Slight annoying vibration finally cured!!! Hub centric vs lug centric
Discussion in '2nd Gen. Tacomas (2005-2015)' started by sandjunkie, May 15, 2012.
  1. Apr 10, 2013 at 5:15 AM
    #61
    stolleee
    stolleee Well-Known Member
    Memphis
    2012 Tacoma Supercharged and 1970 Toyota FJ40
    Fox shocks, TRD Supercharger, leather, wheels/tires, exhaust, audio.... etc....etc
    Man do I hope this solves my problem. I have a 2012 double cab and own the ATX crawl wheels and have the same annoying passenger seat shake thing at 70 miles an hour. I thought it was possibly the tires being made wrong as Ive had it balanced 3 times and it still does it. Ordered this morning via Amazon......will hope it solves the issue
  2. Apr 11, 2013 at 10:08 AM
    #62
    Plik
    Plik Ragin Cajun
    Houston
    '11 DCSB PreRunner TRD Sport
    Click my sig pic for build thread
    were you using an impact wrench? lol
  3. Jun 9, 2013 at 8:57 AM
    #63
    stolleee
    Memphis
    Well I installed the lugs however the hub rings ordered didn't fit the hub. My hub is slightly larger than the 108. I have a 4 wheel drive model......do you all have 2 wheel drive? Anyone got any ideas?
  4. Jun 14, 2015 at 7:16 PM
    #64
    HXC
    HXC Well-Known Member
    Cory
    Houston, Texas
    2011 white Dbl cab 4x4 6spd man.
    Does this only apply to aftermarket wheels? I'm running stock and 2 of them if they are in the front cause a horrible vibration. I've been to the shop multiple times for balance and nothing works. I've purchased new tires thinking that it was the bfgs that came on it but still have the issue. Recently bought some take offs from another member and still have the issue... Super annoyed that this $30k truck has a vibration that dealerships say is normal.
  5. Jun 14, 2015 at 7:18 PM
    #65
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Yes. The factory wheels are matched to the hub. No need for hub centric rings.
  6. Jun 14, 2015 at 7:26 PM
    #66
    HXC
    Cory
    Houston, Texas
    So stock is Lug centric, but aftermarket everyone does hub centric? Just trying to fix this vibration I've had since the first time it went to the dealership in 2011. I'm super close to saying screw it and trade it in because I feel that an ongoing vibration will cause more issues down the road.
  7. Jun 14, 2015 at 7:38 PM
    #67
    preybird1
    preybird1 02 taco on 37's
    Russ
    Salt lake city Utah
    2002 taco s\c
    Trd S\C with nosecone hybrid bearing upgrade kit. 2.0 urd pulley, 7th injector kit-urd "6 fabtech lift with 3" body lift. 20" XD spy wheels with toyo open country r\t's in 37"x 12.50x20. Front and rear diffs re-geared to 4.88 dirty 30 drive axles. and a rhino pack clutch. Custom exhaust and huge mudflaps!
    The reason your breaking these keys is they are not ment for hand tools. They are in fact designed for impact guns. I do this for a living also if you try and use your foot on the bar loosening the wheels then the key cocks crooked and splits. I have literally used one of these keys until the inside splines are almost stripped and the outside rounded off from impact guns.
  8. Jun 14, 2015 at 7:50 PM
    #68
    preybird1
    Russ
    Salt lake city Utah
    2002 taco s\c
    Toyota's are a huge PIA with after market wheels! You have to have hub rings period and the ET lugs don't hurt (extended threads)........And if you can watch next time your at the shop and see what your rubber is balancing at. more than 3 oz it could be all tire related. I have 37's with zero vibration all the way from 0-90 mph. I had a 2004 that vibrated like crazy and it turned out to be the steering column joints were loose. I just tack welded the joint and it stopped. but i don't know if the 2011 had the same style of steering column issue as the 1st gens. I just love the 1st gens. And finally i hate to say it but some wheels are just shitty quality. I've had wheels come bent from the manufacturer........I love to show the customer bent new product on there $40,000.00 car and say well there sending out a new wheel in 3 days sorry!!! F'N Quality inspected my A$%
  9. Jun 14, 2015 at 9:26 PM
    #69
    sparkystaco
    sparkystaco Well-Known Member
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    3" lift? A.R.E cap 285/70/17 moto metal 955 17x9
    Just the opposite factory is hub centric and usually aftermarket is lug centric.
