May 17, 2012 at 7:13 AM
    mws4ua
    mws4ua I'll try being nicer if you try being smarter.
    Birmingham
    2018 GMC Sierra SLT Z71 4x4... Yeah yeah, I know.
    I had no idea of the difference when I was looking for new wheels... Wish I had.
  5. May 17, 2012 at 8:23 AM
    black_magic2010
    black_magic2010 Well-Known Member
    South Texas
    10 Tacoma TRD Sport DBL Cab
  6. May 17, 2012 at 9:09 AM
    sandjunkie
    sandjunkie [OP] Well-Known Member
    Aaron
    OC
    I agree but isn't it difficult to find hub centric wheels in current aftermarket styles?
  7. May 17, 2012 at 9:16 AM
    Joben7726
    Joben7726 wes mantooth ™
    Joben
    Western PA/Va Beach
    Trail limo
    more than list-able
    Subbed for shimmy.
  8. May 17, 2012 at 9:28 AM
    broken taco
    broken taco Well-Known Member
    Adam
    San Diego / Houston
    01 TRD SR5 4WD
    Trail gear 3 Link Solid Axle Swap kit, 14 " Fox coil overs with reservoirs up front, Chevy 63 leaf spring swap with ruff stuffs Chevy 63 swap kit, 14 "Fox shocks on the rear, 37" tires, Custom front bumper by Next Venture Motor Sports with a warn winch, glassworks unlimited fender flares, custom rock rails with kickups (modeled after Relentless Fab Rock sliders), rear bumper from streetacos.com (with custom rap around protection for fiberglass fenders and the hitch receiver hidden behind the license plate that is on hinges), HID off road lights on front bumper, rigid pods on rear bumper with red back lighting, high lift mounted in the bed, onboard air, Flowmaster muffler, aftermarket air intake, alarm system, Alpine Deck, Alpine amp, Alpine speakers, JL W6 12" subwoofer, JL amp.
    im gunna have to try this. mine does the same thing but when i go over 80
  9. May 17, 2012 at 9:45 AM
    SCSPerformance
    Vin
    Bay Area, CA
    2005 Tacoma
    it is a little difficult b/c most companies out there make a "one size fit all" type of deal. they all usually have 108mm or 110mm hub opening and our tacoma's hub bore is only 106mm.
    one of the reasons why i have started what i've started is b/c of this very issue of not being able to find nice hub centric wheels. proper fitment and clean styling is what i'm trying to achieve.
    nevertheless, even with new tires, it can be a pita to get properly balanced. i've seen brand new tires rebalanced 3-4 times and it would still be off. some tires are just bad from the factory so don't eliminate this factor especially when you're dealing with huge mud tires.
  10. May 17, 2012 at 9:53 AM
    lundy
    lundy Well-Known Member
    Justin
    Reno, NV
    2023 Double Cab 4x4
    My BMF's and all BMF's are 106 [​IMG] but yeah hub rings are a must
  11. May 17, 2012 at 9:59 AM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Incorrect. Acorn lugnuts are used to center non-hubcentric wheels (hence the taper). The extended thread is meant for thick wheels where the stud threads exposed is too short for safety. The shank of ET lugnuts is not meant to center the wheel (often it doesn't touch the wall of the lug hole). Your vibrations were cured by the hubcentric ring.
    TAF_Taco likes this.
  12. May 17, 2012 at 9:59 AM
    krimson
    krimson Nothin
    TRD Off Road
    OME 3" lift with 885 coils. OME Shocks with TSB 1.5 AAL. 285/75/16 KM2s. XD Hoss 16" wheels. DDM Tuning 6000K HIDs, H10 6000K Fogs. BHLM. Debaged. 20% tint on front windows.
    My wheels are lug centric. I'am in need of Hub centric rings, I have A shake at highway speeds.
  13. May 17, 2012 at 3:47 PM
    CRU
    CRU Well-Known Member
    Seminole Cnty, FL
    07 SSM TuRD Sport DCLB
    20" Enkei WT4 wrapped in Bridgestone Dueler A/T Revo 3 265/50, Steel braided brake lines, Pioneer AVH-X5500BHS deck w/JBL GTO cones, OEM Smoked headlights, OEM LED tails, Clazzio seat covers, aFe Pro-Dry S air filter, Fumoto oil valve, Grillcraft MX grille w/Land Cruiser "TOYOTA" emblem, Redline QuickLIFT hood struts, Leather TRD shift knob, 13" shorty antenna
    They want $45 for plastic hug rings! :eek:
    I got mine from a local discount tire for $15.
  14. May 17, 2012 at 3:55 PM
    KenLyns
    Belly of the Beast
  15. May 17, 2012 at 4:13 PM
    #35
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    X2 I was going to say the same thing. The extended thread is just to get more threads, the taper part is what centers the lug nut, and the ring is what cured your vibes
  16. May 17, 2012 at 4:43 PM
    #36
    Seabass
    Seabass Give it to me. I'll break it for you
    Adam
    AZ
    '06 Sport 4x4
    Just a bunch of old crap
  17. May 18, 2012 at 12:11 AM
    #37
    thebaker
    thebaker Well-Known Member
    Byron
    NorCal
    Upgraded to a 3rd gen
    Never ending......$$$
  18. May 18, 2012 at 5:56 AM
    #38
    mws4ua
    Birmingham
    Also the link in the first post... Amazon for $17 w/ free shipping (if you order $25 worth of stuff).
  19. May 18, 2012 at 8:39 AM
    #39
    Cortland
    Cortland Well-Known Member
    Cortland
    California
    Clifford aka Big Red
    Camburg 4" Spindles, 5100's All Around, All-Pro 1.5" Leaf Pack, All-Pro U-Bolt Flip Kit, Avid Sliders, AFE Pro Dry Filter, Wicked Flow 18" Muffler
  20. May 23, 2012 at 6:22 AM
    #40
    mws4ua
    Birmingham
    I got one wheel into this fix and this shit happened...
    I have five loose lugs on a wheel, and no damn key to finish until the guys at the place linked in the first post ship me another key. The truck is just sitting in the garage. FML