  10. Jun 14, 2015 at 9:31 PM
    #70
    EatMyTacomaDust
    EatMyTacomaDust Well-Known Member
    2014 "Black Beauty" Baja DC 4x4
    ICON 3" LIFT, Console Vault, Tailgate Security Clamp MOD, SuperBumper Crash Attenuator, TRD Front Skid Plate, Wet Okoles - 1/2 Piped, Undercover SE Tonneau
  11. Jun 14, 2015 at 10:10 PM
    #71
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    This. Hence the need for hub centric rings on most aftermarket wheels.
  12. Jun 14, 2015 at 10:19 PM
    #72
    bubagump74
    bubagump74 SkiFreak
    Fred
    Montreal,Quebec
    2013 Trd OR
    NSA Pnl,US OFF ROAD winch mount bumper,Sirrius pods,Clazzio covers,Wheathertech mats, Pro Comp wheels,Image dynamics audio,leer cover,lights,bed mat,anti dark light...
  13. Jun 15, 2015 at 3:23 PM
    #73
    tacoma guy
    tacoma guy Well-Known Member
    Joe
    Phoenix Az.
    2011 Tacoma Prerunner TRD
    Bilstein 5100's on all four corners. Front set @ 0 with OME 883x coils. Alcon leaf springs. Viper Alarm. Wet Okole seat covers. WeatherTech Floor liners front and back. Oem Toyota chrome exhaust tip. ARE Shell. America Outlaw Wheels.
    OP thank you for posting this. This is very valuable information to those with the vibration issue or looking to get wheels. I have owned Toyota trucks for years and have done my fear share of after market wheels with lots of vibration issues. But last year when looking into once again doing after market wheels for my 2nd gen Tacoma I learned all about the hub centric and lug centric. So this time I got wheels that are 106.2 hub centric. If I would have known this years ago I could have saved myself a lot of grief. That's why I love this forum . :thumbsup:
  14. Jun 15, 2015 at 3:39 PM
    #74
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    You can get whatever wheels you want... That's the whole point of the hub centric rings.
  15. Mar 20, 2017 at 4:18 PM
    #75
    Prayn4surf
    Prayn4surf 20 minutes late
    Socal
    2004 Tacoma xtra cab
    So I'm gonna bring this thread back to life curious if anyone has the method NV wheels, and what size rings they used...if I take out the center caps the rings from the original OP will fit...not sure if I should be taking out my center cap on my wheels just to run these rings... so my truck does get some vibration between 60 and 70 miles an hour... I do like those SCS wheels... I wish I knew about this three years ago when I bought my wheels :facepalm:
  16. Mar 20, 2017 at 7:15 PM
    #76
    tamer
    tamer hamerworx.com
    NorCal
    2015 TRD OR AC, MGM, 4x4, 6spd MT
    Great thread. Has anyone used these in combination with a 1/4" spacer? Not sure if they'll reach the hub with the spacer installed.
  17. Jan 6, 2018 at 6:44 PM
    #77
    BraskaTaco
    BraskaTaco Well-Known Member
    Midwest
    2013 Tacoma TRD OR
    Yup I'm having this problem with my Method NV's even though the road force said they were near perfect.
    These are the lugs I'm running: https://www.summitracing.com/parts/gor-21138etbc
    Should I try new lugs or the hug centric rings first?
  18. Jan 6, 2018 at 7:34 PM
    #78
    Prayn4surf
    Socal
    Get the conical lugs and if you can fit the rings on with your center caps rock em, they wont fit mine w the center caps, my vibration isnt too bad
  19. Jan 6, 2018 at 9:12 PM
    #79
    BraskaTaco
    Midwest
    2013 Tacoma TRD OR
    I’m not running any center caps.. is it possible that the center caps act as hub centric rings?? Lol
  20. Jan 6, 2018 at 9:27 PM
    #80
    Prayn4surf
    Socal
    Haha i wondered the same thing, i doubt it, but if you dont have the center caps on your wheels then the rings will fit fine...put the right lugs n the center caps on and see what happens lol
    BraskaTaco[QUOTED] likes this.
